4 Replies Latest reply on Dec 27, 2011 12:38 PM by kingdok 10001
    After Effects CS5 Dynamic Link Manager Crashing
    JaredPeace
      Hi. Every time I go to use an effect in After Effects CS5, the program crashes and spits
      out a message about an error with the Dynamic Link Manager (full text of message
      included below). I researched this here and on the Creative Cow and it seems to be a
      fairly common problem, and the solution that was suggested was going into the Common
      files for Adobe and trashing the preferences for CS5 and restarting the application. And
      although that MAY work on a new project (not sure - haven't tried), it's doing nothing as
      yet for the project I was previously working on.
      So. As anyone who knows how quickly an After Effects project becomes too complicated
      to just start fresh, is there any way to fix the program so I can finish this effects shot?
      Thanks.
      Process:         After Effects [243]
      Path:            /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After Effects
      Identifier:      com.adobe.AfterEffects
      Version:         10.0 (10.0)
      Code Type:       X86-64 (Native)
      Parent Process:  launchd [75]
      Date/Time:       2011-08-11 03:33:31.557 -0600
      OS Version:      Mac OS X 10.5.4 (9E25)
      Report Version:  6
      Exception Type:  EXC_BAD_ACCESS (SIGABRT)
      Exception Codes: KERN_INVALID_ADDRESS at 0x000000000e1d2da4
      Crashed Thread:  0
      Thread 0 Crashed:
      0   libSystem.B.dylib             0x00007fff82f94dd6 __kill + 10
      1   U.dylib                       0x0000000102a88867 U_LoadFrameworkBundle + 695
      2   libSystem.B.dylib             0x00007fff82f9334a _sigtramp + 26
      3   ???                           0x0000000000001000 0 + 4096
      4   ...e.AfterEffectsLib.framework 0x00000001006f30d7 FEE_PerformEyedropper(PF_PixelFloat const&, Point, int, unsigned char (*)(Point, void*), void (*)(PF_PixelFloat const&, void*), void*, PF_PixelFloat*) + 343
      5   ...e.AfterEffectsLib.framework 0x000000010085f280 CLayer::TrackEyeDropper(CPanorama*, TDB_StreamIDPath const&, M_Rect*, M_Rect*) + 480
      6   ...e.AfterEffectsLib.framework 0x0000000100afb45a CComposition::GetMarkerInfoStr(T_Time const&) + 21658
      7   ...e.AfterEffectsLib.framework 0x0000000100afb617 CComposition::GetMarkerInfoStr(T_Time const&) + 22103
      8   ...e.AfterEffectsLib.framework 0x0000000100a1c963 COutlineDir::GetOutlinePano() + 23395
      9   ...e.AfterEffectsLib.framework 0x00000001009fff4b WF_WatchFolder(FILE_Spec*) + 126379
      10  ...e.AfterEffectsLib.framework 0x0000000100a1f0c5 COutlineDir::GetOutlinePano() + 33477
      11  ...e.AfterEffectsLib.framework 0x00000001006d3bf9 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 393
      12  ...e.AfterEffectsLib.framework 0x00000001006d3b14 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 164
      13  ...e.AfterEffectsLib.framework 0x00000001006d3b14 CView::DispatchMouseEvent(ae::egg::MouseEvent const&) + 164
      14  ...e.AfterEffectsLib.framework 0x0000000100702058 dvacore::utility::SearchLiveHelp(std::basic_string<unsigned short, std::char_traits<unsigned short>, std::allocator<unsigned short> >) + 7480
      15  ...e.AfterEffectsLib.framework 0x0000000100a16d9e GetCEffects(BEE_Layer*) + 67326
      16  com.adobe.dvaui.framework     0x00000001031d8822 dvaui::ui::UI_Node::UI_DispatchMouseEventToLeaf(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&) + 146
      17  com.adobe.dvaui.framework     0x00000001031db7d5 dvaui::ui::UI_Node::DispatchMouseEvent::operator()(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvacore::geom::PointT<float> const&) const + 165
      18  com.adobe.dvaui.framework     0x00000001031e5243 std::pair<bool, dvaui::ui::UI_Node*> dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeafT<dvaui::ui::UI_Node::DispatchMouseEv ent>(dvaui::ui::UI_Node::DispatchMouseEvent&, dvacore::geom::PointT<float> const&, bool) + 131
      19  com.adobe.dvaui.framework     0x00000001031df613 dvaui::ui::UI_Node::UI_DispatchMouseEventTowardsLeaf(dvaui::ui::MouseEvent const&, bool) + 83
      20  com.adobe.dvaui.framework     0x00000001031e0dcf dvaui::ui::UI_Node::UI_DispatchMouseEventToTarget(dvaui::ui::UI_Node*, dvaui::ui::MouseEvent const&, bool) + 159
      21  com.adobe.dvaui.framework     0x00000001031e0eb4 dvaui::ui::UI_Node::UI_DispatchMouseEvent(dvaui::ui::MouseEvent const&, bool) + 68
      22  com.adobe.dvaui.framework     0x0000000103254433 dvaui::ui::OS_View::UI_DispatchPlatformMouseEvent(dvaui::ui::MouseEvent const&, bool) + 595
      23  com.adobe.dvaui.framework     0x0000000103250249 dvaui::ui::OS_View::UI_DispatchPlatformMouseClickEvent(dvaui::ui::OS_Event const&) + 313
      24  com.adobe.dvaui.framework     0x00000001032568a2 dvaui::ui::OS_View::UI_DispatchEvent(dvaui::ui::OS_Event*) + 450
      25  com.adobe.dvaui.framework     0x000000010324138f dvaui::ui::OS_View::UI_HandleOSEvent(dvaui::ui::OS_Event*) + 31
      26  com.adobe.dvaui.framework     0x000000010324708b dvaui::ui::OS_View::UI_HandlePlatformEvent(NSEvent*) + 59
      27  com.adobe.dvacore.framework   0x0000000102d4ce16 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 38
      28  ...e.AfterEffectsLib.framework 0x0000000100662946 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5382
      29  ...e.AfterEffectsLib.framework 0x0000000100662a71 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 5681
      30  com.adobe.dvacore.framework   0x0000000102d4bcf5 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 197
      31  com.adobe.dvacore.framework   0x0000000102d4dc83 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 99
      32  com.adobe.dvaui.framework     0x000000010324a34d -[DVAMacContainerView mouseDown:] + 253
      33  com.apple.AppKit              0x00007fff836fc5e7 -[NSWindow sendEvent:] + 5068
      34  com.apple.AppKit              0x00007fff836c9ba6 -[NSApplication sendEvent:] + 5087
      35  com.adobe.dvaui.framework     0x0000000103242d6f -[DVAMacApplication sendEvent:] + 223
      36  ...e.AfterEffectsLib.framework 0x0000000100470ac3 0x10046a000 + 27331
      37  com.apple.AppKit              0x00007fff836244be -[NSApplication run] + 499
      38  ...e.AfterEffectsLib.framework 0x00000001006b6a12 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 16386
      39  ...e.AfterEffectsLib.framework 0x0000000100660dcc SetAPETerminateFunc(boost::function<void ()()> const&) + 1308
      40  ...e.AfterEffectsLib.framework 0x0000000100661494 EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 84
      41  com.adobe.AfterEffects        0x00000001000043b8 main + 1144
      42  com.adobe.AfterEffects        0x0000000100003895 _start + 227
      43  com.adobe.AfterEffects        0x00000001000037b1 start + 33
      Thread 1:
      0   libSystem.B.dylib             0x00007fff82f345be __semwait_signal + 10
      1   com.adobe.amt.services        0x000000010c378c53 AMTConditionLock::LockWhenCondition(int) + 37
      2   com.adobe.amt.services        0x000000010c371cce _AMTThreadedPCDService::PCDThreadWorker(_AMTThreadedPCDService*) + 92
      3   com.adobe.amt.services        0x000000010c378cbe AMTThread::Worker(void*) + 28
      4   libSystem.B.dylib             0x00007fff82f5b913 _pthread_start + 316
      5   libSystem.B.dylib             0x00007fff82f5b7d5 thread_start + 13
      Thread 2:
      1   ...ple.CoreServices.CarbonCore 0x00007fff809c7a06 TSWaitOnCondition + 118
      2   ...ple.CoreServices.CarbonCore 0x00007fff809ad24a TSWaitOnConditionTimedRelative + 177
      3   ...ple.CoreServices.CarbonCore 0x00007fff809c76b7 MPWaitOnQueue + 191
      4   ...e.Frameworks.ASL.Foundation 0x0000000104dc2000 ASL::(anonymous namespace)::TaskProc(void*) + 96
      5   ...ple.CoreServices.CarbonCore 0x00007fff809c5fbc PrivateMPEntryPoint + 42
      6   libSystem.B.dylib             0x00007fff82f5b913 _pthread_start + 316
      7   libSystem.B.dylib             0x00007fff82f5b7d5 thread_start + 13
      Thread 3:
      4   AdobeACE                      0x0000000108eb723d 0x108e7d000 + 238141
      5   AdobeACE                      0x0000000108eb6bea 0x108e7d000 + 236522
      6   ...ple.CoreServices.CarbonCore 0x00007fff809c5fbc PrivateMPEntryPoint + 42
      7   libSystem.B.dylib             0x00007fff82f5b913 _pthread_start + 316
      8   libSystem.B.dylib             0x00007fff82f5b7d5 thread_start + 13
      Thread 4:
      Thread 5:
      Thread 6:
      Thread 7:
      Thread 8:
      Thread 9:
      Thread 10:
      1   libGLProgrammability.dylib    0x00007fff818b717b glvmDoWork + 155
      2   libSystem.B.dylib             0x00007fff82f5b913 _pthread_start + 316
      3   libSystem.B.dylib             0x00007fff82f5b7d5 thread_start + 13
      Thread 11:
      4   com.adobe.dvacore.framework   0x0000000102db4a1f dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 143
      5   com.adobe.dvacore.framework   0x0000000102d4dd5e boost::function0<void>::operator()() const + 46
      6   com.adobe.dvacore.framework   0x0000000102dace53 dvacore::threads::(anonymous namespace)::LaunchThread(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
      7   ...obe.boost_threads.framework 0x0000000107f8dac4 thread_proxy + 132
      8   libSystem.B.dylib             0x00007fff82f5b913 _pthread_start + 316
