6 Replies Latest reply on Aug 9, 2011 2:47 AM by Tim Goodman
    Execute Script - How to Update second node in XML group
    Tim Goodman Level 1
      I have an XML variable "myXML" which is set to:
      <root>
           <nodes>
                <node>
                     <value>a</value>
                </node>
                <node>
                     <value>b</value>
                </node>
           </nodes>
      </root>
      Question - within an Execute script, how can I easily access and update the second node value? i.e. change "b" to "c"
      The following fails in Execute Script (although it is possible using an XPath expression in a SetValue
        patExecContext.setProcessDataValue("/process_data/myXML/root/nodes/node[1]/value", "c");
      If I have square brackets in this expression then it fails with a nasty error
      Is there an easy way?
