3 Replies Latest reply on Aug 24, 2011 5:11 AM by mattdwm
    Scroller component speed
    mattdwm Level 1
      Does anyone have any tips for dealing with the speed of the Scroller component (the mouse wheel speed specifically). It scrolls either way to fast or way to slow.
        • 1. Re: Scroller component speed
          _spoboyle Level 4
          I had a similar issue and implemented a fixed speed scroller (i.e. not dependant on scroller height/width)
          subclass VScrollBar/HScrollBar
          add the following function (this is my code for the VScrollBar
          override mx_internal function mouseWheelHandler(event:MouseEvent):void
                      const vp:IViewport = viewport;
                      if (event.isDefaultPrevented() || !vp || !vp.visible)
                          return;
                      var delta:Number = event.delta;
                      var direction:Number = 0;
                      var distance:Number = 20;
                      // figure out the direction of scroll
                      if (delta < 0){
                          direction = 1;
                      } else if (delta == 0){
                          direction = 0;
                      } else {
                          direction = -1;
                      vp.verticalScrollPosition += distance * direction;
                      event.preventDefault();
          and then applly these scrollbars in your ScrollerSkin
          • 2. Re: Scroller component speed
            Shongrunden Adobe Employee
            This should be easier in Flex 4.5: http://bugs.adobe.com/jira/browse/SDK-26432
            • 3. Re: Scroller component speed
              mattdwm Level 1
              I'm using Flash Builder 4.5, doesn't seem to be easier.
