6 Replies Latest reply on Aug 14, 2011 5:59 PM by swimmer12
    60fps Video showing Jittery/repeat Frames?
    swimmer12
      I have 59.94fps video in a 59.94fps comp, the video is 720p and is recorded from a HD Capture card. When I put the clip into After effects cs5, I get a strange jittery, repeat frame effect. It is only in a couple parts of the clip, but the strange thing is, in anyother video player/ editing software, it is fine, no repeat.
      Basically what im getting is this, every so often, there is a jitter in the video, like so, it goes Frame 1-2-3-2-3-4-5-4-5-6-7-6-7-8-9. Its very annoying and renders the video usless. The video is .mp4
      Thanks in advance for the help!
      my specs are, Windows 7, AE CS5, ATI radeon HD GPU, 6GB RAM.
        • 1. Re: 60fps Video showing Jittery/repeat Frames?
          Does AE report any pending conforms (media pending)? To what location are you capturing? The problem occuring only in parts would indicate that there were hiccups during capture/ transfer eitehr due to genuine disk performance issue or the drive being fragmented. Also not much point comparing it with external players - VLC et al never show you every discrete frame as AE would and since your eyes are to slow, anyway, they will skip damaged data or reconstruct it from frames farther away, none of which AE does.
          Mylenium
          • 2. Re: 60fps Video showing Jittery/repeat Frames?
            swimmer12 Level 1
            Well I dont think it has to do with the capture, because i have captured and rendered it as .mp4 from the sorce, witch is also .mp4, im importing a render clip that is saved onto my hard drive.
            • 4. Re: 60fps Video showing Jittery/repeat Frames?
              swimmer12 Level 1
              Im not positive, but this might be helpful to know. The Capture card records at a frame rate of 60.006fps, which I then render to 59.94fps .mp4
              • 5. Re: 60fps Video showing Jittery/repeat Frames?
                Todd_Kopriva Level 8
                That is very strange.
                • 6. Re: 60fps Video showing Jittery/repeat Frames?
                  swimmer12 Level 1
                  Here is Captured file info:
                  Format                           : MPEG-4
                  Format profile                   : 3GPP Media Release 4
                  Codec ID                         : 3gp4
                  File size                        : 974 MiB
                  Duration                         : 10mn 20s
                  Overall bit rate                 : 13.2 Mbps
                  Video
                  Format                           : AVC
                  Format/Info                      : Advanced Video Codec
                  Format profile                   : Main@L4.0
                  Format settings, CABAC           : Yes
                  Format settings, ReFrames        : 4 frames
                  Format settings, GOP             : M=4, N=32
                  Codec ID                         : avc1
                  Codec ID/Info                    : Advanced Video Coding
                  Duration                         : 10mn 20s
                  Bit rate mode                    : Variable
                  Bit rate                         : 12.9 Mbps
                  Maximum bit rate                 : 20.0 Mbps
                  Width                            : 1 280 pixels
                  Height                           : 720 pixels
                  Display aspect ratio             : 16:9
                  Frame rate mode                  : Variable
                  Frame rate                       : 59.940 fps
                  Minimum frame rate               : 59.887 fps
                  Maximum frame rate               : 60.006 fps
                  Color space                      : YUV
                  Chroma subsampling               : 4:2:0
                  Bit depth                        : 8 bits
                  Scan type                        : Progressive
                  Bits/(Pixel*Frame)               : 0.234
                  Stream size                      : 958 MiB (98%)
