1 Reply Latest reply on Nov 7, 2006 2:54 PM by jonnybennett
    sending variables to flash from php code
      I have this login form that works with a sql database. When a user submits login info, it is check against the database through a php doc. If the information matches, the php doc sends an ok to the flash doc to move to the next frame.
      This works fine.
      I am now trying to use the load movie function in flash on the next frame to load an external swf on level 10.
      basically this:
      ifFrameLoaded (1) {
      loadMovie(file.swf", 10);
      However, I would like to have the "file" in "file.swf" replaced by the users username:
      ifFrameLoaded (1) {
      loadMovie(userName+".swf", 10);
      My question is... How do I write the php code to send the 'user' or 'steve' variable to this frame in flash? and second... what do I need to do in the flash doc to make this work?
      Any help would be greatly appreciated... I have pasted the php code below.
      //connect to database
      if ($user && $pass){
      mysql_pconnect("dbhost","dbusername","dbpassword") or die ("didn't connect to mysql");
      mysql_select_db("dbname") or die ("no database");
      //make query
      $query = "SELECT * FROM login WHERE username = '$user' AND password = '$pass'";
      $result = mysql_query( $query ) or die ("didn't query");
      //see if there's an EXACT match
      $num = mysql_num_rows( $result );
      if ($num == 1){
      ///checklog= function in flash move. if checklog=1 then movie advances to next frame
      print "status=Connected&checklog=1";
      } else {
      print "status=Sorry, your user name and password are not valid.&checklog=2";
        • 1. Re: sending variables to flash from php code
          jonnybennett Level 1
          In your php add a variable for the successful username:
          print "status=Connected&checklog=1&userName=".$user;
          your A>s>
          sendUser=new LoadVars();
          recievedUser=new LoadVars();
          if (recievedUser.status=='Connected')
          loadMovie(userName+".swf", 10);}}
          Hope this helps.
