2 Replies Latest reply on Aug 11, 2011 7:26 AM by the_wine_snob
    Resolution & aspect ratio
    Ahachng
      I am going to take some pictures in RAW format with my Canon 60D to use in video editing. I'll crop my original RAW file to 16:9 aspect ratio and reduce image size to 1920x1080 (16:9) then.
      a. As Canon 60D provides L(RAW) 5184x3456, M(RAW) 3888x2592 and S(RAW) 2592x1728, I wonder which original RAW format I should use. Is there any differene in quality of my final product with different original RAW?
      b. Say if I choose S(RAW) 2592x1728, can I crop it to 2592x1458 (16:9) and scale it down to the proper size to use in video editing? If I do it this way, will the final video file become much bigger?
      Thank you.
      Ahachng
        • 1. Re: Resolution & aspect ratio
          Colin Brougham Level 6
          Do you plan on animating the photos, e.g. zoom in, zoom out, pan around? Or will you be leaving them static? If you're not going to be animating the photos, you can probably use the lowest resolution--and practically speaking, you don't even need to crop and resize the images externally before using them in Premiere Pro. As of CS5, PPro has much better scaling algorithms and can produce very nice results simply by scaling the photos in your editing sequence. This lets you position a large photo any way you see fit within your sequence, so you don't need to worry about creating multiple versions of a cropped photo, e.g. wide, medium, close-up.
          If you will be animating the photos, there are practical maximum dimensions you'll want to be aware of: maximum dimensions in Adobe Premiere Pro CS5 and CS5.5 « Premiere Pro work area
          • 2. Re: Resolution & aspect ratio
            the_wine_snob Level 9
            Along with everything that Colin stated, my one question would be: "Will I ever have need for these photos to be printed large, or used in printed material?" If the answer is yes, then shoot at the highest resolution. If these will ONLY be used for Video, then the lower resolution will save some HDD real estate, and just a bit of processing, when going from the Canon RAW in Photoshop, Lightroom, or in Canon's RAW utility.
            I find it frustrating, when the client says, "Oh, we will NEVER need the images, beyond the Video," and then they come back with, "Can you do a Frame Export, because we want to use that for our tradeshow booth, and it needs to be printed to 120" wide."
