0 Replies Latest reply on Aug 17, 2011 8:04 AM by fpsmonkey
    How to fix exit code 4 on ADL
    fpsmonkey
      I'm trying to build an application using a trial version of FlashBuilder 4, using SDK 4.1. The SDK has AIR 2.0.2 overlayed.
      When I run my ant builds, it all works as expected, but running adl from the command line, or from within FlashBuilder the app just terminates.
      I inspected the exit code, and got code 4.
      The last information I found was that exit code 4 means I had a version conflict. What I don't understand is that my ant build points to the same SDK I try to run from the command line, and the same SDK configured in FlashBuilder.
      Then I figured it might be the version of the runtime on my system, I downloaded an app called 'Version' (Air App), and it reports that I'm running Air 2.7, I cannot find an older version download for OSX.
      I'm really eager to try out FlashBuilder, and my trial is almost over, I have had no luck, and it's starting to drive me insane.
      Does anyone know what I am doing wrong?
