2 Replies Latest reply on Aug 14, 2011 3:04 PM by JJMack
    Photoshop action for photobooth strip effect
    davidadamphotog
      I have a few hundred photos that I'd like to turn into a photo booth "strip".  Basically I'd like to take 4 images and add them to a template so that it looks like they were created in a photobooth and printed as a sequence strip.  I've used actions for this, but the problem is that everytime I run the action, it looks for the same exact file to use, instead of the next set of 4 in the sequence.  How can I create an action or script, so that it takes the next group of four images instead of using the same four over and over?
      Thanks in advance for your help!
        • 1. Re: Photoshop action for photobooth strip effect
          c.pfaffenbichler Level 9
          I’m afraid Actions would not suffice for the task, Scripting should be able to handle it, though.
          But maybe an existing contact sheet-Script or even Bridge’s functionality may work for your intended output?
          • 2. Re: Photoshop action for photobooth strip effect
            You could do that using a Photo Collage Template for a photo booth strip.  Today I added a modified version of Rags Gardner www.rags-int-inc.com Copyright (c) 2006 CollageBuilder script to my Photoshop Photo Collage Toolkit package that would be able to build the template you need.  The scripts in the toolkit could then be used to populate the template with your images.
            Photo Collage Toolkit UPDATED Aug. 14, 2011 added a modified version of Rags Gardner www.rags-int-inc.com Copyright (c) 2006 CollageBuilder script.
            Documentation and Examples
            Download
            To make the template set the width to 5" and the height 25" for the paper size.
            select the none large image option
            Small images 4" wide 6" high
            4 Rows 1 column
            Once the collages are built you can edit them and crop off the side margins by using Canvas size and setting the width to 4". so you can print them on 4: roll paper.
            Or you could install Photoshop's Contact Sheet II plug-in from Adobe's CS5 optional plug-ins download and do the same without a pemplate.
