0 Replies Latest reply on Mar 25, 2009 2:10 PM by whole_bit
    loadMovie(XML) vs.Enterframe
      I am creating a swf slideshow from an external XML file. the XML system loads the swf movies into a movie symbol on the stage. The symbol has a format function for scale and position, and updates within an onEnterFrame code block based on stage size. When the swf loads into the symbol, it no longer updates its scale or position based on the stage size.
      I know that loading swfs causes the dimensions to adjust, however the dimesions of the container are based on an equation for stage size adjustment by the user. So...in theory the dimensions of the container should be controlled by constant calls to the enterFrame.
      This is the Enterframe Block and format function:
