3 Replies Latest reply on Nov 6, 2006 3:35 AM by Newsgroup_User
    XML-flash troubles
    Level 7
      This is a multi-part message in MIME format.
      ------=_NextPart_000_0003_01C7018D.CD2132F0
      Content-Type: text/plain;
      charset="us-ascii"
      Content-Transfer-Encoding: 7bit
      Hey,
      It seems I want to much of xml. Defined in the xml as
      <pages>
      <page id="home" x="100" y="10" title="BIG TITLE"
      bg="set-01-cut.jpg">
      <column w="220" h="300" title="Subtitle">
      <![CDATA[<C1>Body tekst formatted by
      an external css file</C1>]]>
      </column>
      </pages>
      I have breaks in the subtitles of my design, and the way this is defined
      it leaves no room for html/css formatting.
      Id, title and body are defined in actionscript, body and title even as
      htmlText, but unsurprisingly of no avail.
      Started out as a graphic flash user, I am not that familiar with xml, so
      if someone here can clear things up for me, I would be very grateful.
      Thanks in advance
      Content-Type: text/html;
      charset="us-ascii"
      Content-Transfer-Encoding: quoted-printable
      <html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
      xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
      xmlns=3D" http://www.w3.org/TR/REC-html40">
      <head>
      <META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
      charset=3Dus-ascii">
      <meta name=3DGenerator content=3D"Microsoft Word 11 (filtered medium)">
      <style>
      /* Font Definitions */
      @font-face
      {font-family:Futura-Book;
      panose-1:0 0 0 0 0 0 0 0 0 0;}
      /* Style Definitions */
      p.MsoNormal, li.MsoNormal, div.MsoNormal
      {margin:0cm;
      margin-bottom:.0001pt;
      font-size:12.0pt;
      font-family:"Times New Roman";}
      a:link, span.MsoHyperlink
      {color:blue;
      text-decoration:underline;}
      a:visited, span.MsoHyperlinkFollowed
      {color:purple;
      p
      {mso-margin-top-alt:auto;
      margin-right:0cm;
      mso-margin-bottom-alt:auto;
      margin-left:0cm;
      font-size:12.0pt;
      span.E-mailStijl17
      {mso-style-type:personal-compose;
      color:windowtext;
      font-weight:normal;
      font-style:normal;
      text-decoration:none none;}
      @page Section1
      {size:612.0pt 792.0pt;
      margin:72.0pt 90.0pt 72.0pt 90.0pt;}
      div.Section1
      {page:Section1;}
      </style>
      </head>
      <body lang=3DEN-US link=3Dblue vlink=3Dpurple>
      <div class=3DSection1>
      <p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
      lang=3DNL
      style=3D'font-size:12.0pt'>Hey,<o:p></o:p></span></font></p>
      lang=3DNL
      style=3D'font-size:12.0pt'><o:p> </o:p></span></font></p>
      style=3D'font-size:
      12.0pt'>It seems I want to much of xml. Defined in the xml =
      as<o:p></o:p></span></font></p>
      style=3D'font-size:
      style=3D'font-size:
      12.0pt'>&lt;pages&gt;<o:p></o:p></span></font></p>
      style=3D'font-size:
      12.0pt'>          &nbsp=
      ; &lt;page id=3D&quot;home&quot; x=3D&quot;100&quot;
      y=3D&quot;10&quot; title=3D&quot;BIG TITLE&quot; =
      bg=3D&quot;set-01-cut.jpg&quot;&gt;<o:p></o:p></span></font></p>
      style=3D'font-size:
      12.0pt'>          &nbsp=
      &lt;column w=3D&quot;220&quot; h=3D&quot;300&quot;
      title=3D&quot;Subtitle&quot;&gt;<o:p></o:p></span></font></p>
      style=3D'font-size:
      12.0pt'>          &nbsp=
      &lt;![CDATA[&lt;C1&gt;Body tekst formatted
      by an external css file&lt;/C1&gt;]]&gt;<o:p></o:p></span></font></p>
      style=3D'font-size:
      12.0pt'>          &nbsp=
      &lt;/column&gt;<o:p></o:p></span></font></p>
      style=3D'font-size:
      12.0pt'>&lt;/pages&gt;<o:p></o:p></span></font></p>
      style=3D'font-size:
      style=3D'font-size:
      12.0pt'>I have breaks in the subtitles of my design, and the way this is
      defined it leaves no room for html/css formatting. =
      style=3D'font-size:
      12.0pt'>Id, title and body are defined in actionscript, body and title =
      even as
      htmlText, but unsurprisingly of no avail.<o:p></o:p></span></font></p>
      style=3D'font-size:
      12.0pt'>Started out as a graphic flash user, I am not that familiar with =
      xml,
      so if someone here can clear things up for me, I would be very =
      grateful.<o:p></o:p></span></font></p>
      style=3D'font-size:
      style=3D'font-size:
      12.0pt'>Thanks in advance<o:p></o:p></span></font></p>
      </div>
      </body>
      </html>
      ------=_NextPart_000_0003_01C7018D.CD2132F0--
        • 1. Re: XML-flash troubles
          AnandMX Level 1
          I am not able to understand what is your exact problem but if it is integration of CSS data with XML then it is simple as u can directly *** css in your textField. Use stylesheet property of TextField and put HTML=true
          i think your job wil be done
          • 2. Re: XML-flash troubles
            Level 7
            Sorry, I couldn't find a question in there...
            However, I do believe your XML is malformed - in your column tag, you have
            column C1 within the CDATA... the XML parser isn't going to see C1 that
            way... I believe you want it like so:
            <C1><![CDATA[Body test formatted by an external css file]]></C1>
            Dave -
            Head Developer
            www.blurredistinction.com
            Adobe Community Expert
            http://www.adobe.com/communities/experts/
            • 3. Re: XML-flash troubles
              Level 7
              Indeed,
              I haven't been clear.
              C1 is CSS selector. It's read when the xml data is imported by flash and
              then run through the css. I believe that part works right now.
              My question is how to text format a variable like "title", inside
              <page>. I want to get the subtitle text to break like
              Sub
              Title
              Text
              Instead of "Sub Title Text"
              I've already set the textfields to html, (by actionscript) but it won't
              read the variable "title" with tags inside.
