3 Replies Latest reply on Aug 21, 2011 6:00 PM by saisri2k2
    Application Scaling Issue
    Flex Rock Level 1
      Hi all,
                Application is getting scaled based on the width and height of div file. But components are not getting scaled. It was working in flex3. When i moved the project from Flex3 to Flex4 with same mxml code it is not working. Please anybody help me. I was struck with this for past two days.
      Regards,
      Jayagopal.
        • 1. Re: Application Scaling Issue
          saisri2k2 Level 4
          It might happen if you have explicit height and width on the components.
          • 2. Re: Application Scaling Issue
            Flex Rock Level 1
            You are exactly right saisri. But if i want to change the width and height to percentage i need to revamp the whole project. Is there any other way to solve it.
            Jayagopal.
            • 3. Re: Application Scaling Issue
              saisri2k2 Level 4
              I would try my hands on the applications scaleX and scaleY, I guess you already know the applciations standard height and width, if the app's height and width is more than the standard height/width calculate the scaling factor from the formula NewHeight/standardHeight = scaling factor(all this calculations has to be done in the JS), do this for width also.
              Next use java script external interfaces to call a method in flex passing down the scaleX and scaleY values to it which does this.scaleX = new value and same for scaleY.
              2nd option: group has resizeMode='scale' property, if the browser size increases(i.e. app height increases/decreses) then the content in the app scales. I would wrap the whole application in this tag and tweak.
