1. Re: code color php in htm and html documents
MurraySummers Aug 21, 2011 11:30 AM (in response to helennewton)If not, this is very bad thing as many old sites uses the html extension for php pages.
I would take issue with your use of the word "many", but I guess it's arguable at worst. I know that I have an ASP site that is set this way....
There is a way to make DW color code html files containing PHP - for the life of me I can't remember how. Why do you not want to 'come out' as it were, and just change your filenames over to a PHP extension? Are you hosted on Windows?
2. Re: code color php in htm and html documents
helennewton Aug 21, 2011 12:20 PM (in response to MurraySummers)Thanks, but,
To change the extension of the pages that been on first page in google, I prefer to use my old version of dreamweaver.
I found a way doing changes in a file, however it did not work.
Of course many persons do html pages and later they learn php and add php code to the html pages,
not only old websites has html pages,
cant understand why adobe did such a downgrade. The old version I used colored php in html pages.
3. Re: code color php in htm and html documents
John Waller Aug 21, 2011 1:09 PM (in response to helennewton)Try
http://kb2.adobe.com/cps/164/tn_16410.html
There has been no upgrade or downgrade in this functionality. No change at all.
If your older version used to code color PHP in HTML doucments then it must have been tweaked manually to do so at some point.
4. Re: code color php in htm and html documents
helennewton Aug 21, 2011 1:38 PM (in response to John Waller)Thanks, will try that one, already tried 2 that did not work,
Nop, I install and reinstall my dreamweaver without doing any changes at all,
the php code is being colored by default in html pages.
btw, its old, I use dreamweaver mx2004.
5. Re: code color php in htm and html documents
John Waller Aug 21, 2011 1:53 PM (in response to helennewton)Works here. CS5.
I used to use MX 2004 too and it never colored PHP code in HTM/HTML files on a fresh install.
Glad it works for you on that version though but I'm sure that feature wasn't there by design.
6. Re: code color php in htm and html documents
helennewton Aug 21, 2011 2:05 PM (in response to John Waller)Lol, Must been some problems with your pc, since 2004 I had several computers,
and formatted many times, used diferent windows, and it always colored my php code.
Later I will try and let you know if I manage to get it to work.
However I do think this should be an option.
7. Re: code color php in htm and html documents
MurraySummers Aug 21, 2011 2:07 PM (in response to helennewton)To change the extension of the pages that been on first page in google, I prefer to use my old version of dreamweaver.
This is the simplest thing in the world if you are hosted on a *nix server. Just use an .htaccess file to do a 301 redirect of oldname to newname. No SEO penalty at all when it's a 30x redirect. Look at the flexibility you'll gain by doing that!
8. Re: code color php in htm and html documents
MurraySummers Aug 21, 2011 2:08 PM (in response to helennewton)I used MX2004 too, and don't recall it doing that either.
9. Re: code color php in htm and html documents
helennewton Aug 21, 2011 2:37 PM (in response to MurraySummers)lol and lol again,
I have it installed at this moment and yes it do color php files, I ever touched any files,
you must speak about another version,
if you want I can send it to you and you can see for yourself that it does.
No I dont want to change any name of any page that existed for many years,
and people know there name,
a more than 500 pages site in several languages,
and hundreds of pages are well indexed,
it is just perfect with the host serving the pages as php.
10. Re: code color php in htm and html documents
John Waller Aug 21, 2011 2:39 PM (in response to helennewton)No I dont want to change any name of any page that existed for many years,
No need for any issues there if you set up a 301 redirect via a .htaccess file. -
11. Re: code color php in htm and html documents
helennewton Aug 21, 2011 3:03 PM (in response to John Waller)
Thanks, but I now that perfectly well, I took the decision years ago to dont do a 301,I tell the server to read the html as php, as I think that is better, I dont want to change name of any
of my 500 pages, its just rediculous. No need to.
Dont know what I am doing wrong, I followed the instructions and it doesnt work, before
I got an error but that was because I saved the backup copy in the same folder.
Lets see if I think wright, I have to do change in extensions.text and in MMDocumentTypes.xml.
But should I delete the hmtl from html and add to php, or delet the php and add to html?
I tried both and non worked, maybe I have to restart. will restart and see if any changes dones.
Btw, I did a research on google, and there where many asking the same thing, Im not the only one,
12. Re: code color php in htm and html documents
mytaxsite.co.uk Aug 21, 2011 4:50 PM (in response to helennewton)I have put the following code in my conf file:
<IfModule dir_module>
DirectoryIndex index.php index.pl index.cgi index.asp index.shtml index.html index.htm \
default.php default.pl default.cgi default.asp default.shtml default.html default.htm \
home.php home.pl home.cgi home.asp home.shtml home.html home.htm
</IfModule>This ensures that no matter what the file extension is, my server will render the file. Perhaps this is not what you are looking for. Also, the configuration file is only relevant if you are running your own server. you can't change your host's files!!!
hth
13. Re: code color php in htm and html documents
Keith.L Aug 22, 2011 4:30 AM (in response to John Waller)Hi, I was also looking for a solution for the coloring codes problem and found this post.
I tried that link you provided, I tested all kind of ways, putting all into html, putting all into php, puttting all into both.
