4 Replies Latest reply on Aug 10, 2011 6:49 AM by nikos101
    Complex object types cannot be converted to simple values with a good path
    nikos101 Level 2
         <cffile action='Write' file="#filename#" output='#data#' >
      works fine with
      <cfset filename = "\\fs-shared\shared$\biz\pre\#DateFormat(now(), "dd mmm yyyy hh mm ss")#.xml">
      but with this
          <cfset filename = "c:\#DateFormat(now(), "dd mmm yyyy hh mm ss")#.xml">
      I get this:
      faultCode:Server.Processing faultString:'Unable to invoke CFC - Complex object types cannot be converted to simple values.' faultDetail:'The expression has requested a variable or an intermediate expression result as a simple value. However, the result cannot be converted to a simple value. Simple values are strings, numbers, boolean values, and date/time values. Queries, arrays, and COM objects are examples of complex values. <p> The most likely cause of the error is that you tried to use a complex value as a simple one. For example, you tried to use a query variable in a cfif tag.'