      9   libSystem.B.dylib             0x00007fff82f5b7d5 thread_start + 13
      Thread 12:
      Thread 13:
      Thread 14:
      Thread 15:
      0   libSystem.B.dylib             0x00007fff82f2d656 semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib             0x00007fff82f5c6ce _pthread_cond_wait + 1207
      2   ...ple.CoreServices.CarbonCore 0x00007fff809ad26a TSWaitOnConditionTimedRelative + 209
      Thread 16:
      Thread 17:
      Thread 18:
      Thread 19:
      Thread 20:
      Thread 21:
      Thread 22:
      Thread 23:
      Thread 24:
      Thread 25:
      Thread 26:
      0   libSystem.B.dylib             0x00007fff82f5b18a kevent + 10
      1   ...dobe.dvatransport.framework 0x0000000107ce8d05 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 517
      2   ...dobe.dvatransport.framework 0x0000000107cc68cc SkyConnectionEnv::MainLoop() + 76
      3   ...dobe.dvatransport.framework 0x0000000107cc6939 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
      4   ...obe.boost_threads.framework 0x0000000107f8dac4 thread_proxy + 132
      5   libSystem.B.dylib             0x00007fff82f5b913 _pthread_start + 316
      6   libSystem.B.dylib             0x00007fff82f5b7d5 thread_start + 13
      Thread 27:
      1   ...dobe.dvatransport.framework 0x0000000107ce8e3f boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 831
      2   ...dobe.dvatransport.framework 0x0000000107ce9a35 boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service<boost::asio ::ip::tcp>::work_io_service_runner>::run() + 53
      3   ...dobe.dvatransport.framework 0x0000000107ccec79 asio_detail_posix_thread_function + 25
      Thread 28:
      0   libSystem.B.dylib             0x00007fff82f2d5f6 mach_msg_trap + 10
      1   libSystem.B.dylib             0x00007fff82f34c2f mach_msg + 59
      2   com.apple.CoreFoundation      0x00007fff81e3bc6f CFRunLoopRunSpecific + 1631
      3   com.apple.audio.CoreAudio     0x00007fff81fae576 HALRunLoop::OwnThread(void*) + 142
      4   com.apple.audio.CoreAudio     0x00007fff81fae4b3 CAPThread::Entry(CAPThread*) + 67
      Thread 29:
      Thread 30:
      Thread 31:
      Thread 32:
      2   com.apple.audio.CoreAudio     0x00007fff81fb7eb2 CAGuard::WaitFor(unsigned long long) + 164
      3   com.apple.audio.CoreAudio     0x00007fff81fb9073 CAGuard::WaitUntil(unsigned long long) + 53
      4   com.apple.audio.CoreAudio     0x00007fff81fb8195 HP_IOThread::WorkLoop() + 645
      5   com.apple.audio.CoreAudio     0x00007fff81fb7f0b HP_IOThread::ThreadEntry(HP_IOThread*) + 9
      6   com.apple.audio.CoreAudio     0x00007fff81fae4b3 CAPThread::Entry(CAPThread*) + 67
      Thread 33:
      1   com.adobe.AfterEffects.MThread 0x000000012608ca8f main + 20783
      2   com.adobe.dvacore.framework   0x0000000102d4dd5e boost::function0<void>::operator()() const + 46
      3   com.adobe.dvacore.framework   0x0000000102dace53 dvacore::threads::(anonymous namespace)::LaunchThread(std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 99
      Thread 34:
      Thread 35:
      Thread 36:
      Thread 37:
      Thread 38:
      Thread 39:
      Thread 40:
      Thread 41:
      Thread 42:
      1   com.adobe.AfterEffects.OpenEXR 0x0000000127deb4c6 IlmThread::Semaphore::wait() + 70
      2   com.adobe.AfterEffects.OpenEXR 0x0000000127dea33c IlmThread::(anonymous namespace)::WorkerThread::run() + 188
      3   libSystem.B.dylib             0x00007fff82f5b913 _pthread_start + 316
      4   libSystem.B.dylib             0x00007fff82f5b7d5 thread_start + 13
      Thread 43:
      Thread 44:
      Thread 45:
      Thread 46:
      Thread 47:
      Thread 48:
      Thread 49:
      Thread 50:
      1   ...dobe.AfterEffects.Scripting 0x0000000128b18fbb zcfree + 197989
      2   ...dobe.AfterEffects.Scripting 0x0000000128afbfd3 zcfree + 79229
      3   ...dobe.AfterEffects.Scripting 0x0000000128b190b6 zcfree + 198240
      Thread 51:
      1   com.adobe.adobeswfl           0x00000001293e904d APXGetHostAPI + 2430509
      2   com.adobe.adobeswfl           0x00000001291aaa39 APXGetHostAPI + 77849
      3   com.adobe.adobeswfl           0x00000001293e9161 APXGetHostAPI + 2430785
      4   com.adobe.adobeswfl           0x00000001293e92ba APXGetHostAPI + 2431130
      5   com.adobe.adobeswfl           0x00000001293e93b0 APXGetHostAPI + 2431376
      Thread 52:
      Thread 53:
      Thread 54:
      Thread 55:
      Thread 56:
      Thread 57:
      Thread 58:
      Thread 59:
      1   libSystem.B.dylib             0x00007fff82f5b913 _pthread_start + 316
      2   libSystem.B.dylib             0x00007fff82f5b7d5 thread_start + 13
      Thread 60:
      3   com.apple.CoreFoundation      0x00007fff81e3c666 CFRunLoopRun + 54
      4   com.apple.QTKit               0x00007fff8025ea10 listenOnDelegatePort + 285
      Thread 61:
      4   com.apple.QTKit               0x00007fff8024ba63 listenOnNotificationPort + 243
      Thread 62:
      2   com.adobe.adobeswfl           0x00000001293e9019 APXGetHostAPI + 2430457
      3   com.adobe.adobeswfl           0x000000012957e943 APXGetHostAPI + 4091683
      4   com.adobe.adobeswfl           0x00000001293e9161 APXGetHostAPI + 2430785
      5   com.adobe.adobeswfl           0x00000001293e92ba APXGetHostAPI + 2431130
      6   com.adobe.adobeswfl           0x00000001293e93b0 APXGetHostAPI + 2431376
      Thread 63:
      3   com.adobe.adobeswfl           0x000000012940595c APXGetHostAPI + 2547516
      Thread 64:
      0   libSystem.B.dylib             0x00007fff82f795c6 select$DARWIN_EXTSN + 10
      Thread 65:
      1   libtbb.dylib                  0x000000010001222c tbb::internal::GenericScheduler::wait_while_pool_is_empty() + 92
      2   libtbb.dylib                  0x000000010001cb84 tbb::internal::CustomScheduler<tbb::internal::IntelSchedulerTraits>::wait_for_all(tbb::ta sk&, tbb::task*) + 1858
      3   libtbb.dylib                  0x0000000100014e3a tbb::internal::GenericScheduler::worker_routine(void*) + 632
      Thread 66:
      Thread 67:
      Thread 68:
      Thread 69:
      Thread 70:
      Thread 71:
      Thread 72:
      4   com.apple.DesktopServices     0x00007fff816706df TSystemNotificationTask::SystemNotificationTaskProc(void*) + 109
      Thread 73:
      4   com.apple.DesktopServices     0x00007fff816707e8 TFSEventsNotificationTask::FSEventsNotificationTaskProc(void*) + 162
      Thread 74:
      4   com.apple.DesktopServices     0x00007fff81678215 TNodeSyncTask::SyncTaskProc(void*) + 67
      Thread 75:
      Thread 76:
      2   com.apple.Foundation          0x00007fff83386464 -[NSCondition waitUntilDate:] + 228
      3   com.apple.Foundation          0x00007fff83386292 -[NSConditionLock lockWhenCondition:beforeDate:] + 130
      4   com.apple.AppKit              0x00007fff83692ced -[NSUIHeartBeat _heartBeatThread:] + 417
      5   com.apple.Foundation          0x00007fff833430a5 __NSThread__main__ + 1157
      Thread 77:
      3   ...ple.CoreServices.CarbonCore 0x00007fff809ad07b TSWaitOnSemaphoreCommon + 362
      4   ...ple.CoreServices.CarbonCore 0x00007fff809acdc1 AsyncFileThread(void*) + 47
      Thread 78:
      4   com.apple.DesktopServices     0x00007fff81679bb1 TFolderSizeTask::FolderSizeTaskProc(void*) + 83
      Thread 0 crashed with X86 Thread State (64-bit):
        rax: 0x0000000000000000  rbx: 0x00007fff5fbfdc00  rcx: 0x00007fff5fbfdbd8  rdx: 0x0000000000000000
        rdi: 0x00000000000000f3  rsi: 0x0000000000000006  rbp: 0x00007fff5fbfdbf0  rsp: 0x00007fff5fbfdbd8
         r8: 0x0000000102a95768   r9: 0x000000010c0f4538  r10: 0x00007fff82f6ce06  r11: 0x0000000000000202
        r12: 0x00007fff5fbfdc10  r13: 0x000000000e1d2da4  r14: 0x00007fff5fbfe1c0  r15: 0x0000000000000000
        rip: 0x00007fff82f94dd6  rfl: 0x0000000000000202  cr2: 0x0000000124756000
      Binary Images:
             0x100000000 -        0x100004ff3 +com.adobe.AfterEffects 10.0 (10.0) <b62ce36e00b740dcaf979e7b36eefa6e> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/MacOS/After Effects
             0x100009000 -        0x100022feb +libtbb.dylib ??? (???) /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libtbb.dylib
             0x100033000 -        0x100039feb +libtbbmalloc.dylib ??? (???) /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libtbbmalloc.dylib
             0x100040000 -        0x10004cff5 +com.adobe.boost_signals.framework boost_signals version 5.0.0 (5.0.0.213330) <b3758c2193f69d51627e048eab1f910c> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
             0x10005e000 -        0x10005ffff +com.adobe.boost_system.framework boost_system version 5.0.0 (5.0.0.213330) <82b9a0e966bd2de0e5b83388b845a8b0> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
             0x100065000 -        0x10006cff3 +com.adobe.boost_date_time.framework boost_date_time version 5.0.0 (5.0.0.213330) <3a6f274113e1dbb5bd25b3e2cb12c76a> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
             0x10007c000 -        0x100081ffd +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <dffb9a088369d65f161f7c61d562e307> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
             0x100086000 -        0x1001c9fef +WRServices ??? (???) <dd50d315c0ecc729ac6792588187e8c7> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
             0x100215000 -        0x100319fef +hydra_filters ??? (???) <1ad09f41c78b916522c147f60212929c> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/hydra_filters.framework/Versions/A/hydra_filters
