Here is my intall log:
Exit Code: 6
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 5 error(s), 1 warning(s)
----------- Payload: {650C9D09-D5BD-4532-8BEE-01DBC1DF5537} Adobe Flash Builder 4.5 4.5.0.0 -----------
ERROR: DW030: Custom Action for payload {650C9D09-D5BD-4532-8BEE-01DBC1DF5537} Adobe Flash Builder 4.5 4.5.0.0 returned error. Failing this payload.
WARNING: DW036: Payload cannot be installed due to dependent operation failure
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe Flash Builder 4.5: Install failed
ERROR: DW050: - AdobeHelp: Install failed
ERROR: DW050: - Adobe Flash Builder 4.5_4.5.1_AdobeFlashBuilder-mul: Install failed
I am also facing the similar problem.
can you pleas help me resolving it as soon as possible.
Exit Code: 6
- 0 fatal error(s), 13 error(s), 9 warning(s)
----------- Payload: {B6D38690-755E-4F40-A35A-23F8BC2B86AC} Microsoft_VC90_MFCLOC_x86 1.0.0.0 -----------
ERROR: Error 1935.An error occurred during the installation of assembly component {937FF758-7DED-3922-B192-1CA34A6D9AC2}. HRESULT: 0x80073712.
ERROR: Install MSI payload failed with error: 1603 - Fatal error during installation.
MSI Error message: Error 1935.An error occurred during the installation of assembly component {937FF758-7DED-3922-B192-1CA34A6D9AC2}. HRESULT: 0x80073712.
----------- Payload: {1B4483F2-849C-4AC3-99B1-473FFC0192DD} Adobe Flash Builder 4.5.0.0 -----------
ERROR: DW050: - Adobe Flash Player 10 Plugin: Install failed
ERROR: DW050: - Adobe Flash Player 10 ActiveX: Install failed
ERROR: DW050: - Microsoft_VC90_MFC_x86: Install failed
ERROR: DW050: - AdobeTypeSupport CS5: Install failed
ERROR: DW050: - Microsoft_VC90_MFCLOC_x86: Install failed
ERROR: DW050: - AdobeCMaps CS5: Install failed
ERROR: DW050: - Adobe Player for Embedding 3.2: Install failed
ERROR: DW050: - Suite Shared Configuration CS5.5: Install failed
Where are you finding this install log?
it shows in the installation window which opens while running the flashbuilder setup.
when the installation fails, i click on the troubleshoot , then these all error logs are shown.
hope its give u the sufficient info
Ahh, I'm doing a scripted, silent, unattended install. I'm hoping to find a way to get the logs going somewhere where they can be found.
Thanks for the response!
