11 Replies Latest reply on Aug 16, 2011 9:08 AM by r4raghs
    How to put the html text in Tooltip?
    Jessie_Meta
      Hi all,
      May i know how to display the html text using Tooltip?
      Thanks.
      Regards,
      Jessie
        • 2. Re: How to put the html text in Tooltip?
          Kanchan Ladwani Level 2
          Hello Jessie,
            here is the code for it
          Main.mxml
                         xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" >
              <mx:Button x="266" y="214" label="Button" id="Btn" mouseOver="init(event)"  />
              <fx:Script>
                  <![CDATA[
                      import com.Htmltip;
                      import mx.controls.Alert;
                      import mx.controls.ToolTip;
                      import mx.managers.ToolTipManager;
                      public  function init(evt:MouseEvent):void{
                      ToolTipManager.toolTipClass=Htmltip;          //Htmltip is action script class
                      var tip2:String;
                      tip2 = "<font color='#076baa' size='+4'><b>Quickly format your tooltips:</b></font><br><br>";
                      tip2 += "<b>Create lists:</b> <li>item 1</li><li>item 2</li><br>";
                      tip2 += "<b>Align your text:</b><br>";
                      tip2 += "<p align='left'>Left aligned text</p>";
                      tip2 += "<p align='right'>Right aligned text</p>";
                      tip2 += "<p align='center'>Centered text</p>";
                      Btn.toolTip=tip2;
              </fx:Script>
          </s:Application>
          Action script class
          package com
              import mx.controls.Text;
              public class Htmltip extends ToolTip
                  public function Htmltip()
                  {    super(); }
                  override protected function commitProperties():void{
                      super.commitProperties();
                      textField.htmlText=text;
          Thanks and Regards,
          Kanchan Ladwani | kladwani@infocepts.com | www.infocepts.com
          • 3. Re: How to put the html text in Tooltip?
            Jessie_Meta Level 1
            Hi r4raghs & Kanchan Ladwani, thanks for the help.
            Kanchan Ladwani, i alr tried your example but I got an error (Parse error at '<font>').
            The different thing is I'm using MXML Component NOT MXML Application but why the code can't working in MXML Component???
            Regards,
            Jessie
            • 4. Re: How to put the html text in Tooltip?
              r4raghs Level 1
              you can follow the link i have provided to get tooltip in custom component.
              • 5. Re: How to put the html text in Tooltip?
                Jessie_Meta Level 1
                Hi r4raghs,
                I already followed the link that you have provided but not successful. It will come out with the error (Parse error at '<strong>'.)
                Regards,
                Jessie
                • 6. Re: How to put the html text in Tooltip?
                  Hi Jessie,
                    I tried same code with MXML component as well its not giving me any such error,working as expected in both FB3 & FB4
                  <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
                           xmlns:mx="library://ns.adobe.com/flex/mx" width="400" height="300">
                      <fx:Script>
                          <![CDATA[
                              import com.Htmltip;
                                  var tip2:String;
                                  Btn.toolTip=tip2;
                      </fx:Script>
                  </s:Group>
                    i guess there is some other issue,could u pls paste code snippet?? so that we can work on it
                  Thanks and Regards,
                  • 7. Re: How to put the html text in Tooltip?
                    EvyatarBH Level 3
                    I suggest to read the following -
                    http://help.adobe.com/en_US/flex/using/WS2db454920e96a9e51e63e3d11c0bf60d65-7ff6.html
                    You can scroll to the section named "Implementing the IToolTip interface"
                    Their example seems like exactly what you are looking for and I implemented it successfully, but with some important differences -
                    <s:Panel xmlns:fx="http://ns.adobe.com/mxml/2009"
                               implements="mx.core.IToolTip" backgroundColor="#F9F9DD"
                               width="{textContent.width+5}" height="{textContent.height+5}" alpha="0.95"
                               skinClass="com.xxx.yyy.zzz.skin.PanelWithoutTitleSkin">
                         <fx:Script>
                              <![CDATA[
                                   import com.xxx.yyy.zzz.skin.PanelWithoutTitleSkin;
                                   import flashx.textLayout.conversion.TextConverter;
                                   import mx.core.IToolTip;
                                   [Bindable]
                                   public var bodyText:String;
                                   public var _text:String;
                                   private static var _toolTipInstance:PanelToolTip;
                                   public function get text():String{
                                        return _text;
                                   public function set text(value:String):void{
                                   public static function getInstance(toolTipText:String):PanelToolTip{
                                        if(_toolTipInstance==null){
                                             _toolTipInstance = new PanelToolTip();
                                        _toolTipInstance.bodyText = toolTipText;
                                        return _toolTipInstance;
                         </fx:Script>
                         <s:RichText id="textContent" paddingLeft="4" paddingTop="2" backgroundAlpha="0"
                              textFlow="{TextConverter.importToFlow(bodyText,TextConverter.TEXT_FIELD_HTML_FORMAT)}"
                    </s:Panel>
                    • 8. Re: How to put the html text in Tooltip?
                      Jessie_Meta Level 1
                      Thanks EvyatarBH & Kanchan Ladwani for your replied.
                      I'm using flex 4.5 with flex SDK Flex3.6. Below is my sample code with the error (Access of undefined property Htmltip).
                      Test.mxml (MXML Component)
                      <mx:Canvas
                      xmlns:mx="http://www.adobe.com/2006/mxml" width="400" height="300">
                      <mx:Script>
                      <![CDATA[
                      import com.Htmltip;
                      var tip2:String;
                      Btn.toolTip=tip2;
                      </mx:Script>
                      </mx:Canvas>
                      Regards,
                      Jessie
                      • 9. Re: How to put the html text in Tooltip?
                        Hello,
                        Htmltip is your actionscript class,make sure its in the folder named com.(u can chose any folder name just import it accordingly)
                        Htmltip.as
                        package com
                                {    super(); }
                        Thanks and Regards,
                        • 10. Re: How to put the html text in Tooltip?
                          Jessie_Meta Level 1
                          I already put an actionscript class(Htmltip.as) in the folder named com BUT I still got the error (Parse error at '<font>').
                          I really do not know why this will happen?
                          Regards,
                          Jessie
                          • 11. Re: How to put the html text in Tooltip?
                            r4raghs Level 1
                            Have change nothing with your code, works perfect.
