8 Replies Latest reply on Aug 28, 2006 3:22 PM by sanclementetech
    event.token.kind is undefined
    sanclementetech Level 1
      Page 1225 of the developers guide mentions that you can check the event.token.kind of a ResultEvent to determine what action was completed. However no matter what I do I am getting back an undefined value. Fill, Update/Save, Delete all work according to the database.
      example in the book
      private function resultHandler(event:ResultEvent):void {
      Hourglass.remove();
      if ( event.token.kind == "create") {
      dg.selectedIndex = contacts.length - 1;
      else if (event.token.kind == "delete" && contacts.length>0) {
      var index:int = event.token.index
      < contacts.length ? event.token.index : contacts.length -1;
      dg.selectedIndex = index;
      contact = contacts[index];
      else if (event.token.kind == "fill" && contacts.length>0) {
      dg.selectedIndex = 0;
      contact = contacts[0];
      I have tried the following
      DataMessage.getOperationAsString(DataMessage(event.token.message).operation)
      and it sort of works, but it gives me two messages on the return of a delete statement transactioned and delete.
      Any ideas?
        • 1. event.token.kind is undefined
          seth_hodgson Level 1
          Hi Ken,
          The transactioned result corresponds to the commit and the delete corresponds to the delete. DataService operations are sent within a batched or transactioned message and this will be the last result dispatched so if you want to use a general result handler you should base your post-completion processing on that.
          As for token.kind, that looks like a doc bug. The collection events use a 'kind' property, but the DataService events don't. You can inspect the token message operation on generic result events as you're doing or you may want to just add a responder (that wraps result and fault handler functions) to the token returned when you invoke dataService.commit().
          Seth
          • 2. Re: event.token.kind is undefined
            Thanks Seth -
            Right the documentation is wrong. But that is not the problem, it is a user experience issue. I want to know when something is saved or deleted or loaded (fill), meaning when the processing is done. I get an event back, but what it tells me is less useful now than it what the documentation eluded to - which is more of what I am looking for.
            • 3. event.token.kind is undefined
              Hi Ken,
              When you invoke fill() the asynchronous result or fault is dispatched and you can check the event.token.message.operation to see if it's in response to your fill or not. Like commit(), fill() returns an AsyncToken that you can add a result/fault responder to. AsyncToken is a dynamic class so you can also add whatever else you want to it. For example:
              var token:AsyncToken = ds.fill(...);
              token.kind = "fill";
              and then in your result handler you could look for your dynamic prop:
              if (token.kind != null && token.kind == "fill") ...
              The createItem() and deleteItem() methods work this way as well. Updates are the one operation that doesn't generate an AsyncToken because they are tracked implicitely and either auto-commited or commited as a batch when you call commit(). In the auto-commit case a result/fault event is dispatched upon completion and you can inspect event.token.message.operation to watch for them - no batched/transactioned event is dispatched because you didn't explicitely call commit(). When you're not using auto-commit, you'll get the same general events for updates/etc. but you'll also get the event for the commit itself.
              Best,
              Seth
              • 4. Re: event.token.kind is undefined
                Seth -
                I got all that. The problem is on the delete you actually get 2 messages. One for the delete and one for the commit (save). This is because the item is deleted, great, and then the commit happens. So for a logical unit of work you have problems with giving the user a message like "Your delete worked" because you then get "...and oh yea your save that you did not issue worked as well".
                And one other thing the token.kind is actually undefined. At least that is what I am getting back.
                Ken
                • 5. Re: event.token.kind is undefined
                  Hi Ken,
                  token.kind is undefined by default. However, token is an instance of AsyncToken, a dynamic class, so if you want to add a "kind" field to your tokens you can do that. The token (plus any additions you make to it) is handed back on the result or fault event so you can drive your completion processing that way. Sorry for any confusion there.
                  If you're in auto-commit mode you should only get one event for the deletion. If you're seeing two events in that case it's a bug. If you invoke commit() you should get one for the deletion and one for the commit. I'd recommend waiting for the result event for the commit to inform the user that the delete worked.
                  Best,
                  Seth
                  • 6. Re: event.token.kind is undefined
                    Seth -
                    That makes a liitle more sense. But how would one go about doing what you are talking about? Do you simply create a new AsyncToken("fill") then call ds.fill() and hope for the best? Or do you have to attach the token to the data service? Or do you set a configuration parameter? Or ???
                    The current documentation page 1225 of the Developer's Guide makes no mention of that, it appears that it just happens magically.
                    Thanks again.
                    Ken
                    • 7. Re: event.token.kind is undefined
                      The documentation on page 1225 of the dev guide is wrong. I've passed along a request to have it corrected.
                      If you look at the DataService API, you'll note that several methods (fill(), commit(), etc.) return an AsyncToken. This token is a dynamic class, meaning you can assign ad-hoc data to it, and the token instance will be returned along with the async result or fault event for the async call. It is the "T" in the Asynchronous Completion Token design pattern - used by DataService, RemoteObject, etc.
                      When you invoke fill() it returns an AsyncToken to you. You can add data/context to it like so:
                      private function doFirstStep():void {
                      var token:AsyncToken = ds.fill(... your fill args...);
                      // Add some custom info to the token
                      token.x = 10;
                      token.foo = "bar";
                      token.step = "1st fill";
                      Later, when the result event for this fill is dispatched it will have this same token attatched to it and you can access the data you've added to the token to drive your result processing:
                      if (event.token.x == 10) {
                      // Do something
                      trace(event.token.foo);
                      if (event.token.step = "1st fill") {
                      // Do your next step
                      Hope that helps,
                      Seth
                      • 8. Re: event.token.kind is undefined
                        Seth -
                        Actually I had not noticed. Thanks!
                        Ken
