7 Replies Latest reply on Aug 19, 2011 2:04 AM by mdecler
    [FB4.5 LCDS AIR] No data to AIR apps.
    mdecler
      Hi everybody.
      I'm trying out the new Flash Builder 4.5.1 and in particular the mobile section. Love to create a mobile app.
      Been using LCDS for a while now to and loving it. Creating RIA's with the LCDS backend connected to a MySQL database works like a charm.
      Now I want to enable LCDS for a new mobile project but i'm running on some trouble.
      Things to know: LCDS is working 100%, including the MySQL backend. Can create web bases RIA's that works 100% (CRUD actions).
      But when I create a mobile project with a LCDS backend there is no data to be displayed. I use a list component to show a single culomn but nothing.I figured out that the problem lies with AIR. When I delete the mobile project and create an AIR desktop application the problems return. It seems that LCDS only works when the created project is web based. When local AIR apps are created, LCDS doesn't return the from the MySQL database.
      I monitored the network calls and these are the results:
      ServiceRequest: trigger connect; MessageService; trigger connect
      (mx.messaging.messages::CommandMessage)
        body=(Object)#0
        clientId=(null)
        correlationId=""
        destination="test2.Customers"
        headers=(Object)#0
        messageId="8B8011E1-3688-4F12-FCB1-B087B1CB9E51"
        operation="trigger connect"
        timeToLive=0
        timestamp=0
      Why is LCDS not working in combination with AIR apps?
      EDIT
      Finaly it spet out an error message. Within the AIR app:
      Could not initialize DataService.
      Cannot connect to the server to load configuration for destinations: ["test2.Customers"]
      Hope that helps..
        • 1. Re: [FB4.5 LCDS AIR] No data to AIR apps.
          Mike Peterson Level 1
          The issue is that you are not getting a channel connection between the AIR app and the server. You have to create ChannelSet and Channel explicitly in the script block of your MXML file.
          This section of the doc should help as a reference:
          http://help.adobe.com/en_US/LiveCycleDataServicesES/3.1/Developing/WS4ba8596dc6a25eff-56f1 c8f4126dcd963c6-8000.html
          Basically, you need something like the bolded text below in your script block. Note that this is for an app build using model-driven development. The bolded items would be essentially the same though; one small difference that you would reference your DataService object with yourService.channelSet rather than productService.serviceControl.channelSet. The "serviceControl" is the name of the DataService instance in a generated service wrapper and applies only to model-driven development.
          <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:OfflineAIRAPP="OfflineAIRAPP.*"
          preinitialize="app_preinitializeHandler(event)"
          creationComplete="windowedapplication1_creationCompleteHandler(event)">
              <fx:Script>
                  <![CDATA[
                      import com.adobe.offline.ProductOfflineAdapter;
                      import mx.controls.Alert;
                      import mx.events.FlexEvent;
                      import mx.messaging.Channel;
                      import mx.messaging.ChannelSet;
                      import mx.messaging.channels.RTMPChannel;
                      import mx.messaging.events.ChannelEvent;
                      import mx.rpc.AsyncToken;
                      import mx.rpc.events.FaultEvent;
                      import mx.rpc.events.ResultEvent;
                      public var myOfflineAdapter:ProductOfflineAdapter;
                      public function channelConnectHandler(event:ChannelEvent):void
                          productService.serviceControl.autoConnect=false;
                      protected function
                          app_preinitializeHandler(event:FlexEvent):void
                          var cs:ChannelSet = new ChannelSet();
                          var customChannel:Channel = new RTMPChannel("my-rtmp",
                              "rtmp://localhost:2037");
                          cs.addChannel(customChannel);
                          productService.serviceControl.channelSet=cs;
                          customChannel.addEventListener(ChannelEvent.CONNECT,
                              channelConnectHandler);
                      protected function dataGrid_creationCompleteHandler(event:FlexEvent):void
                          getAllResult.token = productService.getAll();
                      protected function
                          windowedapplication1_creationCompleteHandler(event:FlexEvent):void
                          productService.serviceControl.autoCommit = false;
                          productService.serviceControl.autoConnect = false;
                          productService.serviceControl.autoSaveCache = false;
                          productService.serviceControl.offlineAdapter = new
                              ProductOfflineAdapter();
                          productService.serviceControl.fallBackToLocalFill=true;
                          productService.serviceControl.encryptLocalCache = true;
                          productService.serviceControl.cacheID = "myOfflineCache";
                      protected function connectBtn_clickHandler(event:MouseEvent):void
                          productService.serviceControl.connect();
                      protected function DisconnectBtn_clickHandler(event:MouseEvent):void
                          productService.serviceControl.disconnect();
                      protected function commitBtn_clickHandler(event:MouseEvent):void
