0 Replies Latest reply on Aug 15, 2011 1:31 PM by maretron
    What is the proper way to create a socket?
    maretron
      I am using Flash Professional CS5.5, and have the following code to connect to an IP camera.
      331:            // Connect to the camera using a Socket
      332:            this.webcamSocket = new Socket();
      333:            this.webcamSocket.addEventListener(Event.CONNECT, OnConnect);
      334:            this.webcamSocket.addEventListener(ProgressEvent.SOCKET_DATA, OnData);
      335:            this.webcamSocket.addEventListener(IOErrorEvent.IO_ERROR, OnIOError );
      336:            this.webcamSocket.connect(this.camera.IPAddress, PORT_NO);
      which works perfectly most of the time.
      The whole function is surrounded by a try {  } catch ( e : Error ) {  } block which is never triggered.
      However, every now and then, when the camera is unplugged or not present, the line
      comes up with the following trace statements, and puts a window up for all to see ...
      Error #2044: Unhandled IOErrorEvent:. text=Error #2031: Socket Error.
          at MyVideo/Update()[AxisVideo::frame1:332]
      This means that it is possible for the Socket constructor to generate a SocketError.
      so
      1. What kind of error is the Socket Error ( IOErrorEvent does not list this as a constant )?
      2. If  you can only add event listeners after you create the Socket, how to do create an EventListener to catch this event in the constructor?
      Anyone?
