I want to create a simple survey that would run as an Air App on a sand alone desktop, using Builder and Catalyst. I would create a simple 5 question survey with radio buttons in Catalyst and then bring it into Builder to finish. However, I have no idea what to link it to, to collect the data. So, can anyone tell me if I can do this with in builder? If so what program would I need to be running locally to collect the data? Access, Excel, Notepad? Is there a tutorial online that covers this because I have not had any luck finding one? If anyone could give me some direction that would be great!
Something like this? http://www.adobe.com/devnet/flex/samples/survey-ape-application.html
If you open Flash Builder, the first thing you will see is the start page, which has all kinds of quick starts to get you going.
Thanks Rangora! Just what I was looking for.
This sample does not implement the "server part" so your data aren't really accessible outside of your app. For this part, you could use an AS3 library (for xls, pdf or anything you want) or simply write a XML and send it to a webserver or write it to the sdcard.
If you have more questions about this, just ask them!
