This content has been marked as final.
Show 1 reply
1. Re: Photoshop to Flash
rezun8 Sep 20, 2012 3:38 PM (in response to NerdySyntax)what you can do is simple import the PSD from FLash itself. It should open a dialog box that will then prompt you to select which PSD layers you'd like to import into the new Flash document. Once you select them it brings them in on layers that you can then manipulate just as if you had created the Artwork from within Flash.
From there just animate the art as need. hit publish and your good to go
let me know if you need any further help.
Regards
Russ
