2 Replies Latest reply on Nov 6, 2006 5:56 AM by Newsgroup_User
    Timed tween?
    BryanThomas Level 1
      Is there any way to make a timed tween from image A to image B using actionscript? Ex. Making image A fade out and image B to fade in, all of this over 5 seconds. Thanks.
        • 1. Re: Timed tween?
          Sketchsta Level 1
          why not just make image A and B animate for 5 seconds in iys own timeline.
          That way it wount interfeer with anything else.
          im saying that as an alternative to using actionScript...
          but if you DO find the code to do it.. please share it with me... =)
          the more code one has the better..
          • 2. Re: Timed tween?
            Level 7
            >> seconds. Thanks.
            Sure thing. If the idea is to make it look like A is dissolving into B,
            I would leave B at full opacity the whole time. Just reduce A's opacity.
            If you fade one out and fade one in at the same time, there's this "dead
            spot" when both are at half opacity, and the whole image seems to dip out
            momentarily.
            You could use the Tween class for this. Look up "Tween class" in the
            documentation and you'll find a section on "About the Tween class" as well
            as the Tween class entry itself, in the Components Language Reference. Use
            _alpha as the property to tween.
            > in iys own timeline. That way it wount interfeer with anything
            > else.
            There are definitely times to animate by hand (think complex character
            animation), but there are also times to animate via ActionScript. If you
            want something to animate for 5 seconds in a timeline, you have to take into
            consideration what framerate you're running and do the math. If you need
            five seconds at 24fps, you need 120 frames for that. What if you decide to
            change your mind? What if you need 10 seconds? Now you need 240. What if
            you change the movie's over all framerate? With ActionScript and the Tween
            class, you only need one frame.
            > me... =) the more code one has the better..
            Code can actually be harmful if you're unfamiliar with it. ;) More
            important than finding code is making sure you have a programmer's mindset.
            David Stiller
            Adobe Community Expert
            Dev blog, http://www.quip.net/blog/
            "Luck is the residue of good design."
