1. Re: Any way to save guide set to use again?
Grant H Aug 18, 2011 3:37 PM (in response to emilycornfield)create a guides.psd document. with the guides only and use it as a template to import or place other content...
G
2. Re: Any way to save guide set to use again?
emilycornfield Aug 18, 2011 3:42 PM (in response to Grant H)I am using the guides as a basis for a grid framework, which sometimes I might change after starting a document. I was hoping for something a little easier.
3. Re: Any way to save guide set to use again?
Grant H Aug 18, 2011 3:50 PM (in response to emilycornfield)wait a minute: you can record an action!!! Add al the guides and play in new doc.
G
4. Re: Any way to save guide set to use again?
Grant H Aug 18, 2011 3:53 PM (in response to emilycornfield)yep: just tested it... works perfectly, even on diferent size canvases albeit off the canvas if new doc much smaller...
G
5. Re: Any way to save guide set to use again?
MTSTUNER Aug 18, 2011 6:26 PM (in response to emilycornfield)For better placement of the guides, try changing the
ruler units to percent before recording the action.
MTSUNER
6. Re: Any way to save guide set to use again?
emilycornfield Aug 18, 2011 6:44 PM (in response to Grant H)Thanks-this is great, except I'd like to apply it to a document I already have. Is this possible? At this point when I run the action it opens a new document. I'm not experienced with actions, so maybe it's not set-up right?
7. Re: Any way to save guide set to use again?
emilycornfield Aug 18, 2011 6:47 PM (in response to emilycornfield)Never mind, I just fiddled with the actions and it looks straight forward. I just deleted the new doc step and it performed the grid on top of the current document I had opened. Just what I wanted! Thanks for your help!
