3 Replies Latest reply on Dec 11, 2011 5:46 AM by BKBK
    Coldfusion Instant Message Example?
    citation1 Level 1
      I am trying to go through the IM example in ColdFusion 9 Web Application Construction Kit, Volume 3 (Chapter 71. Integrating with SMS and IM). Has anyone else actually got this example working using the sample code and database?
        • 1. Re: Coldfusion Instant Message Example?
          citation1 Level 1
          In the Coldfusion Admin, under Gateway Instances I have configured the following:
          Gateway ID: helpdesk
          Gateway Type: XMPP - Handles XMPP instant messaging
          CFC Path: C:\ColdFusion9\gateway\cfc\helpdesk\im.cfc
          Configuration File: C:\ColdFusion9\gateway\config\helpdesk_ejabberd_local.cfg
          After I start the "helpdesk" event and check the eventgateway.log there is the following mesage:
          Error invoking CFC for gateway helpdesk: Cannot lock APPLICATION scope.  {ORIGINATORID={lucas@jabber.com},CFCMETHOD={onBuddyStatus},GATEWAYID={helpdesk},DATA={{buddystatus={OFFLINE},buddynicknam e={Lucas},RECIPIENT={me@localhost},buddygroup={Helpdesk  Staff},timestamp={Wed Aug 10 15:11:29 EDT  2011},buddyname={lucas@jabber.com}}},CFCPATH={C:\ColdFusion8\gateway\cfc\helpdesk\im.cfc},GATEWAYTYPE={XMPP}}.  Cannot use cflock to lock the application or session shared scopes without these  scopes being established through the use of the cfapplication tag. To use the  session scope you need to enable session management. Application and/or Session  variables must also be enabled in the ColdFusion Administrator.
          However, Event Status says that it is running.
          When I run the sample index page and I do see a message that says "The helpdesk is currently ONLINE."
          But when I attempt to Add a new issue --- I receive the following:
          The error occurred in C:\Inetpub\wwwroot\DEV_Helpdesk\cfc\helpdesk.cfc: line 25
          Called from C:\Inetpub\wwwroot\DEV_Helpdesk\index.cfm: line 5
          Called from C:\Inetpub\wwwroot\DEV_Helpdesk\cfc\helpdesk.cfc: line 25
          23 : (id,status,subject,DateLogged,Assignedto,loggedby,loggedbyemail,body)
          24 : values
          25 : ('#createUUID()#','unassigned','#arguments.subject#',#CreateODBCDateTime(Now())#,'unassign ed','#arguments.name#','#arguments.email#','#arguments.body#')
          26 : </cfquery>
          • 2. Re: Coldfusion Instant Message Example?
            brademp
            Did you ever have any luck with this?  I'm getting ready to try the same thing and it would be great to know in advance if the example is broken or not?
            • 3. Re: Coldfusion Instant Message Example?
              BKBK Adobe Community Professional & MVP
              Enable application variables and session variables in the 'Memory Variables' page in the ColdFusion Administrator. Then create the following application file and save it in the DEV_Helpdesk directory.
              Application.cfm
              <cfapplication name = "myHelpdesk"  applicationTimeout = "#CreateTimeSpan(1, 0, 0, 0)#" sessionmanagement = "yes" sessionTimeout = "#CreateTimeSpan(0, 0, 20, 0)#">
