4 Replies Latest reply on Aug 17, 2011 4:59 AM by Vibhuti Gosavi(InfoCepts)
    how to restrict a particular column values in a datagrid in flex4 app
    Venkatesan Balasubramanian
      hi friends,
      i am using a datagrid with 3 columns. Already i entered stings in first two columns,now i want to restrict the 3rd,it should allow numbers only,
      do not accept characters and special characters,
      how to restrcit a particular column value,
      any suggession or snippet code are welcome
      B.venkatesan
        • 1. Re: how to restrict a particular column values in a datagrid in flex4 app
          miguel8312 Level 3
          put an item renderer in the column and then put a validator on the it
          em renderer.
          miguel
          • 2. Re: how to restrict a particular column values in a datagrid in flex4 app
            Vibhuti Gosavi(InfoCepts) Level 3
            Following code may help you.
               xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
            <fx:Declarations>
            <!-- Place non-visual elements (e.g., services, value objects) here -->
            <s:NumberValidator id="validate" source="{txt}" property="text"  domain="int" />
            </fx:Declarations>
            <fx:Script>
            <![CDATA[
            import mx.collections.ArrayCollection;
            [Bindable]
            public var arr:ArrayCollection=new ArrayCollection([{A1:"aaa" , B1: "bbb"}]);
            </fx:Script>
            <s:DataGrid id="Dg1" x="67" y="97" width="379" editable="true"  dataProvider="{arr}" >
            <s:columns>
            <s:ArrayList>
            <s:GridColumn dataField="A1" headerText="Column 1"></s:GridColumn>
            <s:GridColumn  dataField="B1" headerText="Column 2"></s:GridColumn>
            <s:GridColumn id="col"  headerText="Column 3"  >
            <s:itemRenderer>
            <fx:Component>
            <s:GridItemRenderer>
            <s:TextInput id="txt"/>
            </s:GridItemRenderer>
            </fx:Component>
            </s:itemRenderer>
            </s:GridColumn>
            </s:ArrayList>
            </s:columns>
            </s:DataGrid>
            </s:Application>
            Thanks and Regards,
            Vibhuti Gosavi | vgosavi@infocepts.com | www.infocepts.com
            • 3. Re: how to restrict a particular column values in a datagrid in flex4 app
              kokorito Level 4
              use the restrict property of the itemrenderer textInput
              txt.restrict(0-9);
              will only allow digits between 0 and 9 to be input to the box
              txt.restrict(\\-.0-9);
              allows negative and decimal numbers
              • 4. Re: how to restrict a particular column values in a datagrid in flex4 app
                hi,
                It works :
                <fx:Declarations>
                </fx:Declarations>
                <fx:Script>
                <![CDATA[
                [Bindable]
                </fx:Script>
                <s:columns>
                <s:ArrayList>
                <s:itemRenderer>
                <fx:Component>
                <s:TextInput id="txt" restrict="0-9"/>
                </fx:Component>
                </s:itemRenderer>
                </s:GridColumn>
                </s:ArrayList>
                </s:columns>
                </s:DataGrid>
                </s:Application>
                Thanks and Regards,
