3 Replies Latest reply on Oct 11, 2011 12:27 AM by robert-sfl
    ü in RH 8 WebHelp replaced with ü
    Mike1813 Level 1
      I am working with a German language project. When I generate WebHelp, the umlaut-ed characters display and work fine. When I publish the WebHelp to our server, URLs that include umlaut-ed characters are broken because they are replaced with ü.
      I'm using RoboHelp 8, the latest update, with Windows XP. The server uses TomCat 5.5.
      Thanks for any suggestions. I apologize if this is a duplicate topic, I did not find any relevant matches when searching with Google.
      Mike
        • 1. Re: ü in RH 8 WebHelp replaced with ü
          robert-sfl Level 1
          I have encountered exactly the same problem, evidently it is a coding error. The topics generated by RoboHelp 9 are correctly UTF-8 coded. Can this be a problem of the server application? Have you found a solution?
          Robert
          • 2. Re: ü in RH 8 WebHelp replaced with ü
            Mike1813 Level 1
            Hi Robert,
            It appears to be a server issue - I think it is related to an older
            version of Apache web server, but can't prove it. It was not fixed -
            here's what I had to do:
               - Remove all umlaat characters from directory paths by modifying
            folder names and RH book names as required.
               - Rename the German version of the Related Topics button so  the code
            for related topics does not include an umlaat character.
               - Then I am stuck with manually replacing the image for the Related
            topics button with a button that uses the correctly-written German for
            Related Topics every time I regenerate the help systems for deployment!
            Hope that helps, but expect you've already figured out the workaround.
            Sorry for the delay.
            I think if I had access to server resources, I would try upgrading to a
            recent version of Apache server.
            Mike
            • 3. Re: ü in RH 8 WebHelp replaced with ü
              robert-sfl Level 1
              Mike,
              thanks for the feedback, yes we settled on manually removing umlauts in
              filenames too.
              Robert
