1 Reply Latest reply on Aug 22, 2011 3:37 AM by Starlover_jacob
    How to find installed assets on mac in applicationdirectory
    Starlover_jacob Level 1
      File.applicationDirectory—the read-only directory where the application is installed (along with any installed assets)
      How do i get to this assets folders/files on a mac?
      I tried the following, but i don't get a list of files.... it works on a windows machine..
      structure:
      myapp.air
      assets/folder1/img1.jpg
      assets/follder1/img2.jpg
      assets/folder2/anotherimage.jpg
      urlarray:Array=getallfilesinfolder(folder1);
      public function getallfilesinfolder(foldername:String):Array {      var filearray:Array=new Array();      var directory:File = File.applicationDirectory;      directory = directory.resolvePath("assets/"+foldername+"");      var contents:Array = directory.getDirectoryListing();      for (var i:Number = 0; i < contents.length; i++)      {             if(contents[i].type==".jpg" ||contents[i].type==".JPG" || contents[i].type==".png")             filearray.push(contents[i].url);      }                    return filearray; }
      Please some help.
      Perhaps you also know a solution for folders that begin wit a # (%23).
      When i want to get a filelist from that folder, the function simply stops on a mac. no error... nothing
        • 1. Re: How to find installed assets on mac in applicationdirectory
          Hi, i found my answer.
          It turns out that mac doesn't use type. Instead i had to check on extension
          contents[i].extension=="jpg"
          How i found out? to alert some variables like this.
          first i checked if the folder assets/folder1 exists
          import mx.utils.ObjectUtil;
          directory = directory.resolvePath("gardenimages/"+foldername+"");
          Alert.show("test:"+ObjectUtil.toString(directory));
          It will get you a long list of info on the folder. by checking the nativepath, url and exists we can tell if the folder is there.
          Now check the contents of that folder to see if the images are there.
          var sTemp:String = "";
          for (var i2:int=0;i2<contents.length;i2++)
                 sTemp += contents [i2].name + "\n";
                 sTemp += contents [i2].exists + "\n";
                 sTemp += contents [i2].nativePath + "\n";
                 sTemp += contents [i2].url + "\n";
                 sTemp += contents [i2].type + "\n";
                 sTemp += contents [i2].extension + "\n";
                 sTemp += "----------- \n";
          and you will see.. on a mac type is null
          Greets, J.
