3 Replies Latest reply on Aug 11, 2011 11:26 PM by drkstr_1
    Why cannot replace the borderColor of the Tooltip?????
    Jessie_Meta
      Hi all,
      When I mouse over the swfLoader1, sometimes it will display the tooltip with the default borderColor(red) of "errorTipRight" border style
      but I already change the borderColor to #FFFFFF (please refer to the sample code as below).
      I don't why sometimes it will show the borderColor with red (default)?????
      Anyone can help me to solve this problem? Thanks.
      Sample code:
      <mx:Style>
           .errorTip
               color: #1B75BB;
                fontFamily: "Century Gothic";
                fontSize: 10;
                borderColor: #FFFFFF;
                borderStyle: "errorTipRight";
                backgroundAlpha: 0.8;
      </mx:Style>
      <mx:Script>
           import mx.controls.ToolTip;
           import mx.managers.ToolTipManager;
           private var myTip:ToolTip = null;
           private function createTip(evt:MouseEvent):void
                myTip = ToolTipManager.createToolTip("Testing",evt.stageX,evt.stageY) as ToolTip;
                myTip.setStyle("styleName", "errorTip");
           private function destroyTip():void
                ToolTipManager.destroyToolTip(myTip);
                myTip = null;
      </mx:Script>
      <mx:SWFLoader id="swfLoader1" x="110" y="9" width="25" height="32" mouseOver="createTip(event)" mouseOut="destroyTip()"/>
      Regards,
      Jessie
        • 1. Re: Why cannot replace the borderColor of the Tooltip?????
          Kanchan Ladwani Level 2
          Hello Jessie,
            Instead of calling setStyle() method,
          u can use following snippet-
          <fx:Style>
                  @namespace mx "library://ns.adobe.com/flex/mx";
                  mx|ToolTip
                  color: #1B75BB;
                  fontSize: 10;
              </fx:Style>
          U dont need to call setStyle method,this will apply styling for ur tooltips.
          Thanks and Regards,
          Kanchan Ladwani | kladwani@infocepts.com | www.infocepts.com
          • 2. Re: Why cannot replace the borderColor of the Tooltip?????
            Jessie_Meta Level 1
            Thanks Kanchan Ladwani for your help.
            I try the method as below, it is working for me.
            import mx.styles.StyleManager;
            StyleManager.getStyleDeclaration("ToolTip").setStyle("backgroundAlpha",0.8);
            StyleManager.getStyleDeclaration("ToolTip").setStyle("borderStyle","errorTipRight");
            StyleManager.getStyleDeclaration("ToolTip").setStyle("fontSize","10");
            StyleManager.getStyleDeclaration("ToolTip").setStyle("fontFamily","Century Gothic");
            StyleManager.getStyleDeclaration("ToolTip").setStyle("color","#1B75BB");
            StyleManager.getStyleDeclaration("ToolTip").setStyle("borderColor","#FFFFFF");
            • 3. Re: Why cannot replace the borderColor of the Tooltip?????
              drkstr_1 Level 4
              Not sure if this matters to you, but for anyone else that stumbles across this thread looking for a solution, that is a horribly innifient way to do it.
              Looking up a style decleration is a heavy operation, and there is no reason to do it for every style property you want to set. If for some reason you don't want to use CSS, I would suggest looking up the style decleration once and store the instance in a variable you can operate on. You may have to setStyleDecleration again when your finished, but I dont think so (not sure if it copies by value or by reference, but most likely reference).
              *edit*
              Strike that last statement. I just realized the fact that the above code even works indicates it copies by reference. No need to reset the style decleration once you've modofied it.
