4 Replies Latest reply on Aug 13, 2011 7:23 AM by Richard M Knight
    Export times
    Richard M Knight Adobe Community Professional & MVP
      Premiere CS5.5
      2.8 Gig i7
      24 Gb ram
      Windows 7 64
      I have just set up the following workflow and I am getting a final export/render speed of about 7 frames/sec is this about right?
      2hr 1080 25i timeline with two video tracks with colour correction
      Export via frame server, HQ
      HD to SD script using Avisynth
      convert to Mpeg 2 dvd using two pass 5Mb/sec average, best quality HC encoder.
      Total time for both passes is about 12hr.
      Richard Knight
        • 1. Re: Export times
          Harm Millaard Level 7
          How are your export times when using MPEG2-DVD with similar settings instead of using Frameserver and Avisynth?
          What color correction was used? MBL or PR? What is your source codec? Length of the timeline? What video card and what disk setup?
          • 2. Re: Export times
            Time line 2 hours Sony EX 1080 25i
            Colour correction Premiere Three-way
            Video card Nvidia GTS 450 with cuda hack
            Black Magic EX sequence
            Source hdd, 2 caviare  black in raid 1- 4Tb
            destination hdd raid 1- 3Tb
            Time using Premiere dvd mpeg2 encoding only about 5 hrs.
            • 3. Re: Export times
              That makes a lot more sense and could possibly be improved upon further without BM. So the long encoding times can be attributed to Frameserver/Avisynth.
              • 4. Re: Export times
                One version of my video included a 4min section where one video stream had 3 soft edge linear wipes. That section rendered at 0.5 fps and the whole film took 17 hours to render. It is often said that you should have a cup of coffee while rendering, I could have gone on holiday!
                While rendering the cpu meter shows 15% usage and the ram 45% are there any ways to use more of my computers power? Do AVIsynth and HC encoder make use of 64 bit computing and multi processors (like the i7)?
