2 Replies Latest reply on Aug 10, 2011 7:12 AM by s_davies
    Reset application on startup
    s_davies
      I mentioned thi sbefore but probably in the wrong way so here goes.
      When testing my application on an android and ipad, everythign is ok, but when I sya, close the app down via pressing the home button on the ipad/android, then when I press my app to open it again, it remains on the last screen it was clsoed on.
      Is there a way in which i can make my app load the first page or loading screen each time its reopened, so the user is taken to the beginning each time.
      Hope this makes sense
      Si
        • 1. Re: Reset application on startup
          Rangora Level 3
          In your application.mxml, listen to the creationComplete event and add this code :
          protected function app_creationCompleteHandler(event:FlexEvent):void
                    NativeApplication.nativeApplication.addEventListener(Event.DEACTIVATE, returnToFirstView);
          public function returnToFirstView(event:Event):void
                   navigator.popAll();
                   navigator.pushView(views.LoginView);
          But beware... If your app is deactivated because you use the CameraUI or the CameraRoll (for example), the event will be fired.... in this case you would have to add a mechanism to prevent the effect (set a static boolean would work).
          • 2. Re: Reset application on startup
            s_davies Level 1
            Thanks, that seemed to work.
            On android it resets on closure andon the iPad it resets when the app is re opened.
            Si