             0x10040e000 -        0x10042cfff +image_runtime ??? (???) <5342d96998cb14eefa4c2252baca7ee3> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
             0x100466000 -        0x100467fff +ALOG.dylib ??? (???) <4b83a1e344342ff3bf5b058071b8fd11> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ALOG.dylib
             0x10046a000 -        0x100e3dfef +com.adobe.AfterEffectsLib.framework AfterFXLib 1.0 (1.0) <4f38252d52251f2fab2d87e378c374b5> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLib
             0x101196000 -        0x101196ff7 +AEFX.dylib ??? (???) <968dd1f9d9538d567f8e642c726d2074> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AEFX.dylib
             0x101199000 -        0x101554fe7 +BEE.dylib ??? (???) <535f8287be3de4aed3e1aa42556db8aa> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEE.dylib
             0x10179d000 -        0x1017acff3 +BEZ.dylib ??? (???) <238c2ec9975eaf5fdf9ff461cecf923a> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BEZ.dylib
             0x1017b0000 -        0x1017bbff3 +BM.dylib ??? (???) <11fd882ba0b3e8b8c9cac7032ca77ac9> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/BM.dylib
             0x1017c2000 -        0x1017fdfff +COR.dylib ??? (???) <c8ecfb666a1a23477e3c8435c453d054> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/COR.dylib
             0x101819000 -        0x101839ff7 +FILE.dylib ??? (???) <85dddb0244193ca927274c8108c9c5d9> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FILE.dylib
             0x101847000 -        0x101874fff +FLO.dylib ??? (???) <973923da95576dc79e00d68f02975bc3> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLO.dylib
             0x10187a000 -        0x10193dfff +FLT.dylib ??? (???) <f5dfa74595fd5cbdcbc692a83efb1f54> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FLT.dylib
             0x1019a0000 -        0x1019a7ff3 +LIST.dylib ??? (???) <6ee40de3ccb75f5ac6cf3e241f97d625> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/LIST.dylib
             0x1019ab000 -        0x1019befff +M.dylib ??? (???) <ed7686ca1d7906e92410f341b614ef7c> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/M.dylib
             0x1019c3000 -        0x1019ccff7 +MC.dylib ??? (???) <84b8d9f917f6dbf4e9c4b8955d37ece2> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MC.dylib
             0x1019d3000 -        0x101a33fff +MSK.dylib ??? (???) <ae2db0dab97a41bdd708bbc62c667e3a> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MSK.dylib
             0x101a47000 -        0x101a5eff7 +OM.dylib ??? (???) <eb18bea8da5d4e14bd54c23e7b576014> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/OM.dylib
             0x101a66000 -        0x101a88ff7 +P.dylib ??? (???) <d8239475f2d02445c857773e1d92b040> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/P.dylib
             0x101a91000 -        0x101ddafff +PF.dylib ??? (???) <b321b8497071dca6878fbb885d6c4d66> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PF.dylib
             0x101e16000 -        0x10201ffff +PIN.dylib ??? (???) <dee97322eb9f8d8c48205adcd5a426d0> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PIN.dylib
             0x1020a0000 -        0x1020bafff +PLUG.dylib ??? (???) <f1b84fa7f1c0d8d20027f398154e7f45> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PLUG.dylib
             0x1020c5000 -        0x1020d8fff +PR.dylib ??? (???) <3e762a5ff8f714301b0537573c94a87c> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PR.dylib
             0x1020df000 -        0x1020e5fff +PREF.dylib ??? (???) <6baf11d362c5c8fda7fe29ec7b7f295f> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREF.dylib
             0x1020e9000 -        0x102101fff +RG.dylib ??? (???) <b5c33d6fb14c1d0a2d2bf36e53f8acce> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RG.dylib
             0x10210a000 -        0x10210cff7 +RI.dylib ??? (???) <e160ab31e857f4e259f629ad71e58caf> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RI.dylib
             0x10210f000 -        0x102110fff +RND.dylib ??? (???) <15050d6c4bc4e00667d8e3799a1a77fe> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/RND.dylib
             0x102117000 -        0x102176ff7 +SLU.dylib ??? (???) <0fde187743f41c286537725004cfa0b5> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SLU.dylib
             0x10219c000 -        0x1021b8ffd +SND.dylib ??? (???) <08cda7d2ab193b47cc30675fb9c19f1b> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SND.dylib
             0x1021c0000 -        0x1021c3ff1 +STR.dylib ??? (???) <404df8fcf56ed1fb69dae62cb2eaad2d> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/STR.dylib
             0x1021c7000 -        0x1021cafff +T.dylib ??? (???) <f139d7d3196278fa13414475161f59df> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/T.dylib
             0x1021cd000 -        0x10220aff5 +TDB.dylib ??? (???) <63379742f5086083303853ba87a9bae5> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TDB.dylib
             0x10221e000 -        0x1028c9fe5 +TXT.dylib ??? (???) <8d482b4028ce1fb77a6cff8463790ac6> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/TXT.dylib
             0x102a68000 -        0x102aa4ff1 +U.dylib ??? (???) <c07391c6a4f7a5834af9b9c19171f45a> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/U.dylib
             0x102ab8000 -        0x102abcfff +VAL.dylib ??? (???) <dbb9a3a1f0f314e8c8270bbdec116e99> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VAL.dylib
             0x102abf000 -        0x102b6ffff +com.adobe.exo.framework exo version 5.0.0 (5.0.0.213330) <cd3b7889351caa1369af27a7aa2df2f4> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/exo.framework/Versions/A/exo
             0x102c76000 -        0x102c9cffb +PREM.dylib ??? (???) <9909304126a0051d9074dea7b00b923b> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PREM.dylib
             0x102cb0000 -        0x102d09fff +FRP.dylib ??? (???) <afbc28aac1bc04a7da6529a933da4db4> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/FRP.dylib
             0x102d26000 -        0x102e84ff7 +com.adobe.dvacore.framework dvacore version 5.0.0 (5.0.0.213330) <256df8849ec1771e6e847bb625046278> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
             0x102ff8000 -        0x10333fff7 +com.adobe.dvaui.framework dvaui version 5.0.0 (5.0.0.213330) <8599321bee71853eec77b4a63ff400c9> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
             0x103701000 -        0x1037affff +com.adobe.dvaworkspace.framework dvaworkspace version 5.0.0 (5.0.0.213330) <ff18da570b63fdf9f90963af774d945a> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
             0x10388b000 -        0x1038abfef +com.adobe.dvaunittesting.framework dvaunittesting version 5.0.0 (5.0.0.213330) <268d30fcbf514fda8854770e8295d2a1> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
             0x1038d4000 -        0x1038e4ff8 +com.adobe.ahclientframework 1.5.0.30 (1.5.0.30) <5d6ffc4e7b813e8cf0d466a3fa94a837> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
             0x1038ef000 -        0x103967fef +com.adobe.adobe_caps adobe_caps 3.0.116.0 (3.0.116.0) <4a3556861451b19a0c55dfe49fd2539e> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
             0x10397d000 -        0x1039e2fff +aif_core ??? (???) <4e7adc1a0d15727f9b791c74a8763fd8> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
             0x103a24000 -        0x103c53fff +aif_ogl ??? (???) <c97013b9c1e5ee50f9248ed11043b282> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
             0x103e17000 -        0x103e2dfff +data_flow ??? (???) <c0e0afa68d2393fbe5d78a2b49d2c268> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
             0x103e60000 -        0x104355fef +image_compiler ??? (???) <c1061733616914e937e67484293bea8b> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_compiler.framework/Versions/A/image_compiler
             0x104895000 -        0x10492bfff +image_flow ??? (???) <3fbf0b872177f53cc3f311d51a45239d> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
             0x104a11000 -        0x104a50ff7 +com.adobe.dynamiclinkui.framework dynamiclinkui version 5.0.0 (5.0.0.213330) <0e169d799960bcafd85b103665e5678b> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
             0x104aa6000 -        0x104c6ffff +com.adobe.dynamiclink.framework dynamiclink version 5.0.0 (5.0.0.213330) <8570780962364e00285a580da81d0094> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
             0x104d8d000 -        0x104defff5 +com.adobe.MediaCore.Frameworks.ASL.Foundation 1.0 (1.0) <bac830acf3f4037a60307773fa47076e> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
             0x104ed6000 -        0x104eecfff +ASLMessaging ??? (???) <3e58548816d5e499e08909c7aa3c1e04> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
             0x104f0b000 -        0x104f1cffe +ASLUnitTesting ??? (???) <6a743b2367b83bbae5b9e6a255bb40c0> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
             0x104f34000 -        0x104f4eff3 +com.adobe.MediaCore.Frameworks.AudioFilterHost 1.0 (1.0) <88358d58d8f98df88e196ab807d63674> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
             0x104f76000 -        0x104faefff +com.adobe.MediaCore.Frameworks.AudioFilters ??? (1.0) <a84b6b9ccc01c65dfdbd413358a34863> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
