3 Replies Latest reply on Aug 18, 2011 12:06 AM by aditya206
    LineChart: How to have fixed interval on X-axis
    aditya206
      Hi All,
      I am flex newbie. I am trying to figureout how to have fixed interval (say 7) of X-axis in a LineChart. I have tried AxisRenderer, CategoryAxis and DateAxis to no avail. Can you refer to an example or a snippet which would help to resolve this problem.I have pasted my code here below. Thanks in advance.
      <mx:LineChart
      id="DOLoginGraph" dataProvider="{doLoginGraphData}" paddingTop="10" width="100%" height="100%"
      showDataTips="
      true" backgroundElements="{gridLinesDOL}" >
      <!-- vertical Value axis -->
      <mx:verticalAxis>
      <mx:LinearAxis baseAtZero="true" maximum="40" interval="10" />
      </mx:verticalAxis>
      <!-- Horizontal Date axis -->
      <mx:horizontalAxis>
      <mx:CategoryAxis id="horiDateAxis" categoryField="date" />
      </mx:horizontalAxis>
      <mx:horizontalAxisRenderers>
      <mx:AxisRenderer placement="bottom" axis="{horiDateAxis}"/>
      </mx:horizontalAxisRenderers>
      <!-- Series -->
      <mx:series>
      <mx:LineSeries yField="value"  showDataEffect="{chartEffect}" form="curve" displayName="Open" >
      <mx:lineStroke>
      <mx:SolidColorStroke color="#32cd32" weight="2" alpha=".8"/>
      </mx:lineStroke>
      </mx:LineSeries>
      </mx:series>
      </mx:LineChart>
        • 1. Re: LineChart: How to have fixed interval on X-axis
          Karl_Sigiscar_1971 Level 3
          LinearAxis:
              //  interval
               *  @private
              private var _userInterval:Number;
              [Inspectable(category="General")]
               *  Specifies the numeric difference between label values along the axis.
               *  Flex calculates the interval if this property
               *  is set to <code>NaN</code>.
               *  The default value is <code>NaN</code>.
               *  @langversion 3.0
               *  @playerversion Flash 9
               *  @playerversion AIR 1.1
               *  @productversion Flex 3
              public function get interval():Number
                  return computedInterval;
               *  @private
              public function set interval(value:Number):void
                  if (value <= 0)
                      value = NaN;
                  _userInterval = value;
                  computedInterval = value;
                  invalidateCache();
                  dispatchEvent(new Event("axisChange"));
          • 2. Re: LineChart: How to have fixed interval on X-axis
            aditya206 Level 1
            Hi Karl,
                     Thank you so much for the help. I am using CategoryAxis with date as X-axis input values. Does this code still stands valid with my requirement?
                 <mx:horizontalAxis>
                      <mx:AxisRenderer placement="bottom" axis=""/>
            Thanks in advance again.
            Aditya206
            • 3. Re: LineChart: How to have fixed interval on X-axis
              aditya206 Level 1
                   I tried the above example with numerical values on X-axis and seems to work fine, but my requirement has Date on this axis. when I am using the interval attribute on this LinearAxis tag, it seems  vary with the input chart data. How can I have a fixed number of intervals independent of input chart data?
              Thanks in advance.
              Aditya206
