1 Reply Latest reply on Aug 25, 2011 12:43 PM by tech_kid_11
    Adobe Photoshop CS5 failed to install. None of the solutions in the previous thread worked.
    RimaSmosh
      I RAN ADOBE SUPPORT ADVISER AND IT SAID
      cpsid_90243r4: Error DW020 or DW050 occurs during installation - Creative Suite 5.5, Flash CS5.5, Flash Builder 4.5
      My laptop's running on windows vista home premium, sp2,32bit
      Intel(R) Core(TM)2 Duo CPU T7700 @ 2.40GHz 2.40GHz
      RAM 2GB
      PHOTOSHOP STOPS DOWNLOAD AT 38% AND HERE’S THE ERROR
      Exit Code: 6
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 46 error(s), 45 warning(s)
      WARNING: DW024: The payload: Adobe Photoshop CS5.1 Core  {08EF22BC-43B2-4B4E-BA12-52B18F418F38} requires a UI parent with following specification:
                      Family: Photoshop
                      ProductName: Adobe Photoshop CS5.1 Core_x64
                      This parent relationship is not satisfied, because this payload is not present in this session.
      WARNING: DW031: Payload:{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 has been updated and has been selected for repair. The patch {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0 will be uninstalled now.
      ----------- Payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0 -----------
      ERROR: Error 1935.An error occurred during the installation of assembly component {43CC1B37-B20C-3EBC-9C04-F809989E4FD3}. HRESULT: 0x80071A30.
      ERROR: Install MSI payload failed with error: 1603 - Errore irreversibile durante l'installazione.
      MSI Error message: Error 1935.An error occurred during the installation of assembly component {43CC1B37-B20C-3EBC-9C04-F809989E4FD3}. HRESULT: 0x80071A30.
      WARNING: DW036: Payload cannot be installed due to dependent operation failure
      ----------- Payload: {D1B83970-7269-48BE-8B0E-5120D9327E52} Adobe Player for Embedding 3.1 3.101.0.0 -----------
      ----------- Payload: {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0 -----------
      ----------- Payload: {7EABC54B-02C3-4DA1-9EB4-974CE7414066} AdobeHelp 3.4.0.0 -----------
      ----------- Payload: {9158FF30-78D7-40EF-B83E-451AC5334640} Adobe Photoshop CS5.1 Driver 12.1.0.0 -----------
      ERROR: DW050: The following payload errors were found during install:
      ERROR: DW050:  - Adobe ExtendScript Toolkit CS5.5: Install failed
      ERROR: DW050:  - Microsoft_VC90_ATL_x86: Install failed
      ERROR: DW050:  - Microsoft_VC90_CRT_x86: Install failed
      ERROR: DW050:  - Adobe Photoshop CS5.1 Core: Failed due to Language Pack installation failure
      ERROR: DW050:  - Microsoft_VC80_ATL_x86: Install failed
      ERROR: DW050:  - Adobe Photoshop CS5.1 International English Language Pack_AdobePhotoshop12-en_GB: Install failed
      ERROR: DW050:  - Adobe XMP Panels CS5: Install failed
      ERROR: DW050:  - Photoshop Camera Raw: Install failed
      ERROR: DW050:  - Adobe Extension Manager CS5.5: Install failed
      ERROR: DW050:  - Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll: Install failed
      ERROR: DW050:  - AdobeColorCommonSetRGB: Install failed
      ERROR: DW050:  - AdobeColorPhotoshop CS5.5: Install failed
      ERROR: DW050:  - Adobe Device Central CS5.5: Failed due to Language Pack installation failure
      ERROR: DW050:  - Adobe Mini Bridge CS5.1: Install failed
      ERROR: DW050:  - AdobeColorCommonSetCMYK: Install failed
      ERROR: DW050:  - Microsoft_VC90_MFC_x86: Install failed
      ERROR: DW050:  - Adobe Linguistics CS5: Install failed
      ERROR: DW050:  - PDF Settings CS5: Install failed
      ERROR: DW050:  - AdobeTypeSupport CS5: Install failed
      ERROR: DW050:  - Adobe CSXS Infrastructure CS5.5: Install failed
      ERROR: DW050:  - AdobeColorEU CS5.5: Install failed
      ERROR: DW050:  - Microsoft_VC80_CRT_x86: Install failed
      ERROR: DW050:  - Adobe Device Central CS5.5_DeviceCentral3.5LP-en_GB: Install failed
      ERROR: DW050:  - AdobeColorJA CS5.5: Install failed
      ERROR: DW050:  - AdobeOutputModule: Install failed
      ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS5: Install failed
      ERROR: DW050:  - Microsoft_VC90_MFCLOC_x86: Install failed
      ERROR: DW050:  - AdobePDFL CS5: Install failed
      ERROR: DW050:  - AdobeCMaps CS5: Install failed
      ERROR: DW050:  - Adobe CSXS Extensions CS5.5: Install failed
      ERROR: DW050:  - Adobe ReviewPanel CS5.5: Install failed
      ERROR: DW050:  - Required Common Fonts Installation: Install failed
      ERROR: DW050:  - Adobe SwitchBoard 2.0: Install failed
      ERROR: DW050:  - Microsoft_VC80_MFC_x86: Install failed
      ERROR: DW050:  - Microsoft_VC80_MFCLOC_x86: Install failed
      ERROR: DW050:  - Recommended Common Fonts Installation: Install failed
      ERROR: DW050:  - AdobeColorNA CS5.5: Install failed
      ERROR: DW050:  - AdobeJRE: Install failed
      ERROR: DW050:  - AdobeColorVideoProfilesCS CS5.5: Install failed
      ERROR: DW050:  - Suite Shared Configuration CS5.5: Install failed
      ERROR: DW050:  - Adobe Bridge CS5.1: Install failed
      ERROR: DW050:  - Adobe Photoshop CS5.1 Support: Install failed
      ERROR: DW050:  - Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All: Install failed