             0x105019000 -        0x105091fe3 +com.adobe.MediaCore.Frameworks.AudioRenderer ??? (1.0) <c561a37c8c80c731f2d608f48aafe579> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
             0x10512c000 -        0x10516afe1 +com.adobe.MediaCore.Frameworks.AudioSupport 1.0 (1.0) <9f36fd9d3708bfdece6cd035561137f7> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
             0x1051b3000 -        0x105bfffff +com.adobe.MediaCore.Frameworks.Backend ??? (1.0) <f6e47c9730b84ef6115606dba45672a9> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
             0x106915000 -        0x106ab7ff3 +com.adobe.MediaCore.Frameworks.ImageRenderer ??? (1.0) <32230b4b6e75463194c075dee05314d8> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
             0x106be7000 -        0x106d6dff7 +com.adobe.MediaCore.Frameworks.ImporterHost 1.0 (1.0) <2dea855acbe89c636ef772d528776b0f> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
             0x106f2d000 -        0x106f61fff +com.adobe.MediaFoundation ??? (1.0) <78b9fe2686c1b44fbb81ba21428022fe> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
             0x106fa4000 -        0x106fa7fff +com.adobe.MediaCore.Frameworks.MediaUtils 1.0 (1.0) <4f4a65502ba7fa8117c4023452073551> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
             0x106fac000 -        0x106fadfff +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0) <6d281021c4ad0f62e78486e6c745aa6d> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
             0x106fb2000 -        0x106febfff +com.adobe.MediaCore.Frameworks.MLFoundation 1.0 (1.0) <1cee4dab7ad16fc5c001a7aaecf05c7b> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
             0x107039000 -        0x10706afff +com.adobe.MediaCore.Frameworks.PluginSupport 1.0 (1.0) <55244e51a1bca2e784ec7f8829d94a0c> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
             0x1070a9000 -        0x1070aafff +PRM ??? (???) <285f42c65d9016f95650377d71a935c6> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
             0x1070ae000 -        0x1070e6fff +com.adobe.MediaCore.Frameworks.SweetPeaSupport 1.0 (1.0) <70ad1ed5a18983d89b39bac35cb614ad> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
             0x107137000 -        0x10717ffff +com.adobe.MediaCore.VideoFrame 1.0 (1.0) <cb52e22bbdc59ce2392ba673da8253b6> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
             0x1071cc000 -        0x1072e6fff +com.adobe.MediaCore.Frameworks.VideoRenderer 1.0 (1.0) <f5072641ca96efefd30d8a643021d71c> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
             0x107450000 -        0x1074f8fe1 +com.adobe.dvaeve.framework dvaeve version 5.0.0 (5.0.0.213330) <03600aa1484d17967dd1c0ba492d14e5> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
             0x1075f5000 -        0x107668ff7 +com.adobe.MediaCore.Frameworks.PlayerHost 1.0 (1.0) <9d9cc1493b1fa889334d9b2bc90212e2> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
             0x107703000 -        0x1077d5fff +com.adobe.MediaCore.Frameworks.VideoFilterHost 1.0 (1.0) <00a438bcac9f70573da4432095ad518b> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
             0x107898000 -        0x107902ff7 +com.adobe.amtlib amtlib 3.0.0.64 (3.0.0.64) <6b2f73c210ab08b34ab0a31c83d1e5e0> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
             0x107935000 -        0x1079d3ff2 +libicucnv.dylib.36.0 ??? (???) <5651fb7c24ed8cc82adea5cb7ca493c3> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
             0x1079f3000 -        0x107a0efff +libicudata.dylib.36.0 ??? (???) <fef83a1c8d4866b4bed6b91835d1aa68> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
             0x107a11000 -        0x107a6bfff +com.adobe.dvametadata.framework dvametadata version 5.0.0 (5.0.0.213330) <2e79abd7fdfab909763564d2b984c8bd> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
             0x107aed000 -        0x107b71fff +com.adobe.dvametadataUI.framework dvametadataUI version 5.0.0 (5.0.0.213330) <91d6b7f4a9650036bd98de8bf3cfb30c> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
             0x107c08000 -        0x107c4cff7 +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 5.0.0 (5.0.0.213330) <5165b4d55ad0f8465586235ddf01078d> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
             0x107c6c000 -        0x107c85fff +com.adobe.dvamediatypes.framework dvamediatypes version 5.0.0 (5.0.0.213330) <dc398f5193e0db114a2b8ea4c1cae7cc> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
             0x107ca4000 -        0x107d1aff7 +com.adobe.dvatransport.framework dvatransport version 5.0.0 (5.0.0.213330) <4f4db4f1fbd8e7748c33830b243c4ba3> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
             0x107d9d000 -        0x107dd9ff3 +com.adobe.dvamarshal.framework dvamarshal version 5.0.0 (5.0.0.213330) <eef373f8ab3b609f6a9d832b4132dc90> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
             0x107e45000 -        0x107e53fff +com.adobe.MediaCore.Frameworks.ProjectSupport 1.0 (1.0) <603af6ee8b986e0fbfb91b48594ee6b4> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
             0x107e67000 -        0x107eaafff +DynamicLinkMedia ??? (???) <0353ada382a5e93442a03a983a7285ef> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
             0x107f17000 -        0x107f17ffd  libmx.A.dylib ??? (???) /usr/lib/libmx.A.dylib
             0x107f1b000 -        0x107f46ff6 +AdobeAXE8SharedExpat ??? (???) <f5c1010bcaff52908b556feb3a287225> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
             0x107f58000 -        0x107f5efef  com.apple.agl 3.0.9 (AGL-3.0.9) <04cded56410b21d5c30843fd34935384> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
             0x107f64000 -        0x107f81fff +AdobeBIB ??? (???) <2f1ce9f90d9a3914c0fee20cc5f1f9f7> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
             0x107f8b000 -        0x107f93ff3 +com.adobe.boost_threads.framework boost_threads version 5.0.0 (5.0.0.213330) <34ee0ebb3b3cb83897df637b4bba82d8> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
             0x107fa2000 -        0x107ff8feb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.011) <03b806982c3ba232f15f8f08f8963a19> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
             0x10803d000 -        0x1080fbffb +filter_graph ??? (???) <869193626eb75faa20bf490ff5d14215> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/filter_graph.framework/Versions/A/filter_graph
             0x108223000 -        0x108281ffd +AdobeXMP ??? (???) <29839f014a215b72ff9ae030d214f5e2> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
             0x10828f000 -        0x10831bfe3 +AdobeXMPFiles ??? (???) <c4531436ca4f8a060481cd1648c20c48> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
             0x108353000 -        0x1083f3fef +com.adobe.AdobeScCore ScCore 4.1.23 (4.1.23.7519) <92f5eb27ed64ca9162f119d29caafc56> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
             0x108439000 -        0x1084ddffb +com.adobe.AdobeExtendScript ExtendScript 4.1.23 (4.1.23.7519) <783ea0cd8a214568a4ce046ac65ebfff> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
             0x10853f000 -        0x10861dfef +AdobeAXEDOMCore ??? (???) <8d4592b85da1d957b1bafb20116514dd> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
             0x108695000 -        0x1089c6fe7 +AdobeCoolType ??? (???) <cb25f6ca6cf394e8918c51a54936c0f4> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
             0x108a62000 -        0x108dabfe7 +AdobeAGM ??? (???) <beeaac1bcc8f1a91c0a203be0343a313> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
             0x108e7d000 -        0x108f91fff +AdobeACE ??? (???) <d04af21ce216d514b310ad865e7c3aa1> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
             0x108fb6000 -        0x108fd7fff +AdobeBIBUtils ??? (???) <e04c88f80fbf8e68c0c2b34cd69bd330> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
             0x108fe4000 -        0x1090b7ffb +AdobeJP2K ??? (???) <8571d9ba44f992a304445ffac2994b88> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
             0x1090d7000 -        0x109118ff7 +AdobeARE ??? (???) <44af62deec7a76f732a81106926b47bd> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
             0x109122000 -        0x10977afef +AdobePDFL ??? (???) <45aa748310a62dab1ff862c9e615039e> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
             0x1098c9000 -        0x109ddafff +AdobeMPS ??? (???) <10c4e97945f3a7c60438262ce5f595b9> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
             0x109eb0000 -        0x109edbfef +AdobeAXE16SharedExpat ??? (???) <f5e56d3bae0e245ce706dfa630d6771c> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedEx pat
             0x109eed000 -        0x10acb0fff +com.adobe.psl AdobePSL 12.0.0.7667 (12.0.0.7667) <f1c9409d033e58d0b9026422bc488aa5> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
             0x10b020000 -        0x10b0cbfeb +com.adobe.MediaCore.Frameworks.ExporterHost 1.0 (1.0) <5e91f6c85afad4cfd96102e210f4074e> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
             0x10b1df000 -        0x10b1fffeb +SegMatServices.dylib ??? (???) <2a93ef53075b328a5830caed59925af4> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SegMatServices.dylib
             0x10b20c000 -        0x10b20cff7 +SAM.dylib ??? (???) <bcf43d01c6a4f35e15188dfefcf7094d> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SAM.dylib
