PDF forms created in Livecycle Designer have bindings of some form fields and an XML data source (Livecycle Preview looks great). When I make user-like data entry into the form as it is displayed in Lifecycle Preview, it behaves as I would expect at the user end after distribution . When submitted from Livecycle Preview it generates an email with an attached XML document representative of the entered data. My problem is that switching back to the Livecycle Design, saving the form, closing Livecycle, opening the form in Adobe Acrobat 8, enabling usage rights in Adobe Reader , and finally distributing the document, it arrives at the user end and is displayed as it is in Livecycle Design View (None of the bound fields are visible and the flowable form is not "flowed". I looks exactly like the Licecycle Design View.
Views
Total Likes
In the Preview it is importing the data that you have specified and is merging that data onto the form template to show you the template and data together. When you distribute the form you are merely sending the blank template (no data file). The user woudl have to import he data file (assuming they had it to get the same result.....or .......you woudl have to merge the data into the template before distribution.
Paul
Views
Total Likes
Thanks for the reply. The user community has no import capability (forms are email-attached for opening using the free Adobe Reader). I want to populate the form from my end (Adobe Acrobat 8.13). I was under the impression that associating the form as follows was sufficient fo populate the form.
File > Form Properties > Select Default Tab and at the Data File: prompt, enter the name of a local XML document that binds to form fields
Am I missing a step?
Views
Total Likes
That is not on the Default tab but on the Preview tab and that only will apply to the Preview. You coudl try opening the form
importing the data file and then do the distribute from Acrobat ...that might work.
Paul
Views
Total Likes
Thanks Paul,
That seems to be the right direction...Still a few issues but I can handle those,,,Thanks again
Views
Total Likes
Views
Likes
Views
Likes
