9 Replies Latest reply on Aug 17, 2011 9:18 PM by Mulraid
    Flex Mobile - Won't filter datagrid?
    Mulraid
      Hi, I am fairly new at all this to be honest. But I pick on things very fast. below is what I have been working on. From the
      ex:'s I have found online. The goal is to load the Xml file. Display a "Buylist" & be able to filter out the very long list. They say  "e4x" is the
      best way to go. Only problem is when I use the [ resultFormat="e4x" ] under the [ <s:HTTPService> it does not display
      a error code. But when I load the app up under the emulator and it trys to read the Xml file it gets an error. And if I take that line out
      it loads fine. But there is no filtering.
      What am I doing wrong?
      <s:View fontSize="20"
              xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:s="library://ns.adobe.com/flex/spark">
          <fx:Script>
              <![CDATA[
              private function init():void
              myData.send();
              private function dataLoaded():void
              myDataGrid.dataProvider = myData.lastResult.document.row;
              private function search():void
              try
              var reg:RegExp = new RegExp(tbSearch.text.toLowerCase());
              myDataGrid.dataProvider = myData.lastResult.document.row.(document.row(Card.toLowerCase()))
              catch(err:Error)
              finally
          </fx:Script>
          <fx:Declarations>
                                  <s:HTTPService
                                                  id="myData"
                                                  url="http://weblist.webs.com/Mbuylist.xml"
                                                  resultFormat="e4x"
                                                  result="dataLoaded();"
          </fx:Declarations>
          <s:titleContent>
              <s:TextInput id="tbSearch" width="357" text="" change="search();">
              </s:TextInput>
          </s:titleContent>
          <s:actionContent>
              <s:Button x="21" width="90" label="S" click="myData.send()"/>
          </s:actionContent>
          <s:DataGrid id="myDataGrid" width="481" height="619" dataProvider="{myData.lastResult.document.row}">
          </s:DataGrid>
      </s:View>
        • 1. Re: Flex Mobile - Won't filter datagrid?
          kokorito Level 4
          cant you just use a filter function on the grid dataprovider
          grid.dataProvider.filterFunction = filtering;
          grid.dataProvider.refresh();
          protected function filtering(obj:Object):Boolean
               return (obj.propertyIwantToTest == whatIwantToFilter);
          • 2. Re: Flex Mobile - Won't filter datagrid?
            Mulraid Level 1
            A little Stumped.
                    myDataGrid.dataProvider.filterFunction = filtering;
                   myDataGrid.dataProvider.refresh();
                            return (obj.document == myData.lastResult.docuemnt.row);
            I havent used the Filter funtion before. This are the values I changed in orange. In Blue is saying
            Multiple markers at this line:
            -1120: Access of undefined property myDataGrid.
            -1120: Access of undefined property filtering.
            -Access of undefined property filterFunction
            Also I still have the e4x loading problem. Do I just not use that? Please break this down for me =).
            Thank You for help! and anyone else who responds!
            • 3. Re: Flex Mobile - Won't filter datagrid?
              kokorito Level 4
              obj is the 'row' from the datagrid
              so
              return (obj.price > 10); would filter all the rows where the price is more than 10
              • 4. Re: Flex Mobile - Won't filter datagrid?
                athakur83
                Filter function has to be used on a array collection for example I want to filter out all the "male" employees:
                var myData:ArrayCollection = new ArrayCollection();
                myData.filterFunction = myFilterFunction;
                myData.refresh();
                myDataGrid.dataProvider = myData;
                private function myFilterFunction(obj:Object):Boolean
                     if (obj.sex == "male")
                          return true;
                     return false;
                So you should cast the data being returned from the service to ArrayCollection/ArrayList before applying filter function. Hope that helps. Please pardon any syntax errors.
                • 5. Re: Flex Mobile - Won't filter datagrid?
                  kokorito Level 4
                  also works with XmlListCollection
                  • 6. Re: Flex Mobile - Won't filter datagrid?
                    Mulraid Level 1
                    My original ?' was if there was anything wrong with my first post.
                    It would not filter. Was I missing something?
                    As for this new method.
                    Now its telling me I have
                    -1151: A conflict exists with definition myData in namespace internal.
                    -46 changed lines
                    Witch I don't understand witch var its having trouble with. I tried renaming a couple different sets but then it give me more errors.
                    Sorry for all the trouble! AND THANKY YOU A BUNCH for the future!
