1 Reply Latest reply on Aug 16, 2011 11:13 PM by John Hawkinson
    [CS5][JSX] File from the web?
    James Robinson
      Is it possible to use a file from the web?
      For instance I have an xsl file I want to use that is at a domain:
      http://www.someserver.net/myxsl.xsl
      If I use File('http://www.someserver.net/myxsl.xsl') it tries to start searching for 'http://www.someserver.net/myxsl.xsl' from the scripts path:
      C:\Program Files\Adobe\Adobe InDesign CS5\Scripts\XHTML for Digital Editions\http:\someserver.net\myxml.xsl
      which does not exist. If I use a string it simply says
      ""http://www.someserver.net/myxsl.xsl""
      does not exist (not sure why quotes are doubled around it).
      The error is thrown when I go to open the XML file with the transform variable:
      cDoc.xmlImportPreferences.allowTransform = true;
      cDoc.xmlImportPreferences.transformFilename = defaultPathImportXSL;
      cDoc.importXML( XMLFilePath );
      defaultPathImportXSL is the variable contianing the path to to the XSL file (wrapped in File() or not -- this is the variable that is not found).
      XMLFilePath is the variable contianing the path to the XML file which works (can be found).
      Is there a way to use a web URL as a usable file in InDesign?
