2 Replies Latest reply on Aug 15, 2011 2:35 PM by almakana1
    Load external swf problem
      I think this is my last station to find the answer of my big problem
      I made a simple project  with flash CS5 which contain
      main swf which load external swf  in to empty movie
      I could manage to load all external swf smoothly but
      the external swf has drag and drop work perfect alone but when it is called stops working
      input text in external swf also do not work when it called
      I browsed the net for one week and could not find the answer
      Pllllllllllllllllllllllease help
      Thanks in advance
        • 1. Re: Load external swf problem
          Does the loaded file use _root references?  If so, you need to set the _lockroot property to true inside that file so that it is not looking beyond itself to the _root of the file that loads it.  If you are not familiar with it, it is documented in the Flash help files with examples.
          • 2. Re: Load external swf problem
            almakana1 Level 1
            Thanks for your replay
            The problem is half solved now
            I can drag now but the reward mc which inside the external swf do not function properly
            The second problem
            Input text do not function in fullscreen mode while it works in normal
            Can I solve this problem????
            I read alot and couldnt find the key
            thanks in advance