I restarted dreamweaver and its just the same....I do change the files that are in program files just as it says in the link and I do use notepad to do the change.
dont know if I doing anything wrong, anyway that link only talk about versions cs3 and lower, I have cs5, so maybe it wont work on cs5.
Keith
14. Re: code color php in htm and html documents
Keith.L Aug 22, 2011 10:16 AM (in response to helennewton)After hours researching both internet and my own pc, found another file with the same name that is the one that should be changed, this link I found in this forum:
http://kb2.adobe.com/cps/164/tn_16410.html this link does not concern cs5 at all.
To change the code color in cs5, you must change the MMDocumentTypes.xml file not found in programfiles as per that link, but the one that can be found in documents and settings/etc, changing the one in program files wont do absolutely nothing.
And I must agree with Helennewton, I think its a downgrade you cant color all kinds of codes in an html file,
its a handicap. (well you can do, however not easily).
And just to change filetype not domain name, the practice is to put a code in .htaccess file to read html files as whatever you want, not to do a 301
redirect that is more indicated when the page changed domain or name, not just extension.
Hope this will help more with the same problem,
would not be a bad idea to update that link with the correct information for cs5.
15. Re: code color php in htm and html documents
Lon Winters Aug 22, 2011 10:29 AM (in response to Keith.L)Well, there's one thing I learned from this discussion. I've often wondered how HTML files were able to run script, such as log ins. Now I know! Generally speaking though, wouldn't this practice be considered deprecated? If so, and while I do understand the issue and logic of the problem, I feel that any solution shold move away from deprecated methods, in general of course.
16. Re: code color php in htm and html documents
MurraySummers Aug 22, 2011 10:31 AM (in response to Lon Winters)wouldn't this practice be considered deprecated?
I don't think you could call it deprecated, and in some cases it may be the only solution. But it will certainly cause a successor to scratch their head a bit at first.
17. Re: code color php in htm and html documents
MurraySummers Aug 22, 2011 10:33 AM (in response to Lon Winters)I've often wondered how HTML files were able to run script, such as log ins.
Often times, they aren't. The HTML page is likely submitting the data to a server-scripted process page which returns to the login page if authentication fails.
18. Re: code color php in htm and html documents
Keith.L Aug 22, 2011 11:34 AM (in response to MurraySummers)Murray *ACP* wrote:
Just dont understand that, if you write in your htaccess file your html files are asp or php pages, they works just like if they were called .asp or .php
There is absolutely no difference.
If you add this to your htaccess:
AddType application/x-httpd-php html
all your pages named html will function as if they were php pages.
You can do whatever you want using php, as for exampel login. If you cant code for yourself,
well maybe the host have some loginscript for you.
19. Re: code color php in htm and html documents
Thanks Keith,
Finally I found the file you are talking about, and it works perfect, thanks a lot.
You must not save a copy of the file in the same folder just as they say in the link, if you do you get error. So if you do a backup of the file before editing it, save it somewhere else.
And its not in programfiles as the link says, (as Keith found out) In my pc it was in documents and settings/administrator/ (In programfiles there is another with the same name)
20. Re: code color php in htm and html documents
CJJ9 Oct 16, 2012 4:52 PM (in response to helennewton)I'm Korean. And ... not good at English ^^ sorry.
My environment is : Win7, DreamweaverCS5
1. Exit dreamweaver
2. Kill the process named "CS5.5ServiceManager.exe" in the task manager. (VERY IMPORTANT)
If you miss this step, you will receive many error messages when start DW.
And the changes in configuration is not work correctly.
3. Remove directory "C:\Users\cjjo\AppData\Roaming\Adobe\Dreamweaver CS5.5", if it exists.(VERY IMPORTANT)
4. Modify "(DWCS5 Install directory)\configuration\Extentions.txt"
move the 'HTML' on line 2 in ':HTML Documents' to ':PHP Files'.
... like this ...
HTM,HTA,HTC,XHTML:HTML Documents
... skip lines ...
PHP,PHP3,PHP4,PHP5,TPL,PHP-DIST,PHTML,HTML:PHP Files
Save and close.
5. Modify "(DWCS5 Install directory)\configuration\DocumentTypes\MMDocumentTypes.xml"
1) find '<documenttype id="HTML"', and remove 'html' in 'winfileextension=' and 'macfileextension='.
=> <documenttype id="HTML" internaltype="HTML" winfileextension="htm,shtml,shtm,stm,tpl,lasso,xhtml"
macfileextension="htm,shtml,shtm,tpl,lasso,xhtml,ssi" file="Default.html" writebyteordermark="false" mimetype="text/html">
2) find 'id="PHP_MySQL"', and add 'html' in that section's two list.
=> <documenttype id="PHP_MySQL" servermodel="PHP MySQL" internaltype="Dynamic"
winfileextension="php,php3,php4,php5,phtml,html" macfileextension="php,php3,php4,php5,phtml,html" file="Default.php"
Save and close.
6. Start DW.
All instructions I found in the web, they only explain that how to change the configuration.
And they didn't work. So, I spent much time to find correct way.
The important thing is that => step 2 and 3
Thanks~ Good luck
Oh my poor Eng. T.T