                        <fx:Script>
                            <![CDATA[
                                import mx.collections.ArrayCollection;
                                myData.refresh();
                                    if (obj.Set == "3rd Edition")
                                return true;
                                return false;
                        </fx:Script>
                        <fx:Declarations>
                            <s:HTTPService
                                id="myData"
                                url="http://weblist.webs.com/Mtgbuylist.xml"
                        </fx:Declarations>
                        <s:titleContent>
                            <s:TextInput id="tbSearch" width="357" text="" change="myFilterFunction(obj:Object)">
                            </s:TextInput>
                        </s:titleContent>
                        <s:actionContent>
                        </s:actionContent>
                        </s:DataGrid>
                    </s:View>
                    • 7. Re: Flex Mobile - Won't filter datagrid?
                      kokorito Level 4
                      your service is called myData, declared in mxml
                      and in the script you declare myData as an arraycollection
                      you dont call the filterfunction directly
                      private function clickHandler(event:MouseEvent):void
                           myDataGrid.dataProvider.filterFunction = myFilterFunction;
                      <s:Button label="3rd Edition" click="clickHandler(event)"/>
                      • 8. Re: Flex Mobile - Won't filter datagrid?
                        athakur83 Level 1
                        I wrote the following code it works. Note that I am using urlloader instead of http service coz I am a bit lazy. But I used the same xml file as yours.
                        <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                        layout="absolute"
                        backgroundGradientAlphas="[1.0, 1.0]"
                        backgroundGradientColors="[#FFFFFF, #FFFFFF]"
                        creationComplete="init()" fontSize="12" fontFamily="Arial">
                        <mx:Script>
                        <![CDATA[
                        import mx.events.FlexEvent;
                        import mx.collections.XMLListCollection;
                        import mx.rpc.events.ResultEvent;
                        import mx.rpc.http.HTTPService;
                        [Bindable]
                        public var myData:XMLListCollection;
                        this.removeEventListener(FlexEvent.CREATION_COMPLETE,init);
                        var myLoader:URLLoader = new URLLoader();
                        myLoader.dataFormat = "XML";
                        myLoader.addEventListener(Event.COMPLETE, loadDataResult);
                        myLoader.load(new URLRequest("Mbuylist.xml"));
                        private function loadDataResult(event:Event):void
                        var myXML:XML = new XML(event.target.data);
                        var myXMLList:XMLList = myXML.row;
                        myData = new XMLListCollection(myXMLList);
                        myData.refresh();
                        private function myFilterFunction(obj:XML):Boolean
                        if(String(obj.Card).toLowerCase().indexOf(tbSearch.text.toLowerCase()) > -1)
                        return true;
                        return false;
                        </mx:Script>
                        <mx:DataGrid top="40" left="10" right="10" bottom="10" id="dgResults" dataProvider="{myData}">
                        <mx:columns>
                        <mx:DataGridColumn headerText="Card" dataField="Card"/>
                        <mx:DataGridColumn headerText="Set" dataField="Set"/>
                        <mx:DataGridColumn headerText="Buy" dataField="Buy"/>
                        </mx:columns>
                        </mx:DataGrid>
                        <mx:TextInput x="60" y="10" width="490" id="tbSearch" change="search()"/>
                        <mx:Label x="10" y="12" text="Search"/>
                        </mx:Application>
                        • 9. Re: Flex Mobile - Won't filter datagrid?
                          Mulraid Level 1
                          THANK YOU SO MUCH!
                              <fx:Script>
                                  <![CDATA[
                                      [Bindable]
                                      public var myData2:XMLListCollection;
                                          myLoader.load(new URLRequest("http://weblist.webs.com/Mtgbuylist.xml"));
                                          myData2 = new XMLListCollection(myXMLList);
                                          myData2.filterFunction = myFilterFunction;
                                          myData2.refresh();
                                              return true;
                                          return false;
                              </fx:Script>
                              <fx:Declarations>
                              </fx:Declarations>
                              <s:titleContent>
                                  </s:TextInput>
                              </s:titleContent>
                              <s:actionContent>
                                  <s:Button x="21" width="90" label="S" click="init()"/>
                              </s:actionContent>
                              <s:DataGrid id="dgResults" width="481" height="619" dataProvider="{myData2}">
                                  <s:columns>
                                      <s:ArrayList>
                                          <s:GridColumn headerText="Card" dataField="Card"/>
                                          <s:GridColumn headerText="Set" dataField="Set"/>
                                          <s:GridColumn headerText="Buy" dataField="Buy"/>
                                        </s:ArrayList>
                                  </s:columns>
                              </s:DataGrid>
                          </s:View>
                          Just one more ? How do i get to filter Buy prices!?
                          I used your example and edited a little. The main part was I was not loading the data on the grid and so it had nothing to search! OMG lol And thank you everyone ellse who contributed I have learned a lot and there are no words good enough for the gratitude you guys deserve!