             0x10b20f000 -        0x10b232fef  com.apple.QuickLookFramework 1.1 (170.4) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
             0x10b248000 -        0x10b520fe6 +libxerces-c-3.0.dylib ??? (???) <46020284eea87d7b388cbf23a318c997> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/libxerces-c-3.0.dylib
             0x10b69a000 -        0x10b6caffb  libcurl.4.dylib ??? (???) <276acb990f3a40bbae7aaa39c0ae6305> /usr/lib/libcurl.4.dylib
             0x10b6d5000 -        0x10b700fef  libssl.0.9.7.dylib ??? (???) <088aa0e89525fbb374d9985ba9d37178> /usr/lib/libssl.0.9.7.dylib
             0x10b710000 -        0x10b726ff6 +com.adobe.AMEAppFoundation.framework ??? (1.0) <07b45ffc9e851348baa4944ec05dd0d7> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
             0x10b747000 -        0x10b76aff1 +com.adobe.PostEncodeHost.framework ??? (1.0) <fdf0e7430db9e7dfbe0522bfe397db56> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
             0x10b798000 -        0x10b854ff7 +AMEWrapper ??? (???) <e735459dfb6c284ce7aeea493e521221> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
             0x10b913000 -        0x10ba1afff +com.adobe.EncoderHost.framework ??? (1.0) <fbaaf460e4d21374f4531a9c98e38207> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
             0x10bb1f000 -        0x10bcecfff +com.adobe.SettingsUI.framework ??? (1.0) <d87f738506e0e6f17c295f20e2a6f9d0> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
             0x10bf49000 -        0x10bfa7ff7 +com.adobe.MediaCore.Frameworks.Utilities.QT32Client 1.0 (1.0) <6c9fa948d19a382d1a3d6ac921e4272a> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
             0x10c015000 -        0x10c040fff  com.apple.carbonframeworktemplate 1.0 (1.0) <377c4816226e3d48afdaa40178588b15> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
             0x10c07a000 -        0x10c0a3fff +ameproperties ??? (???) <538dd95d86a83d74a23106f1584a954b> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
             0x10c0e6000 -        0x10c0eaff2 +com.adobe.AppServices.framework ??? (1.0) <859af026319b2120c6ef422964eff52c> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServices
             0x10c23b000 -        0x10c23dfe1  com.apple.textencoding.unicode 2.2 (2.2) <def28c6ac112b562d2edeee92ac8bb84> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
             0x10c355000 -        0x10c3c5ff6 +com.adobe.amt.services AMTServices 3.0.0.64 (BuildVersion: 3.0; BuildDate: Mon Jan 26 2010 21:49:00) (3.0.0.64) <52ff1f9b9991ece2c7e309da1b368cbe> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
             0x10c6c8000 -        0x10c6d0fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <3d59cb21f5c74232ab00dfeb04206024> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
             0x11f0ec000 -        0x11f1f7fef  com.apple.RawCamera.bundle 2.0.7 (2.0.7) /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
             0x11f6b9000 -        0x11f6bafff  ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
             0x11f742000 -        0x11f74ffff  com.apple.URLMount 3.1.1 (3.1.1) <f4b4ce3af4cca0e4d7fc94c763083091> /System/Library/PrivateFrameworks/URLMount.framework/URLMount
             0x11f94e000 -        0x11f94fff7 +com.adobe.AfterEffects.Paint ??? (???) <8c07b2f54b17f5c1c4aeb0394226eee2> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paint.plugin/Contents/MacOS/Paint
             0x11fa44000 -        0x11fa49fff  libCGXCoreImage.A.dylib ??? (???) <184e83783f80c75b351aa79df7a62185> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
             0x11ff67000 -        0x11ff7efef  libJapaneseConverter.dylib ??? (???) <760a1e46df8e2df13d148921acf25630> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
             0x120552000 -        0x120552ffe  com.apple.quartzframework 1.5 (1.5) <3387d0eccdccac3a1dcf110bb77880c9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
             0x1207a4000 -        0x120941fe3  GLEngine ??? (???) <30b5e682b460b975a157905e6dfb6109> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
             0x12096f000 -        0x120bcefe5  com.apple.ATIRadeonX2000GLDriver 1.5.28 (5.2.8) <75a447d1bbcda247d5ef23965f5e4126> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLD river
             0x120c2c000 -        0x120c4bfff  GLRendererFloat ??? (???) <9424dd3be60dbca672684cbac4600020> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/G LRendererFloat
             0x1253ee000 -        0x125418ff1 +com.mainconcept.mc_dec_dv 8.5 (8.5.0.14572) <cff0820db6c10db843de35169748fd94> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_dec_dv.framework/mc_dec_dv
             0x125431000 -        0x125458ff1 +com.mainconcept.mc_enc_dv 8.5 (8.5.0.14572) <46ab84046892f7bf150ed8249ecfd0b8> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
             0x12568d000 -        0x125691fff  com.apple.audio.AudioIPCPlugIn 1.0.4 (1.0.4) <599bd571fe66da4d5d8c5c383b8e0bb9> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
             0x125696000 -        0x12569bfff  com.apple.audio.AppleHDAHALPlugIn 1.5.7 (1.5.7a24) /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
             0x125749000 -        0x12574efff +com.adobe.MediaCore.ExporterCoreAudio 1.0 (1.0) <67df0ef9b52649abfbf1a1a4dfe25ed4> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ExporterCoreAudio.bundle/Contents/MacOS/ExporterCor eAudio
             0x125755000 -        0x125764fe7 +com.adobe.MediaCore.Frameworks.AudioConverter 1.0 (1.0) <9df434df0cb3ff7bb9885eed3ca04bab> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/AudioConverter.framework/Versions/A/AudioConverter
             0x125900000 -        0x125aacffb  com.apple.audio.codecs.Components 1.6.3 (1.6.3) /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
             0x125adf000 -        0x125b05ff3 +com.adobe.MediaCore.ExporterQuickTimeHost 1.0 (1.0) <f53cb51e93015881113e72b7543661d9> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ExporterQuickTimeHost.bundle/Contents/MacOS/Exporte rQuickTimeHost
             0x125cbe000 -        0x125cf4fff +com.adobe.MediaCore.ImporterQuickTime 1.0 (1.0) <98b3f385b34eab840944316ff3edf68d> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterQuickTime.bundle/Contents/MacOS/ImporterQui ckTime
             0x125d28000 -        0x125d3ffff +com.adobe.MediaCore.Frameworks.QTParser 1.0 (1.0) <493eaf2c16216d9e0b64f4be9dda694e> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
             0x125d53000 -        0x125d69ff7 +com.red.ImporterRED 1.01 (1.0) <3282fa198a94defd8bf6eea9132de447> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterRED.bundle/Contents/MacOS/ImporterRED
             0x126082000 -        0x12608efff +com.adobe.AfterEffects.MThread ??? (???) <d15114661d57532cc82e69a13a2bd6d9> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Extensions/Mthread.plugin/Contents/MacOS/MThread
             0x1260b8000 -        0x1260cefe7 +com.adobe.AfterEffects.PS3Export ??? (???) <b5e53b3b3f9727353e20a140ebc71960> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Format/PS Layer Export.plugin/Contents/MacOS/PS3Export
             0x1260da000 -        0x1260defff +com.adobe.AfterEffects.EasyEase ??? (???) <c9455ffca444b363d387620c3314bdf0> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/EasyEase.plugin/Contents/MacOS/EasyEase
             0x1260e1000 -        0x1260e5ff7 +com.adobe.AfterEffects.ExpScale ??? (???) <060aabf0117b6c9b6deb893396d31c33> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/ExpScale.plugin/Contents/MacOS/ExpScale
             0x1260e8000 -        0x1260eeff7 +com.adobe.AfterEffects.Sequence ??? (???) <f316a4574d533f1323c5eb09ae43c971> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/Sequence.plugin/Contents/MacOS/Sequence
             0x1260f3000 -        0x1260f7fff +com.adobe.AfterEffects.TRKeys ??? (???) <44353a63f5bab648204dd3f3581e2e58> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/TRKeys.plugin/Contents/MacOS/TRKeys
             0x1260fa000 -        0x1260fdff7 +com.adobe.AfterEffects.Durer ??? (???) <65299d99e8915dcda5d03e9de237ff7b> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Standard3D.plugin/Contents/MacOS/Durer
             0x126595000 -        0x126616fff +com.adobe.AfterEffects.AEGPDriver ??? (???) <2d2af512181be93122cf112b5ae2973c> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/AEGPDriver.plugin/Contents/MacOS/AEGPDriver
             0x12664e000 -        0x126670ff3 +com.adobe.AfterEffects.PS3Import ??? (???) <7fdd1a1fe72e597a53662af4fbc29ec4> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Format/PS Layer Import.plugin/Contents/MacOS/PS3Import
             0x126681000 -        0x1266f7fff +com.adobe.AfterEffects.Escher ??? (???) <e19fed0bfd678e9d4f68067bb310e6f7> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Advanced3D.plugin/Contents/MacOS/Escher
             0x126704000 -        0x126782ff3 +com.adobe.AfterEffects.AEDynamicLinkServer ??? (???) <fda9eaf41fc7f670d61f38e2b44b3d25> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/AEDynamicLinkServer.plugin/Contents/MacOS/AEDynamicLinkServer
             0x1268c9000 -        0x1268e6fff +com.adobe.AfterEffects.AudioPal ??? (???) <b2ec3e6b42af11bfa0cdfca84b4a31e8> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Audio Palette.plugin/Contents/MacOS/AudioPal
