1 Reply Latest reply on Aug 9, 2011 9:05 AM by lomorgan
    Create new extension project - hangs
    Richard Butler
      I've installed Extension Builder 1.5 on OSX.
      I am working in a large organisation behind quite a paranoid firewall, so I'm getting a hang on creating a project; all I get is a "Contacting server" window that forces me to close Eclipse as it never goes away.
      Is there really no provision for users behind firewalls or with limited/intermittent internet access?
        • 1. Re: Create new extension project - hangs
          lomorgan Adobe Employee
          Hi Richard,
          Extension builder will dial home every few days - I think the blocking dialog is only shown if you haven't contacted the server for a week or more (or if it's the first attempt). If you use the machine outside of the firewall once a week then that should allow extension builder to connect and function normally. I'm surprised that the request is blocked by your firewall, as it is just an HTTP request - I'll investigate this further.
          The dialog should also not be blocking - we haven't seen this behaviour before, and I would imagine the firewall and our timeout code aren't playing well together - I'll look into this too.
          Note that extension builder only tries to authenticate if you are using extension builder functionality - you should be able to work on non-extension projects in eclipse and flash builder without being presented with that dialog.
          Hope that helps,
          Louis
