6 Replies Latest reply on Aug 12, 2011 5:51 AM by Venkatesan Balasubramanian
    how to avoid  save same employee name under same company name
    Venkatesan Balasubramanian Level 1
      hi,
      i am doing flex4 web application with mxml tags,
      i am having one text box and one datagrid and one save button. text box having one company name, data grid having employee names.
      when i click save button which is placed in outside the datagrid it will save all the details.
      Now my requirement is text box having the same company name and when i enter same employee name in datagrid and click save button means it wont
      allow to save that record, and through msg box with some alerts.
      How to do this,
      Any suggession or snippet code are welcome
      Thanks ,
      B.venkatesan
        • 1. Re: how to avoid  save same employee name under same company name
          Kumar Pratik Level 1
          Dint understand your question.. An example could help
          • 2. Re: how to avoid  save same employee name under same company name
            hi,
            when i click save button which is placed in outside the datagrid it will save all the details in cloud DTO.
            this is my code:
            private function saveRecord():void
                        refreshRecords();
                        model.employeeDetailsReq=new EMPLOYEEDETAILS_DTO();
                            var lengthindex:uint=model.employeeDetailsReqRecordsList.length;
                            var i:int;
                            for (i = 0; i < lengthindex; i++)
                            if((model.employeeDetailsReqRecordsList.getItemAt(lengthindex).employee name==customerdet.selectedItem.employeename)&&
                                (model.employeeDetailsReqRecordsList.getItemAt(lengthindex).employeeNumber==customerdet.s electedItem.employeeID)){
                                Alert.show("you cannot Add Same CustomerName and Invoiceno again");
            (when this line come the error through like this: Index '8' specified is out of bounds.
            else
            var dp:Object=employeedet.dataProvider;
            var cursor:IViewCursor=dp.createCursor();
            var employeename:String = employeename.text;
                     model.employeeDetailsReq.employename = employeename;
            model.employeeDetailsReq.employeeNumber=cursor.current.employeeID;
            var sendRecordToLocID:QuickBaseEventStoreRecord = new
                                QuickBaseEventStoreRecord(model.employeeDetailsReq, new
                                    KingussieEventCallBack(refreshList))
                            sendRecordToLocID.dispatch();
            <mx:Button id="btnAdd" x="33" y="419" enabled="false" label="Add" width="65" fontFamily="Georgia" fontSize="12" click="saveRecord()"/>
            employeename and employeeID are datafields of datagrid. datagrid id=customerdet
            employeeDetailsReqRecordsList---recordlist of save records
            please help .
            any suggession or snippet code welcome
            B.venkatesan
            • 3. Re: how to avoid  save same employee name under same company name
              miguel8312 Level 3
              if I understand correctly you would like to not save a record that has already been saved. if that
              s the case then how are you saving the records on the click event of the grid. if you are using listevent then you can
              grab the datagrid column values add to an array or make a service call to server and compare the value to see if its already there if its there then throw and alert box up if its not then save it.
              Let me know if this answers your question.
              Miguel
              • 4. Re: how to avoid  save same employee name under same company name
                hi miguel8312,
                you said"if I understand correctly you would like to not save a record that has already been saved. if that
                s the case then how are you saving the records on the click event of the grid"
                till tat ur answer is correct after that , i am not using any server while creating a flex4 web application.so i cant make any request to the severr.i am using
                cloud to store my data.there i am somany DTO. i am creating DTO with so many fields and assigned their data type. that DTO fields using in flex application.
                B.venkatesan
                • 5. Re: how to avoid  save same employee name under same company name
                  r4raghs Level 1
                  why dont't you ask in brief ? much complicated to read the whole thing.
                  • 6. how to avoid  specified is out of bounds error in flex 4 mxml web application
                    hi raghs,
                    i want to add records in cloud.bt while adding the records if we enter existing record details and try to save again na it wont allow to that record.
                    that time the alert box  should show this msg "This record is already existing record in cloud database.
                    ex: one company name called mobile. i am adding a employee name called raja now i save this record,its data saved in     cloud DTO
                      again try to add same employee name raja under the same compny means it should through error.
                    I am give my code here please if any suggession tel.
                    CODE:
                                refreshRecords();
                                    var i:int;
                                    if((model.employeeDetailsReqRecordsList.getItemAt(lengthindex).employ ee name==customerdet.selectedItem.employeename)&&
                                         (model.employeeDetailsReqRecordsList.getItemAt(lengthindex).employeeN  umber==customerdet.selectedItem.employeeID)){
                    else
                    B.venkatesan