             0x1268f8000 -        0x126927ffb +com.adobe.AfterEffects.BrushPal ??? (???) <aa683ee732c066c5414ce2e7b9cc021e> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Brush Palette.plugin/Contents/MacOS/BrushPal
             0x12693f000 -        0x12697fff7 +com.adobe.AfterEffects.CharPal ??? (???) <25bbab42542ac8a9626d3bc60d4727d6> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Character Palette.plugin/Contents/MacOS/CharPal
             0x1269a0000 -        0x1269c2fff +com.adobe.AfterEffects.InfoPal ??? (???) <e301706b7062c4cb0f6742675992bb5d> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Info Palette.plugin/Contents/MacOS/InfoPal
             0x1269d6000 -        0x126a02ffb +com.adobe.AfterEffects.PaintPal ??? (???) <7cb211af3ed49da0a7c64f083f1ede14> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paint Palette.plugin/Contents/MacOS/PaintPal
             0x126a1a000 -        0x126a3bff7 +com.adobe.AfterEffects.ParaPal ??? (???) <4adba656e5b9527a4f245e77032e1bc3> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Paragraph Palette.plugin/Contents/MacOS/ParaPal
             0x126a4f000 -        0x126be6fff +com.adobe.AfterEffects.SnapCut ??? (???) <649b6cb7e3ad316f94267ca65cf289bf> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Roto Brush.plugin/Contents/MacOS/SnapCut
             0x126c15000 -        0x126c37fff +com.adobe.AfterEffects.TimePal ??? (???) <5c49cb19ec498dd4b742c817ebb9f2af> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Time Palette.plugin/Contents/MacOS/TimePal
             0x126c4d000 -        0x126c90fff +com.adobe.AfterEffects.ToolPal ??? (???) <44504f8dafd6c9bcf491299b17d92b41> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Tool Palette.plugin/Contents/MacOS/ToolPal
             0x126cb6000 -        0x126cd6ffb +com.adobe.AfterEffects.TrackerPal ??? (???) <c1a622394f43c20e900db6fb2abff195> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Tracker Palette.plugin/Contents/MacOS/TrackerPal
             0x126ce8000 -        0x127abaff7 +com.ImagineerSystems.mochashapeconverter4ae 1 (1.0.0) <3c1f5d08d5159e2435edcc76fcca9675> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/Imagineer/mocha shape converter for AE.plugin/Contents/MacOS/mochashapeconverter4ae
             0x127c97000 -        0x127cfdfff +com.adobe.AfterEffects.AE_OpenGL ??? (???) <115a01df0ff9b6863c0367c7c8bf05ca> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Extensions/AE_OpenGL.plugin/Contents/MacOS/AE_OpenGL
             0x127d11000 -        0x127d1dff7 +com.adobe.AfterEffects.LocalizePresets ??? (???) <6a10f872ecd90bcc618975010d491050> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Extensions/LocalizePresets.plugin/Contents/MacOS/LocalizePresets
             0x127d2c000 -        0x127daeff3 +com.adobe.AfterEffects.FlashExporter ??? (???) <762a17c7f9e6db9f3dd40e94cdb459e6> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Format/FlashExporter.plugin/Contents/MacOS/FlashExporter
             0x127ddb000 -        0x127f2cfeb +com.adobe.AfterEffects.OpenEXR ??? (???) <e570dda88cd55c4ba8ea38b63e89231a> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Format/OpenEXR.plugin/Contents/MacOS/OpenEXR
             0x127f7d000 -        0x127f88fff +com.adobe.AfterEffects.Analyzer ??? (???) <322481ea82cd67aefb8b2687e2fbfe81> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/Analyzer.plugin/Contents/MacOS/Analyzer
             0x127f8d000 -        0x127f91ff7 +com.adobe.AfterEffects.RPFImport ??? (???) <415423d4579bbae5187c9d436aff6c6c> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/RPFImport.plugin/Contents/MacOS/RPFImport
             0x127f94000 -        0x127f98ff8 +com.adobe.ape.shim adbeape version 3.1.64.7373 (3.1.64.7373) <b492c64700df280f47a0ea78f1f9424a> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
             0x127fb6000 -        0x127fe6fff +com.adobe.AfterEffects.PNGIO ??? (???) <3e5936e00f004785302f388208b11628> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Format/PNGIO.plugin/Contents/MacOS/PNGIO
             0x127ff1000 -        0x128005ffb +com.adobe.AfterEffects.Smoother ??? (???) <ab6f9378e6e54b64fb32b18f9a8f0e2e> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/Smoother.plugin/Contents/MacOS/Smoother
             0x128436000 -        0x1284eafff +com.adobe.AfterEffects.PremiereProImport ??? (???) <61e5aebad4bae2c76d3a798c9822cb35> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Format/PremiereProImport/PremiereProImport.plugin/Contents/MacOS/PremierePro Import
             0x128517000 -        0x1285a9fff +com.adobe.MediaCore.Frameworks.UI 1.0 (1.0) <c646f212dd5f242bf7e95a767f980fb1> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
             0x128633000 -        0x12868ffff +com.adobe.AfterEffects.TIFFIO ??? (???) <bb070dc93710e676703c9bbfa563de12> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Format/TIFF.plugin/Contents/MacOS/TIFFIO
             0x12869f000 -        0x128763feb +com.adobe.AfterEffects.Vic ??? (???) <82deaa73d565a6b0e29610bcf914b257> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Format/Vector Output.plugin/Contents/MacOS/Vic
             0x1287ba000 -        0x1287d3ff3 +com.adobe.AfterEffects.Align ??? (???) <8925249ebdfe57735c8e7678f4cf792e> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/Align.plugin/Contents/MacOS/Align
             0x1287e2000 -        0x1287f2fff +com.adobe.AfterEffects.MayaImport ??? (???) <3c2ee5dec841a35ddf51eb125a8fc38d> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/MayaImport.plugin/Contents/MacOS/MayaImport
             0x1287f5000 -        0x12880cff7 +com.adobe.AfterEffects.MetaPal ??? (???) <3d1218bee450ecdce1da8f81e6e2db3a> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/MetaPal.plugin/Contents/MacOS/MetaPal
             0x12881d000 -        0x128847fff +com.adobe.AfterEffects.Moka ??? (???) <d9479ab2eef1036a74893f4e66893f81> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/Moka.plugin/Contents/MacOS/Moka
             0x128858000 -        0x12886cffb +com.adobe.AfterEffects.MotionSketch ??? (???) <5db4467f168a982572329aa597f1d8e7> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/MotionSketch.plugin/Contents/MacOS/MotionSketch
             0x12887a000 -        0x128ccefff +com.adobe.AfterEffects.Scripting ??? (???) <30dcc64f38102cebcc73c5c9a46a457f> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/Scripting.plugin/Contents/MacOS/Scripting
             0x128e5a000 -        0x128e7affb +com.adobe.ape adbeapecore version 3.1.65.7508 (3.1.65.7508) <284c86beacd831dde58d544f581bc93b> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
             0x128ea1000 -        0x128ea2fff  com.apple.MonitorPanelFramework 1.2.0 (1.2.0) <23e3ab9afc9fe1912e87f8ac5cbe1976> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
             0x128ecb000 -        0x128edcfff  com.apple.DSObjCWrappers.Framework 1.3 (1.3) <5f8972eff5c1afaccb870c7eea9e953f> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
             0x128eee000 -        0x128ef4fff  com.apple.DisplayServicesFW 2.0 (2.0) <996299e987f1583e29ae072f919c6e73> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
             0x12916a000 -        0x129fb1fcf +com.adobe.adobeswfl ??? (2.0.0.7489) <dbd3811148d6c031ef50d034c94ed38b> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/Ado beSWFL
             0x12a1b2000 -        0x12a23ffff  com.apple.PDFKit 2.1 (2.1) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
             0x12a2b7000 -        0x12a30dfe9  com.apple.securityinterface 3.0 (32532) <e63f65b66d9d286fc0804d7a57f9f826> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
             0x12a366000 -        0x12a3acfe2  com.apple.securityfoundation 3.0 (32989) <80e4c351f25f2b498fa3a838cb24bcce> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
             0x12a3f0000 -        0x12a5ebfeb  com.apple.QuartzComposer 2.1 (106.5) <11aa26d3ace52146926300d862384aa6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
             0x12a7c1000 -        0x12a804ff7  com.apple.quartzfilters 1.5.0 (1.5.0) <4df462ce4a340e0db7d5ca3210ab647c> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
             0x12a844000 -        0x12a9c3fff  com.apple.imageKit 1.0.1 (1.0) <34663e0875645adf48f11de7645fdf71> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
             0x12ab27000 -        0x12ac10ff7  com.apple.JavaScriptCore 5525.18 (5525.18) /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
             0x12ac86000 -        0x12ace5fff  com.apple.QuickLookUIFramework 1.1 (170.4) /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/QuickLookUI
             0x12ad3d000 -        0x12ad5bff3  com.apple.DirectoryService.Framework 3.5.4 (3.5.4) <a788599274aae328b26bcefb26ae6f5c> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
             0x12c559000 -        0x12c568fe7  libSimplifiedChineseConverter.dylib ??? (???) <c534e538edc041ded4030b976b314412> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
             0x12c8ce000 -        0x12c8e0fef  libTraditionalChineseConverter.dylib ??? (???) <6e782f19ba64de4353f2d031aa10d513> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
             0x12c8e4000 -        0x12c905ff7  libKoreanConverter.dylib ??? (???) <681ba086d6cf23e1cbf19a1d98f9b33b> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
