0 Replies Latest reply on Aug 9, 2011 6:55 AM by ourri99
    LoadXML external XML
    ourri99
      Hello everybody,
      Question, How I can load the external xml file data in the form.
      For examle I have owned a dropdown list box that contains the following give: A, B, C.
      And then I have fields in my form: TextField1, TextField2,textField3.
      By changing event dropdownlist box I must load the xml dynamically:
      http://mywebsite.com/userdata/myxml-A.xml
      or
      http://mywebsite.com/userdata/myxml-B.xml
      or
      http://mywebsite.com/userdata/myxml-C.xml
      The XML file is loaded in the fields fill in the form:
      for example:
      textField1.rawValue = C.textForField1
      textField2.rawValue = C.textForField2
      textField3.rawValue = C.textForField3
      Does anyone could give me an example how I shouldproceed?
      Thank you in advance.
      Here is my scipt // don't work
      Projects.Page1.lstProjects::change - (JavaScript, client)
      var xmlURL = "http://www.mywebsite.com/userdata/myXML-"+xfa.event.newText+".xml";
      app.alert(xmlURL); //work, response : http://www.mywebsite.com/userdata/myXML-A.xml";
      xfa.datasets.loadXML(xmlURL, false, false);
      xfa.datasets.saveXML();
      var projectXML=xfa.datasets.resolveNode("Project");
      app.alert(projectXML); // don't work
      var numberOfNodes = projectXML.nodes.length;
      app.alert(numberOfNodes); //don't work
      Here is the structure of myXML file (myXML-A.xml) :
      <?xml version="1.0" encoding="UTF-8"?>
      <!DOCTYPE Project SYSTEM ".dtd/project.dtd">
      <Project>
           <OfficialNumber>001</OfficialNumber>
           <Title>Title of my test project</Title>
           <DateReceived showFormat="YYYY-MM-DD" defaultFormat="YYYY-MM-DD">2011-06-30</DateReceived>
           <TypeOfProject>Type1</TypeOfProject>
           <Organisation>Organisation1</Organisation>
      </Projec
