7 Replies Latest reply on Aug 24, 2011 3:30 AM by try67
    Dropdown value
    jck_drmjn Level 1
      The value of Dropdown are A,B,C.
      If "A" select, Text_A will be equal to Text_1. (this.getField("Text_A")=this.getField("Text_1") .value)
      What is the code and where should I place it?
      I have made code for it but it shows left hand invalid.
        • 1. Re: Dropdown value
          As the combo's validate script, enter this:
          this.getField("Text_A").value="";
          this.getField("Text_B").value="";
          this.getField("Text_C").value="";
          if (event.value=="A")
          this.getField("Text_A").value=this.getField("Text_1") .value;
          else if (event.value=="B")
          this.getField("Text_B").value=this.getField("Text_1") .value;
          else if (event.value=="C")
          this.getField("Text_C").value=this.getField("Text_1") .value;
          etc.
          • 2. Re: Dropdown value
            jck_drmjn Level 1
            Thanks. It works well in calculation script.
            If check box depends on text field value, what is the code for it?
            Example:
            If(event.value == "A")
            checkbox.value = "true";
            What is the perfect code?
            • 3. Re: Dropdown value
              You need to use the value specified as the Export Value, which is usually "Yes".
              So like this:
              getField("Check Box1").value="Yes";
              Another option, probably a better one, is to do it like so:
              getField("Check Box1").checkThisBox(0,true);
              • 4. Re: Dropdown value
                jck_drmjn Level 1
                Many thanks for help me.
                It does not work.
                I have used under text field:
                if(event.vaue =="A")
                I have test for both code. Where am I making mistake?
                Thanks again
                • 5. Re: Dropdown value
                  First of all, the name of the property is "value", not "vaue".
                  Also, you will need to change the name of the check-box in the second line to match yours. I used "Check Box1" as an example.
                  • 6. Re: Dropdown value
                    jck_drmjn Level 1
                    Nice. It works now.
                    Would you tell me following things:
                    if(condition1)
                    {statement1}// this statement will be executed always under condition1
                                   if(condition1_1)   // this condition depends on condition1
                                   {statement2}
                                   else if(condition1_2)
                                   statement2}
                                   else{statement}
                    else if (condition2)
                    {statement}
                    else
                    What is the easiest code in this case?
                    • 7. Re: Dropdown value
                      Seems fine to me the way that it is...