             0x12c9b2000 -        0x12c9c8ff3 +com.adobe.AfterEffects.Wiggler ??? (???) <b4ce3dcaf16a5ed9b2677c31a31b247d> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Keyframe/Wiggler.plugin/Contents/MacOS/Wiggler
             0x12cbb3000 -        0x12cbb5ff7 +com.adobe.AfterEffects.Gaussian_Blur ??? (???) <e0983d31ff1aa5f3a96485f2038b7db0> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/Gaussian_Blur.plugin/Contents/MacOS/Gaussian_Blur
             0x12cf07000 -        0x12cf09ff7 +com.adobe.AfterEffects.Photo_Filter ??? (???) <f50edc58672becb2acaf331803e9f1d4> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/Photo Filter.plugin/Contents/MacOS/Photo_Filter
             0x12cfa5000 -        0x12cfaaff7 +com.adobe.AfterEffects.Transform ??? (???) <d2cfbe78787a6cacda5a18831286093f> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/Transform.plugin/Contents/MacOS/Transform
             0x12cff2000 -        0x12cff5ff7 +com.adobe.AfterEffects.B-c-2 ??? (???) <2499a2466261f8d321e7182710ad56df> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/B-c-2.plugin/Contents/MacOS/B-c-2
             0x12cff8000 -        0x12cffcfff +com.adobe.AfterEffects.Tint ??? (???) <bcff37816e2534dd98179766f63a9aa7> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/Tint.plugin/Contents/MacOS/Tint
             0x12e785000 -        0x12e78efff +com.adobe.AfterEffects.Exposure ??? (???) <553e6f4b82ef63780a2e9b36b16a34f9> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/Exposure.plugin/Contents/MacOS/Exposure
             0x12e791000 -        0x12e7a0fff +com.adobe.AfterEffects.FreePin ??? (???) <4d77b3744b94c30af0a8758d82dc3114> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/Puppet.plugin/Contents/MacOS/FreePin
             0x12e806000 -        0x12e809fff +com.adobe.AfterEffects.Color_HLS ??? (???) <f9063a73d4518c45c9d5dc434cbe39ec> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/Color_HLS.plugin/Contents/MacOS/Color_HLS
             0x12e80c000 -        0x12e811fff +com.adobe.AfterEffects.Unsharp_Mask ??? (???) <86b3eebb50f73012ced9e5b6e104f767> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/Unsharp_Mask.plugin/Contents/MacOS/Unsharp_Mask
             0x12e814000 -        0x12e851feb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.0.0.64 (1.0.0.64) <cd8bd7c70f6629b6c158a6ef8df69996> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotification s
             0x12e8a3000 -        0x12e8affff +com.adobe.AfterEffects.Corner_Pin ??? (???) <97455ac3bc32dc4cbf498a7329c08642> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/Corner_Pin.plugin/Contents/MacOS/Corner_Pin
             0x12e900000 -        0x12e903fff +com.adobe.AfterEffects.ChangeToColor ??? (???) <6bc98fc5d9e3e551a3a12791bb0c284c> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/ChangeToColor.plugin/Contents/MacOS/ChangeToColor
             0x12e9b5000 -        0x12e9d3fff +com.adobe.MediaCore.ImporterMPEG 1.0 (1.0) <1c6582c08e6711fb9a1f18b987df7949> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Plug-ins/(MediaCore)/ImporterMPEG.bundle/Contents/MacOS/ImporterMPEG
             0x12ede7000 -        0x12eee4fff +com.adobe.AfterEffects.RefineMatte ??? (???) <3f9c8c995344de9476e1a8948daab8bc> /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Required/RefineMatte.plugin/Contents/MacOS/RefineMatte
             0x130d29000 -        0x130d3afff +com.adobe.AfterEffects.Hue_Sat ??? (???) <f5888fef2551fa1f6f1782e4387dcff3> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/Hue_Sat.plugin/Contents/MacOS/Hue_Sat
             0x130d3f000 -        0x130d5efff +com.adobe.AfterEffects.MshWrp_New ??? (???) <c918ce15f6d3e9153c004b7a53aff1a3> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/MshWrp_New.plugin/Contents/MacOS/MshWrp_New
             0x130ec1000 -        0x130ed2fff +com.adobe.AfterEffects.Levels2 ??? (???) <de0a361cc1220eeec4494f14beb44ee6> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/Levels2.plugin/Contents/MacOS/Levels2
             0x131000000 -        0x13107ffff  com.apple.iLifeMediaBrowser 1.0.9 (212.0.1) /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowse r
             0x131a1a000 -        0x131a30ff3 +com.adobe.AfterEffects.ShadowHighlight ??? (???) <cf9323da11a07030b7df01219719934b> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/ShadowHighlight.plugin/Contents/MacOS/ShadowHighlight
             0x131b20000 -        0x131b4ffe3 +com.adobe.AfterEffects.MatchGrain ??? (???) <8cc64943b854916574b184a933b80ed7> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/MatchGrain.plugin/Contents/MacOS/MatchGrain
             0x131bc7000 -        0x131be6fe3 +com.adobe.AfterEffects.Jpg ??? (???) <00bf19283bce599c22af490689f3b369> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Format/JPEG.plugin/Contents/MacOS/Jpg
             0x131d00000 -        0x131d61fef +com.mainconcept.mc_mfimport 8.5 (8.5.0.14572) /Applications/Editing Apps/Adobe After Effects CS5/Adobe After Effects CS5.app/Contents/Frameworks/mc_mfimport.framework/Versions/8.5/mc_mfimport
             0x132092000 -        0x132096fff +com.adobe.AfterEffects.Noise ??? (???) <c97619396baef7483ec7de9ab3341eb9> /Applications/Editing Apps/Adobe After Effects CS5/Plug-ins/Effects/Noise.plugin/Contents/MacOS/Noise
          0x7fff5fc00000 -     0x7fff5fc2e593  dyld 96.2 (???) <f8badea89d68688d53ebe823a5f32cf1> /usr/lib/dyld
          0x7fff80003000 -     0x7fff8002cfff  libcups.2.dylib ??? (???) <cb6b41153bdcbc045aa278d8c8bdc04a> /usr/lib/libcups.2.dylib
          0x7fff8002d000 -     0x7fff8005fff7  libauto.dylib ??? (???) <cc8eece8c0097b254c758bd4e8df9537> /usr/lib/libauto.dylib
          0x7fff80060000 -     0x7fff8012bfe7  com.apple.ColorSync 4.5.0 (4.5.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
          0x7fff8012c000 -     0x7fff8014dfff  libresolv.9.dylib ??? (???) <03b4dca5d0f95bc63dbf72f65267ff9d> /usr/lib/libresolv.9.dylib
          0x7fff8014e000 -     0x7fff80156ffa  libbsm.dylib ??? (???) <a870a8e515e1a6407c81ddeebba21793> /usr/lib/libbsm.dylib
          0x7fff80157000 -     0x7fff8015affb  com.apple.help 1.1 (36) <625c2d6bb29ee822f9dce6322d08df47> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
          0x7fff8015b000 -     0x7fff80182fff  libxslt.1.dylib ??? (???) <edd5bcbc17be0053cc2014d045ccbe08> /usr/lib/libxslt.1.dylib
          0x7fff80183000 -     0x7fff801c6fef  libTIFF.dylib ??? (???) <d0e8f77725507c880231a445725d05a9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
          0x7fff801c7000 -     0x7fff801ccfff  com.apple.CommonPanels 1.2.4 (85) <8f5631ff238ad1bad2e031fe5e7442d2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
          0x7fff801cd000 -     0x7fff801cdff8  com.apple.Cocoa 6.5 (???) <d53437c1faeb42624f1d71202caa9cad> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
          0x7fff801ce000 -     0x7fff8021afe7  com.apple.Metadata 10.5.2 (398.18) <6a7eb6380d44957c317a2f6a6bf8ee29> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
          0x7fff8021b000 -     0x7fff80229fff  libCSync.A.dylib ??? (???) <091df4156abceb82d891b65f92867475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
          0x7fff8022a000 -     0x7fff8022efff  libGIF.dylib ??? (???) <459456ebf1ecb3e94a09902dcd169550> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
          0x7fff8022f000 -     0x7fff8022fffd  com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
          0x7fff80230000 -     0x7fff80230ff8  com.apple.ApplicationServices 34 (34) <29a6f07deb1ef821735e2c18ef1e9fa5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
          0x7fff80231000 -     0x7fff802bbfef  com.apple.QTKit 7.5 (861) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
          0x7fff802bc000 -     0x7fff802defff  libJPEG.dylib ??? (???) <3ed8e3e285ad415113ecc0c8497c854f> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
          0x7fff802df000 -     0x7fff80343fef  libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
          0x7fff80344000 -     0x7fff8090bfef  com.apple.CoreGraphics 1.351.31 (???) <4c6f9f279b01cfb225d24f663b79c911> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
          0x7fff8090c000 -     0x7fff80949ff7  com.apple.coreui 1.1 (61) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
          0x7fff8094a000 -     0x7fff8094cfff  com.apple.NavigationServices 3.5.2 (163) <3e58cfe6d1bdcc4a4a64b6f79421291f> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
          0x7fff8094d000 -     0x7fff8094dffd  com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
          0x7fff8094e000 -     0x7fff8098dfef  com.apple.framework.IOKit 1.5.1 (???) <e0775a7c539702a670994b4b27bac410> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
          0x7fff8098e000 -     0x7fff80c89fe3  com.apple.CoreServices.CarbonCore 786.4 (786.4) <2a8a9adecacd29c8a50a968b64f51eb8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
          0x7fff80c8a000 -     0x7fff80ccdfef  com.apple.QD 3.11.52 (???) <6168470edc8c4db06ec8d250eae8ada0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
          0x7fff80cce000 -     0x7fff80dc2fff  libobjc.A.dylib ??? (???) <097c18311136478bb48938be0777c168> /usr/lib/libobjc.A.dylib
          0x7fff80dc3000 -     0x7fff80dc4ff3  com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
          0x7fff80dc5000 -     0x7fff80ea6fff  libcrypto.0.9.7.dylib ??? (???) <c39effd87ec6fb72b9a95a5c63baca41> /usr/lib/libcrypto.0.9.7.dylib
          0x7fff80ea7000 -     0x7fff81664fef  libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
