6 Replies Latest reply on Aug 24, 2011 12:49 AM by Starlover_jacob
    problem with # (%23) in foldername
    Starlover_jacob Level 1
      Hi there,
      I have a backup script for my air application that creates a zip of all files inside applicationStorageDirectory.
      One of the folders inside that dir is called; #ApplicationUpdater
      For some reason the function that gets all filenames inside that folder stops to work.
      This works on a windows machine, but on a mac it simply stops.. no error nothing..
      Please some help.
      code:
      getlist=getdirlist(dirlist,foldername);
                  // used vars for getting a dirlist of the applicationstoragedir.
                  private var tempdirlist:Array;
                  private var foldername:String;
                  private var dirlist:Array=new Array();
                  // ATTENTION! RECURSIVE FUNCTION.
                  private function getdirlist(tempdirlist:Array,foldername:String):Array
                      // path to application storage dir.
                      var directory:File = File.applicationStorageDirectory;
                      if(foldername!=null)
                          directory=File.applicationStorageDirectory.resolvePath(unescape(foldername));
                      // gets a list of files and folders.
                      tempdirlist=directory.getDirectoryListing();
                      //run trough that list.
                      for (var i:uint = 0; i < tempdirlist.length; i++)
                          // if you want to show folders in the dirlist array just turn of the following if statement.
                          if(tempdirlist[i].extension!=null)
                              var stringcut:String=tempdirlist[i].url;
                              dirlist.push(stringcut);
                          // if no extention is found it must be a folder, so we go into it by
                          // calling this function and give that foldername with it.
                          //if(tempdirlist[i].extension==null)
                          else
                              foldername=tempdirlist[i].url;
                              getdirlist(tempdirlist,foldername);
                      return dirlist;
        • 1. Re: problem with # (%23) in foldername
          Flex harUI Adobe Employee
          Is there a reason you are calling unescape?
          • 2. Re: problem with # (%23) in foldername
            Well in my previous attempts i used tempdirlist[i].nativePath substracted some characters from it to let it work.. i then got the problem on windows with # so after some search i found that unescape could help.
            Well some programming days later.. i found out that saving a nativePath of an image to my sqlite db was not a succesfull idea. I needed to save url instead, so i can place a backup of my sqlite database and folder of images at any system.. and it would just work.
            so i also modified my backup to url instead of nativePath.. so the unescape was just a leftover of previous coding.. and it didn't seem to bother on a windows machine.. so i left it there.
            I removed it from the code and tested it again.. no difference what so ever.. it works on a windows machine.. still not on a mac.
            Any ideas?
            • 3. Re: problem with # (%23) in foldername
              When you debug through it, do you not get a valid directory or is
              tempDirList null?
              • 4. Re: problem with # (%23) in foldername
                when i do:
                Alert.show(""+tempdirlist.length);
                it outputs 5, so he thinks there are 5 items in my applicationStorageDirectory
                When i look at my folder structure there are the following files/folders:
                #ApplicationUpdater (folder)
                imagesfolder (folder)
                imagesfolder2 (folder)
                imagesfolder3 (folder)
                mydatabase.db (file)
                so 5 is correct.
                Now i run trough that tempdirlist
                                    Alert.show(""+tempdirlist[i].url);
                the alert shows me: app-storage:/%23ApplicationUpdater
                since there is no extension it should be a folder, so i call the same function with that folder name.. in this case app-storage:/%23ApplicationUpdater
                Now it should run to the same alert where i get a numer of items inside that applicationupdater folder.
                I do not get an alert.. so directory=File.applicationStorageDirectory.resolvePath(foldername); failed
                Is there a way to alert all given errors? since i develop on a windows machine export my project and test it on a mac.. i cannot debug on a mac. Only by showing stuff by using alert or put it in textarea.
                Greets, J.
                • 5. Re: problem with # (%23) in foldername
                  According to the doc, you should not use URLs in resolve path, try using the
                  nativePath instead
                  • 6. Re: problem with # (%23) in foldername
                    Thank you.. it indeed were that simple.
                    Beneith the correct function to get a dirlist from the applicationStorageDirectory.
                    I cut the first part of the string, to get a list of folder/filename items and not the complete nativepath.
                    This way.. when i need to read that files for lets say creating a zip. I can use; var thisfile:File =File.applicationStorageDirectory.resolvePath(getlist[1]);
                                            var stringcut:String=tempdirlist[i].nativePath;
                                            var fulllength:Number=stringcut.length;
                                            var lengthToSubstract:String = File.applicationStorageDirectory.nativePath;
                                            stringcut=stringcut.substr(lengthToSubstract.length+1,fulllength);
                                        // calling this function and give that nativePath to that folder with it.
                                        else
                                            var newfoldername:String=tempdirlist[i].nativePath;
                                            getdirlist(tempdirlist,newfoldername);
                                    return dirlist;
                    var getlist:Array;
