7 Replies Latest reply on Aug 17, 2011 12:50 PM by Diana Densmore
    Issue of configuring the Start Point when migrating to ES2
    Han Dao Level 1
      Hello,
      I am trying to migrating the 8.x process to ES2 to start to take the advantages of the new ES2 but keep having an issue of configuring the new Start Point.
      Here are the steps that I have done by the following steps from the captivate recording "Migrating an Application from Adobe® LiveCycle® ES to ES2" web site:
      - Export 8.x process to the .lca file
      - Import it in AdminUI ES2
      - Create a new application and import all legacy items
      - Reset the Deployment ID
      - Refactoring the process by adding the new Start Point in ES2 but having issue of selecting a variable in the "Presentation & Data" with the error "incompatible variable 'formData' selected' in the Variable drop down list.
      Can any one please advise how to fix this issue.
      Thanks in advance,
      Han Dao
        • 1. Re: Issue of configuring the Start Point when migrating to ES2
          Diana Densmore Level 3
          Hi
          Are you trying to use your old 8.x variable?
          As of 9.0, you need to be using a variable of type xml or document on the Presentation & Data tab.
          Diana
          • 2. Re: Issue of configuring the Start Point when migrating to ES2
            Han Dao Level 1
            Hi Diana,
            Because of the incompatible variable, I just created a new xml variable but having an issue of opening form in the workspace ES2 with the below error.
            Thanks, Han
            • 3. Re: Issue of configuring the Start Point when migrating to ES2
              Hi Han
              There could be many reasons for the startpoint not rendering...I can't tell from what you have provided.
              You need to look in the server log to see what caused the error.
              Diana
              • 4. Re: Issue of configuring the Start Point when migrating to ES2
                Han Dao Level 1
                Hi Diana,
                Here are some errors that I got from the log file:
                [8/17/11 10:04:02:999 CDT] 0000006d SystemOut     O [LCDS][ERROR] Exception when invoking service 'remoting-service': flex.messaging.MessageException: ALC-WKS-005-055: An error occurred while retrieving endpoints based on a collection of endpoint ids.
                  incomingMessage: Flex Message (flex.messaging.messages.RemotingMessage)
                    operation = invoke
                    parameters = [4E295FB1-25A0-C20E-186D-40A81E0F7E84, 6004]
                    clientId = B10107EE-BF0C-60F7-BA86-A69EB91FF417
                    destination = endpoint-actions
                    messageId = A4A22AC4-17D2-0518-DF87-D8453DA647EA
                    timestamp = 1313593441327
                    timeToLive = 0
                    body = null
                    hdr(DSId) = B10061D7-370A-EC3F-B14A-945D54D84735
                    hdr(DSEndpoint) = workspace-polling-amf
                  Exception: flex.messaging.MessageException: ALC-WKS-005-055: An error occurred while retrieving endpoints based on a collection of endpoint ids.
                Caused by: java.lang.RuntimeException: Process asset reference could not be resolved. Is this application/asset deployed?  Design Time path: /Process Management (system)/1.0/Submit PDF Form.process
                at com.adobe.idp.taskmanager.dsc.util.TLOUtil.getTLORuntimeInfo(TLOUtil.java:249)
                at com.adobe.idp.taskmanager.dsc.service.TaskEndpointManagerImpl.processDCIServiceCall(TaskE ndpointManagerImpl.java:657)
                at com.adobe.idp.taskmanager.dsc.service.TaskEndpointManagerImpl.processDCI(TaskEndpointMana gerImpl.java:760)
                at com.adobe.idp.taskmanager.dsc.service.TaskEndpointManagerImpl.invokeEndpoint(TaskEndpoint ManagerImpl.java:616)
                at com.adobe.idp.taskmanager.dsc.service.TaskEndpointManagerImpl.invokeEndpoint(TaskEndpoint ManagerImpl.java:362)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:64)
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
                at java.lang.reflect.Method.invoke(Method.java:615)
                at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
                at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
                at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
                at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassi vationInterceptor.java:53)
                at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
                at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:357)
                at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(Ej bTransactionCMTAdapterBean.java:227)
                at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionCMTAdapter_ caf58c4f.doSupports(Unknown Source)
                • 5. Re: Issue of configuring the Start Point when migrating to ES2
                  The caused by section tells you what the problem is:
                  Make sure your Process Management (system)/1.0/Submit PDF Form.process is deployed.
                  This is a system app and should always be deployed.
                  Diana
                  • 6. Re: Issue of configuring the Start Point when migrating to ES2
                    Han Dao Level 1
                    Should it be automatically deployed when the ES 2 is installed? I can see they are available and and active in the Processes list in Workbench ES 9.5.
                    If that is not the one, can you please advise on how to deploy it to make it works correctly.
                    Thanks alot again,
                    Han Dao
                    • 7. Re: Issue of configuring the Start Point when migrating to ES2
                      Yes this application should be deployed automatically when you install the server.
                      Looking in the Processes view in Workbench is not the right place to look.
                      You should look in the Adminui->Applications and Services->Service Management and confirm that it is in a Running state.
                      Diana