                          productService.serviceControl.commit();
                      protected function saveCacheBtn_clickHandler(event:MouseEvent):void
                          productService.serviceControl.saveCache();
              </fx:Script>
              <fx:Declarations>
                  <s:CallResponder id="getAllResult" />
                  <OfflineAIRAPP:ProductService id="productService"
                      fault="Alert.show(event.fault.faultString + '\n' +
                      event.fault.faultDetail)"/>
              </fx:Declarations>
              <mx:DataGrid editable="true" x="9" y="10" id="dataGrid"
                  creationComplete="dataGrid_creationCompleteHandler(event)"
                  dataProvider="{getAllResult.lastResult}">
                  <mx:columns>
                      <mx:DataGridColumn headerText="productid" dataField="productid"/>
                      <mx:DataGridColumn headerText="description" dataField="description"/>
                      <mx:DataGridColumn headerText="price" dataField="price"/>
                      <mx:DataGridColumn headerText="productname" dataField="productname"/>
                  </mx:columns>
              </mx:DataGrid>
              <s:Button x="10" y="246" label="Connect" click="connectBtn_clickHandler(event)"
                  id="connectBtn" width="84" height="30"/>
              <s:Button x="112" y="204" label="Save to Local Cache" id="saveCacheBtn"
                  click="saveCacheBtn_clickHandler(event)" height="30"/>
              <s:Button x="110" y="246" label="Commit to Server" id="commitBtn"
                  click="commitBtn_clickHandler(event)" width="135" height="30"/>
              <s:Button x="10" y="204" label="Disconnect" id="DisconnectBtn"
                  click="DisconnectBtn_clickHandler(event)" height="30"/>
              <s:Label x="270" y="204" text="{'Commit Required: ' +
                  productService.serviceControl.commitRequired}"/>
              <s:Label x="270" y="246" text="{'Connected: ' +
                  productService.serviceControl.connected}"/>
          </s:WindowedApplication>
          • 2. Re: [FB4.5 LCDS AIR] No data to AIR apps.
            mdecler Level 1
            Thank you so much for your answer! Really apreseate it!
            It helped me a long way and i'm now capable of creating LCDS driven AIR apps.
            Only problem though with the Mobile section. Did everything by the book but the list is still not getting populated.. The code:
                           xmlns:test7="test7.*"
                           applicationDPI="160">
                <fx:Script>
                    <![CDATA[
                        protected function
                        protected function
                        protected function list_creationCompleteHandler(event:FlexEvent):void
                </fx:Script>
                <fx:Declarations>
                    <s:CallResponder id="getAllResult"/>
                    <test7:ProductService id="productService"/>
                    <!-- Place non-visual elements (e.g., services, value objects) here -->
                </fx:Declarations>
                <s:List id="list" x="10" y="10" creationComplete="list_creationCompleteHandler(event)"
                        labelField="productname">
                    <s:AsyncListView list="{getAllResult.lastResult}"/>
                </s:List>
            </s:Application>
            It is just a simple list component that needs to be filled, in this case by the LCDS sample database. When I monitor the network connections, the trigger is running succesfully with the following output:
              body=(Object)#0
              clientId=(null)
              correlationId=""
              destination="test7.Product"
              headers=(Object)#0
              messageId="28C54E63-357A-6ACF-B9FD-C0889B6115E9"
            Status: OK
            But there is no Fill execution. When I run this code in an AIR desktop application all runs smooth. Air starts -> connection trigger OK -> Fill execution OK -> And i have a lovely list component filled with Data. When I run this in a mobile app the connection trigger is OK but the fill is not executed.
            Can you help? If you need any further information, just let me know!
            thx!
            • 4. Re: [FB4.5 LCDS AIR] No data to AIR apps.
              kasmit44 Level 2
              You are using "rtmp://localhost:2037" as your channel URL.  You need to use the real IP or servername since localhost is unknown to a mobile.
              Regards,
              KenS
              • 5. Re: [FB4.5 LCDS AIR] No data to AIR apps.
                mdecler Level 1
                It doenn't really matter of I change the Localhost to an external adres like an IP or server adres, it sas that it has a connection to the server. The Fill doesn't get executed and I don't know why.
                Changed the localhost adres to a staic IP from the server though, thx for the advice!
                Please, anyone have a clue why the Fill is not working? I'm reallt stuck here..
                • 6. Re: [FB4.5 LCDS AIR] No data to AIR apps.
                  kasmit44 Level 2
                  I have tried duplicating your issue. When I use your code and create a new model against Product - both the air desktop and mobile project work for me. Send me your project in a private message and I will take a look at it (as time allows).
                  • 7. Re: [FB4.5 LCDS AIR] No data to AIR apps.
                    mdecler Level 1
                    Thank you very much for the effort! I'm currenly at work. When I get home i'll
                    get right on it.
                    And again, thx!
