1 Reply Latest reply on Aug 19, 2011 10:18 AM by SForrest96
    Can't sign an .PDF document
    CapnJackSparrow
      Hello everybody! I have a problem regarding a digital signature!
      A month ago I bought an Oberthur token to sign some documents. I followed the guide and tryied to import the device in Mozilla Firefox. After a few atempts I have abandoned the idea and (also following the guide) I managed to import it in Explorer (the guide proved flawless). I have signed one document and all was ok.
      Yesterday I tryied to msign another document, but when I click the signature field I get the tab: Add digital ID. When I chose the "A device connected to this computer" option I got this message: "Acrobat could not find any new digital IDs..."!
      I have unistalled both Mozilla Firefox and Adobe Reader X and reinstalled them. I have managed to import the signature device in Mozilla, but I can't still sign documents!
      What is there to be done?
        • 1. Re: Can't sign an .PDF document
          SForrest96 Level 4
          I am not familiar with the Oberthur solution, but it sounds like from your description that it is a digital certificate stored on a hardware device.  If this is the case, Reader must be configured to access this device via a PKCS11 interface (driver, typically a DLL file).
          To access the security settings dialog in Reader where this configuration musrt be completed, select Edit > Protection > Security Settings...
          Select "PKCS#11 Modules and Tokens"
          You will then get a security warning...
          Select "Always open with Protected Mode disabled", click OK
          Click the "Attach Module" button to install the driver.
          This should resolve your issue.
          If you are using a "soft cert" (a digital certificate in file format such as PFX or P12) then you can ignore the PKCS#11 settings, and select the "Digital ID Files" option and click "Attach File"
          Hope this helps.
          Steve
