4 Replies Latest reply on Aug 9, 2011 10:35 AM by r4raghs
    Suggest File Structure
    r4raghs Level 1
      Suggest a file structure for the project combined Flex with Java, Going to use Eclipse alone to handle both Flex and Java. I'm having blazeds-turnkey-4.x. I would like to handle everything in and around WEB-INF folder in tomcat.
        • 1. Re: Suggest File Structure
          Vibhuti Gosavi(InfoCepts)
          I would suggest , in Web-Inf folder create following folders :
          1) classes - having all java classes of your project.
          2) flex - keep all configuration files in this folder.
          3) lib - keep all the external jar files.
          You can keep remoting config as follows:
          <?xml version="1.0" encoding="UTF-8"?>
          <service id="remoting-service"
              class="flex.messaging.services.RemotingService">
              <adapters>
                  <adapter-definition id="java-object" class="flex.messaging.services.remoting.adapters.JavaAdapter" default="true"/>
              </adapters>
              <default-channels>
                  <channel ref="my-amf"/>
              </default-channels>
              <destination id="loginService">
                  <properties>
                      <source>infocepts.irms.servlet.login.Login</source>
          <scope>application</scope>
                  </properties>
          <adapter ref="java-object" />
              </destination>
             <destination id="uploadService">
                  <properties>
                      <source>infocepts.irms.servlet.upload.Upload</source>
                  </properties>
              </destination>
             <destination id="FileUtil">
                  <properties>
                      <source>infocepts.irms.util.FileUtils</source>
                  </properties>
              </destination>
          <destination id="feedbackService">
                  <properties>
                      <source>infocepts.irms.servlet.feedback.Feedback</source>
                  </properties>
              </destination>
          <destination id="sessionService">
                  <properties>
                      <source>infocepts.irms.session.MySessionHandler</source>
                  </properties>
              </destination>
          <destination id="processService">
                  <properties>
                      <source>infocepts.irms.servlet.process.Process</source>
                  </properties>
              </destination>
          <destination id="reportService">
                  <properties>
                      <source>infocepts.irms.servlet.reports.Reports</source>
                  </properties>
              </destination>
          <destination id="emailService">
                  <properties>
                      <source>infocepts.irms.util.EMail</source>
                  </properties>
          </destination>
          <destination id="Service">
                 <properties>
                     <source>demo.Info</source>
                 </properties>
          </destination>
          </service>
          Thanks and Regards,
          Vibhuti Gosavi | vgosavi@infocepts.com | www.infocepts.com
          • 2. Re: Suggest File Structure
            r4raghs Level 1
            Hi Vibhuti Gosavi,
            As I'm using blazeds i have the folders u mentioned above.My doubt is, say for example I have a folder structure /tomcat/webapps/FirstApp/WEB-INF.
            I am creating first-app(project name) as dynamic web project in eclipse, in that instead of using default workspace, which path I have to use ? Is  /tomcat/FirstApp/WEB-INF correct ? Also, when create Flex project, I am using project path as /tomcat/webapps/FirstApp. Need more clarification.
            If u metion the paths upto create a project for both it would be greatful.
            • 3. Re: Suggest File Structure
              Vibhuti Gosavi(InfoCepts) Level 3
              Keep your files as follows:
              tomcat/webapps/blazeds/
              In blazeds folder put following folders:
              WEB-INF , META-INF  and output folder(i.e. bin-debug/bin-release) of your Flex project which contains the HTML page and SWF files.
              Thanks and Regards,
              • 4. Re: Suggest File Structure
                r4raghs Level 1
                I have done HelloWorld sample using this structure, seems much reliable.
                Thank you for your valuable time.
