Graphics scaling issues in Flash Builder 4.5.1
rtalton Aug 20, 2011 7:33 AMPlease review this screen shot. Details follow the image.
FB 4.5.1
applicationDPI = "160"
Graphics using MultiDPIBitmapSource scale fairly well.
Graphics used for these properties do not scale well at all:
1) ViewMenuItem's "icon" property.
2) List itemRenderer IconItemRenderer "decorator" property.
3) TabbedViewNavigatorApplication's "splashScreenImage" property.
These graphics assets end up with horrible scaling artifacts, making them unusable. So, I cannot use icons with Menus or Lists or a splash image.
I've reviewed all of Adobe's documentation and followed all of their recommendations for creating graphics assets for use in a mobile applications. Simple graphics with no curved lines or angles less than 90 degrees scale well. Anything else does not.
Attached is a screen shot comparing the scaling issues at 160, 240 and 320 dpi with applicationDPI = "160". It is using an FXG graphic created in Illustrator CS5.5.
The FXG graphic was embedded in the s:IconItemRenderer like this: decorator = "{images.arrow_list_icon}".
For testing purposes, I also tried switching the decorator at runtime based on the applicationDPI, but of course this fails as the application still scales the graphic whenever the application's applicationDPI property is specified.
<s:List>
<s:itemRenderer>
<fx:Component>
<s:IconItemRenderer
decorator = "{chooseDecorator()}"
<fx:Script>
//This code selects a different FXG asset based on the DPI reported at runtime.
import images.arrow_list_icon160;
import images.arrow_list_icon240;
import images.arrow_list_icon320;
import mx.core.FlexGlobals;
protected function chooseDecorator():Class {
var rtnVal:Class;
switch (FlexGlobals.topLevelApplication.runtimeDPI) {
case mx.core.DPIClassification.DPI_160:
rtnVal=images.arrow_list_icon160;
break;
case mx.core.DPIClassification.DPI_240:
rtnVal=images.arrow_list_icon240;
break;
case mx.core.DPIClassification.DPI_320:
rtnVal=images.arrow_list_icon320;
break;
return rtnVal;
</fx:Script>
Has anyone come up with methods which can be used to avoid scaling issues with these items when setting the applicationDPI property?
