0 Replies Latest reply on Aug 11, 2011 3:31 AM by wait andrew
    server datamerge .net crash
    wait andrew
      I am trialling indesign server
      I have successfully created a js based datamerge using the soap example
      I am now trying to do this programatically (e.g. directly interfacing with the server objects)
      In both C# and VB I am getting a crash everytime I execute the datamerge MergeRecords function.
      Below is the script I am running, with comments, if the doc.DataMergeProperties.MergeRecords("c:/temp/wibble.txt") line is commented out the script will execute fine, uncomment it and the whole thing crashes, including the server, when another function is called afterwards.
      This is driving me mad
      Any help appreciated
      Option Explicit Off
      Partial Class vbcreate
          Inherits System.Web.UI.Page
          Protected Sub Page_Load(sender As Object, e As System.EventArgs) Handles Me.Load
      Response.Write("here")
      'Dim app As InDesignServer.Application
      'Dim doc As InDesignServer.Document
      app = CreateObject("IndesignServer.Application")
      doc = app.Open("C:/Adobe InDesign CS5.5 Server SDK/samples/sampleclient-aspnet-soap/files/template2.indd")
      '''''' Below returns 1 so OK up to here
      Response.Write(app.Documents.Count)
      ds = "C:/Adobe InDesign CS5.5 Server SDK/samples/sampleclient-aspnet-soap/files/CSV/xls.csv"
      app.dataMergeOptions.removeBlankLines = True
      doc.DataMergeProperties.SelectDataSource(ds)
      '''''' Below still returns 1 so still working
      ''''' the wibble file is created but then the application CRASHES
      '''''''EITHER of these two next lines will cause a crash
      'doc.close(InDesignServer.idSaveOptions.idNo)
      'Response.Write(app.Documents.Count)
      End Sub
      End Class
