2. Re: Is it possible to stretch or make the time line smaller or consolidate it?
WebGuyDesign Aug 10, 2011 1:22 PM (in response to relaxatraja)i don't see this, where exactly do i go pleaes explain better i am running flash cs5.5
3. Re: Is it possible to stretch or make the time line smaller or consolidate it?
Ned Murphy Aug 10, 2011 1:29 PM (in response to WebGuyDesign)Look for a small menu icon at the far right end of the timeline panel.
4. Re: Is it possible to stretch or make the time line smaller or consolidate it?
tmace64 Aug 11, 2011 12:46 PM (in response to Ned Murphy)I'm sorry, I had problems too finding the method to squeeze the timeline horizontally. It's a another poor interface design and programmed function in Flash.
5. Re: Is it possible to stretch or make the time line smaller or consolidate it?
Lon Winters Aug 12, 2011 12:05 PM (in response to tmace64)You're basically just changing the size of the frames in the timele. Selecting the smallest possible size frame will of course allow more of the timeline to ve seen in the viewable area. I understand that sometimes no matter what you do, you may end up with timelines containing a lot of frames. But this can be minimized by making good use of embedded movie clips and AS classes for teed ing and other things that normally require frames and keyframes.
6. Re: Is it possible to stretch or make the time line smaller or consolidate it?
WebGuyDesign Aug 12, 2011 12:22 PM (in response to Lon Winters)so basically there is no feature to this that has this ojbective.