          0x7fff81665000 -     0x7fff8166efff  libCGATS.A.dylib ??? (???) <ac05fd99f41fc7af032a6515e63ea95b> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGATS.A.dylib
          0x7fff8166f000 -     0x7fff81722fef  com.apple.DesktopServices 1.4.6 (1.4.6) <85dba6ab1bdea3e9a835427ae7e01412> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
          0x7fff81723000 -     0x7fff81792ff9  com.apple.print.framework.PrintCore 5.5.3 (245.3) <bffd62913cdf70462983c58b27be7a07> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
          0x7fff81793000 -     0x7fff817e7fe3  com.apple.HIServices 1.7.0 (???) <ab682a94bbb2418c772570a5f5e13849> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
          0x7fff817e8000 -     0x7fff81870fe7  libsqlite3.0.dylib ??? (???) <3c7ab3523b816dbd3e039ee7e6e2c580> /usr/lib/libsqlite3.0.dylib
          0x7fff81871000 -     0x7fff81871ffa  com.apple.CoreServices 32 (32) <f1ae7e34fb008524b502ed0185b32794> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
          0x7fff81872000 -     0x7fff8187eff1  libgcc_s.1.dylib ??? (???) <6fc905606335f261db4da9529c7e2711> /usr/lib/libgcc_s.1.dylib
          0x7fff8187f000 -     0x7fff81890ffd  libz.1.dylib ??? (???) <2022cc8950afdf485ba1df76364ba725> /usr/lib/libz.1.dylib
          0x7fff81891000 -     0x7fff81db3f26  libGLProgrammability.dylib ??? (???) <97bc2b40687db1aa5ccb6ece7d4f59c2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
          0x7fff81db4000 -     0x7fff81dd1fff  libPng.dylib ??? (???) <1628aa07562a305e75ef3e94eea34565> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
          0x7fff81dd2000 -     0x7fff81f09fff  com.apple.CoreFoundation 6.5.3 (476.14) <8f32ec5c39c3f6ff07459bf731c1c410> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
          0x7fff81f0a000 -     0x7fff81f9bfff  com.apple.SearchKit 1.2.0 (1.2.0) <b5dc67de31f5d81eec9cbb4a6bcc3c28> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
          0x7fff81f9c000 -     0x7fff82022fef  com.apple.audio.CoreAudio 3.1.0 (3.1) <1ae1314da7fb34ed099f33b39a2f0395> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
          0x7fff82023000 -     0x7fff8203dfff  libvDSP.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
          0x7fff8203e000 -     0x7fff8203effb  com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
          0x7fff8203f000 -     0x7fff8203fffd  com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
          0x7fff82040000 -     0x7fff820b4fe7  libstdc++.6.dylib ??? (???) <379a6a2dc6e21ba77310b3d2d9ea30ac> /usr/lib/libstdc++.6.dylib
          0x7fff820b5000 -     0x7fff8248afef  com.apple.QuartzCore 1.5.3 (1.5.3) <543fc59194bbb59a96a5c852061c4fe6> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
          0x7fff8248b000 -     0x7fff824d0fef  libRIP.A.dylib ??? (???) <f9b8ce1d69ef5f0c8446b70c1a4b8bd7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
          0x7fff824d1000 -     0x7fff82595fe2  com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
          0x7fff82596000 -     0x7fff825aefff  com.apple.DictionaryServices 1.0.0 (1.0.0) <ce7135044e951deaa2b687bc8537809a> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
          0x7fff825af000 -     0x7fff825eafff  com.apple.AE 402.2 (402.2) <b03583e0747f82199e0d9604014faa34> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
          0x7fff825eb000 -     0x7fff82727fe9  com.apple.ImageIO.framework 2.0.2 (2.0.2) <2cb2165389e4764fecee459f474a9541> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
          0x7fff82728000 -     0x7fff82736ff9  com.apple.helpdata 1.0 (14) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
          0x7fff82737000 -     0x7fff8283afeb  com.apple.CoreData 100.1 (186) <074abc7f43f81f7885e4d0674a8be4bc> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
          0x7fff8283b000 -     0x7fff8286fff7  libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
          0x7fff82870000 -     0x7fff829defff  libicucore.A.dylib ??? (???) <829a7a0be8d1631d84dde92109abe744> /usr/lib/libicucore.A.dylib
          0x7fff829df000 -     0x7fff829e1ff7  libffi.dylib ??? (???) <5ccd57a3de7db7f7bffa1b6ef2217b0c> /usr/lib/libffi.dylib
          0x7fff829e2000 -     0x7fff829e4fff  com.apple.print.framework.Print 218.0.2 (220.1) <2b847a0a1cd885f596a4d10409d50ba3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
          0x7fff829e5000 -     0x7fff829e9fff  libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
          0x7fff829ea000 -     0x7fff82bf0ffb  com.apple.security 5.0.4 (34102) <18f1b986b1c5c26b98da0c096b29f559> /System/Library/Frameworks/Security.framework/Versions/A/Security
          0x7fff82bf1000 -     0x7fff82c02fff  com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <7b000af113e7f602b9e0b1fd383005fc> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
          0x7fff82c03000 -     0x7fff82c98ffb  com.apple.LaunchServices 289.2 (289.2) <cc35bde2e0b933f6772b6aeb41fabe8b> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
          0x7fff82c99000 -     0x7fff82cb6fef  com.apple.CoreVideo 1.5.1 (1.5.1) <8a7d1055e0880fe6e09d3546fb3030fd> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
          0x7fff82cb7000 -     0x7fff82dd0ffb  com.apple.audio.toolbox.AudioToolbox 1.5.1 (1.5.1) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
          0x7fff82dd1000 -     0x7fff82e8ffff  edu.mit.Kerberos 6.0.12 (6.0.12) <3e2085d4a801ccfd46236281253e692f> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
          0x7fff82e90000 -     0x7fff82f2bfe7  com.apple.ink.framework 101.3 (86) <03096cd083a6e70bc7a18ad1b81feb15> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
          0x7fff82f2c000 -     0x7fff830b0ffb  libSystem.B.dylib ??? (???) <07a565d2ff1b8622d5aed29ce9482f46> /usr/lib/libSystem.B.dylib
          0x7fff830b1000 -     0x7fff830c0fe7  com.apple.opengl 1.5.6 (1.5.6) <b3da565a84601d276d8adaccc544ba30> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
          0x7fff830c1000 -     0x7fff831b6fff  libxml2.2.dylib ??? (???) <08b6a34eb05414f6d173b2deafbadf76> /usr/lib/libxml2.2.dylib
          0x7fff831b7000 -     0x7fff831e7fff  com.apple.shortcut 1 (1.0) <01a5e9a7c5f269cbba2cbd61ccdf1b2f> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
          0x7fff831e8000 -     0x7fff8325efef  libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
          0x7fff8325f000 -     0x7fff83262fff  com.apple.securityhi 3.0 (30817) <96d3b2804806a611f21f99019e90a438> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
          0x7fff83263000 -     0x7fff8327cfff  com.apple.openscripting 1.2.6 (???) <c1625319b1a114ffac2b866c3aa0ddd5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
          0x7fff8327d000 -     0x7fff83287fff  com.apple.speech.recognition.framework 3.7.24 (3.7.24) <cbec4dc3d0a7bc42b55a01f504904b7a> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
          0x7fff83288000 -     0x7fff83338fef  com.apple.CoreServices.OSServices 226.5 (226.5) <153b0f685494caafde595c2df1184da5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
          0x7fff83339000 -     0x7fff835d3fe3  com.apple.Foundation 6.5.5 (677.19) <db6f4ca576cfc6d652a3d27bfeedf9ae> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0x7fff835d4000 -     0x7fff835eaff9  com.apple.ImageCapture 4.0 (5.0.0) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
          0x7fff835eb000 -     0x7fff83f13fef  com.apple.AppKit 6.5.3 (949.33) <e6af96a0fee7f599cae1d07be6dec83a> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x7fff83f14000 -     0x7fff842ccfff  libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
          0x7fff842cd000 -     0x7fff84309fff  libGLImage.dylib ??? (???) <6b0d0bb7daa7d8f3ff8c55301233fecb> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
          0x7fff8430a000 -     0x7fff84347ff7  com.apple.SystemConfiguration 1.9.2 (1.9.2) <3e058b95c78dc2f54ec3f9781bd86e1c> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
          0x7fff84348000 -     0x7fff843c2ff3  com.apple.CoreText 2.0.2 (???) <cfc2580fa1663804866907ed8e219617> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
          0x7fff843c3000 -     0x7fff84455ff3  com.apple.CFNetwork 330.4 (330.4) <a4fb8254162f70cfb3cc8229952ea617> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
          0x7fff84456000 -     0x7fff84456fff  com.apple.Carbon 136 (136) <0e1cbd1cb914da23c1ea6b0647ebe730> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
          0x7fff84457000 -     0x7fff844f7fe3  com.apple.ApplicationServices.ATS 3.3 (???) <7991cf94b502f8d389ae3ee077edcb75> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
          0x7fff844f8000 -     0x7fff847dffeb  com.apple.HIToolbox 1.5.3 (???) <ae8f8d3dd21234aada8ff14c4c9b8ae4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
          0x7fff847e0000 -     0x7fff847e6fff  com.apple.DiskArbitration 2.2.1 (2.2.1) <e75fe224700767869227cc903bef8ed9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
          0x7fff847e7000 -     0x7fff847e9ff9  libRadiance.dylib ??? (???) <f79bf15817e6894c9655c2bd2b062bff> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
          0x7fffffe00000 -     0x7fffffe01780  libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
      0xfffffffffffec000 - 0xfffffffffffeffff  libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
