0 Replies Latest reply on Aug 10, 2011 6:18 PM by Daryl_69
    Resetting spark list components and errorString not working as expected
      I would like to reset the list components  (DropDownList, List, ComboBox) on a form. Normally with mx components I set the selectedIndex to 0 (or -1) and then set errorString on the component to "" this resets the list and hides the error message generated by a validator on the component.
      I'm finding that with spark lists I'm having to delay setting the errorString to "" after setting the selected index to 0.
      Below is a form which demonstrates the behaviour.
      Make a selection in each list then click the clear button. The spark components show an error - not what I expect.
      Then repeat the above but with the Call later check box selected - now the form works as expected.
      1. Why do I have to delay clearing the errorString on spark lists?
      2. Am I doing something wrong?
         xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
      <s:VerticalLayout horizontalAlign="center" verticalAlign="middle"/>
      import mx.core.UIComponent;
      import mx.events.FlexEvent;
      import mx.events.ValidationResultEvent;
      import mx.validators.Validator;
      private function okBtn_clickHandler(event:MouseEvent):void
      if (validatePage())
      resultLbl.text = "Good";
      resultLbl.text = "Bad";
      public function validatePage():Boolean
      return Validator.validateAll(validatorList).length == 0;
      public function clearValidationErrors():void
      for each (var validator:Validator in validatorList)
      validator.source.errorString = "";
      resultLbl.text = "";
      private function clearBtn_clickHandler(event:MouseEvent):void
      sparkList.selectedIndex = 0;
      mxList.selectedIndex = 0;
      sparkDdl.selectedIndex = 0;
      sparkCbo.selectedIndex = 0;
      mxCbo.selectedIndex = 0;
      if (callLaterCkb.selected)
      private function application1_creationCompleteHandler(event:FlexEvent):void
      <fx:Array id="validatorList">
      <mx:NumberValidator id="sparkListValidator"
      source="{sparkList}" property="selectedIndex"
      requiredFieldError="Spark List is required"
      lowerThanMinError="stateLst index is too small"/>
      <mx:NumberValidator id="mxListValidator"
      source="{mxList}" property="selectedIndex"
      requiredFieldError="MX List is required"
      lowerThanMinError="mxList index is too small"/>
      <mx:NumberValidator id="sparkDropDownListValidator"
      source="{sparkDdl}" property="selectedIndex"
      requiredFieldError="Spark DDL is required"
      lowerThanMinError="sparkDdl index is too small"/>
      <mx:NumberValidator id="sparkComboValidator"
      source="{sparkCbo}" property="selectedIndex"
      requiredFieldError="Spark Cbo is required"
      lowerThanMinError="sparkCbo index is too small"/>
      <mx:NumberValidator id="mxComboListValidator"
      source="{mxCbo}" property="selectedIndex"
      requiredFieldError="MX Combo is required"
      lowerThanMinError="mxCbo index is too small"/>
      <s:ArrayCollection id="stateAc">
      <fx:Object label="NSW" data="N" state_id="0"/>
      <fx:Object label="QLD" data="Q"  state_id="1"/>
      <fx:Object label="VIC" data="V" state_id="2"/>
      <fx:Object label="SA" data="S" state_id="3"/>
      <fx:Object label="ACT" data="A" state_id="4"/>
      <s:Form id="theForm" >
      <s:FormItem label="Spark List">
      <s:List id="sparkList" labelField="label" dataProvider="{stateAc}"/>
      <s:FormItem label="MX List" width="100">
      <mx:List id="mxList" labelField="label" dataProvider="{stateAc}" width="100%"/>
      <s:FormItem label="Spark Drop Down List">
      <s:DropDownList id="sparkDdl" labelField="label" dataProvider="{stateAc}"/>
      <s:ComboBox id="sparkCbo" labelField="label" dataProvider="{stateAc}"/>
      <s:FormItem label="MX Combo">
      <mx:ComboBox id="mxCbo" labelField="label" dataProvider="{stateAc}" editable="false"/>
      <s:HGroup width="100%">
      <s:Button id="okBtn" label="OK" click="okBtn_clickHandler(event)"/>
      <s:Button id="clearBtn" label="Clear" click="clearBtn_clickHandler(event)"/>
      <s:CheckBox id="callLaterCkb" label="Call Later"/>
      <s:Label id="resultLbl"/>
