2 Replies Latest reply on Aug 17, 2011 11:35 AM by beh_gras_beh
    Not present than skip lines
    beh_gras_beh Level 1
      Dear people,
      Is it possible for InDesign to skip rules in the script if something is not present?
      Il try to illustrate what I mean:
      //Map the XML tags to the defined styles.
      var myDocument = app.documents.item(0);
      //Part 1.
      myDocument.xmlImportMaps.add(myDocument.xmlTags.item("TAGNAME_1"),
      myDocument.paragraphStyles.item("myparagraphStyle_1"));
      myDocument.xmlImportMaps.add(myDocument.xmlTags.item("TAGNAME_2"),
      myDocument.paragraphStyles.item("myparagraphStyle_2"));
      myDocument.xmlImportMaps.add(myDocument.xmlTags.item("TAGNAME_3"),
      myDocument.paragraphStyles.item("myparagraphStyle_3"));
      //Part 2.
      myDocument.xmlImportMaps.add(myDocument.xmlTags.item("TAGNAME_a1"),
      myDocument.xmlImportMaps.add(myDocument.xmlTags.item("TAGNAME_a2"),
      myDocument.xmlImportMaps.add(myDocument.xmlTags.item("TAGNAME_a3"),
      myDocument.mapXMLTagsToStyles();
      Part 2 is not present in the InDesign document so the script returns with an error that he cannot find Part 2.
      So is it possible to run the script like:
      If part 1 and 2 is present go on
      If part 2 is NOT present ignore and go on.
      Already thanks for the help!
      Greetings from Holland!
        • 1. Re: Not present than skip lines
          2i_Geert Level 1
          Do you mean something like this (not tested):
          //Part 1.
          //Part 2.
          if(myDocument.xmlTags.item("TAGNAME_a1") != null)
          • 2. Re: Not present than skip lines
            Wonderful!!!
            Tested with allot more tags and indeed, Indesign is not giving me a error, just great!
            Want' to give you five stars but the forum dosn't allow that
            Greetings!
