3 Replies Latest reply on Aug 19, 2011 12:39 PM by Muppet Mark
    when I create a new polygon with applescript in in design cs4, I want to make a drop shadow
    filgu74
      Is it possible?
      I am working with MAC OS 10.6.7 and CS4
      Can somebody help me?
        • 1. Re: when I create a new polygon with applescript in in design cs4, I want to make a drop shadow
          S Hopkins Adobe Community Professional
          Here is a sample script you could modify. It was written for CS5.5 and creates a rectangle instead of a polygon. The property settings for drop shadow are self-explanatory. I haven't tested this in CS4, but the settings should be the same.
          (*Drop Shadow
          Creates a rectangle with a drop shadow. Assumes a document exists with measurements set to points and swatch "C=0 M=0 Y=100 K=0."*)
          tell application "Adobe InDesign CS5.5"
          set pageRef to page 1 of document 1
          set rectProps to {fill color:"C=0 M=0 Y=100 K=0", geometric bounds:{36, 36, 144, 144}}
          tell pageRef
          set rectRef to make rectangle with properties rectProps
          end tell
          tell rectRef
          set properties of fill transparency settings to {drop shadow settings:{mode:drop, distance:10, angle:135, spread:0, blend mode:multiply, opacity:75, honor other effects:false, x offset:7, y offset:7, knocked out:true, use global light:false}}
          end tell
          end tell
          • 2. Re: when I create a new polygon with applescript in in design cs4, I want to make a drop shadow
            filgu7N
            Thanks for your help! it works very well,sorry for my english but iam french!
            Just need some minor correction with fill color below
            I just have to test it with other shapes as polygons, circles...
            tell application "Adobe InDesign CS4"
                --set rectProps to {fill color:"C=0 M=0 Y=100 K=0", geometric bounds:{36, 36, 144, 144}}
                -- fill color don't work in cs4 : message "parametre incorrect"
                --set rectProps to {fill color:{swatch:"C=0 M=0 J=100 N="}, geometric bounds:{36, 36, 144, 144}}-- no more message!
                --this don't work the fill color is always "none" and drop shadow does not work with fil color none
              tell pageRef
                    set rectRef to make new rectangle with properties {fill color:"Paper", geometric bounds:{36, 36, 144, 144}}
                    -- this is ok in cs4
                end tell
                tell rectRef
                end tell
            end tell
            -- this works perfectly
            • 3. Re: when I create a new polygon with applescript in in design cs4, I want to make a drop shadow
              Muppet Mark Level 5
              Adding a drop shadow should work fine regardless of shape… As Im a big fan of using styles everywhere I can…
              tell application "Adobe InDesign CS5"
              activate
              tell the active document
              set GotNoStyle to make new object style
              set properties of drop shadow settings of fill transparency settings of GotNoStyle to ¬
              {mode:drop, distance:3, angle:135, spread:0, blend mode:multiply, opacity:50, honor other effects:true, x offset:3, y offset:3, knocked out:true, use global light:false}
              set SomeFill to the last swatch
              tell the first page
              make new rectangle with properties ¬
              {fill color:SomeFill, geometric bounds:{10, 10, 30, 30}}
              apply object style (the result) using GotNoStyle without clearing overrides
              make new oval with properties ¬
              {fill color:SomeFill, geometric bounds:{10, 40, 30, 70}}
              end tell
              end tell
              end tell
              You can then edit the object style to make global changes… Sorry my values were for my euro metric head…
