7 Replies Latest reply on Oct 2, 2011 11:58 PM by pauland
    Calculator
    newbie-fl3x
      Hi Everyone
      I am trying to make simple calc on flex mobile,
      It doesn`t work it doesn`t display anything on text area
      and i got no error message, just warning message abou Data Binding
      This is the code
      <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
        xmlns:s="library://ns.adobe.com/flex/spark" title="HomeView">
      <fx:Declarations>
        <!-- 非ビジュアルエレメント (サービス、値オブジェクトなど) をここに配置 -->
      </fx:Declarations>
      <fx:Script>
        <![CDATA[
         public var numbers:Array = [num0_btn,num1_btn,num2_btn,num3_btn,num4_btn,num5_btn,num6_btn,num7_btn,num8_btn,num9_bt n];
         public var operators:Array = [equal_btn,divide_btn,subtract_btn,add_btn];
         public var op:String;
         public var num1:Number;
         public var num2:Number;
         [Bindable]
         public var txt:TextField = new TextField();
         public function addListeners():void
          for(var i:uint = 0; i < numbers.length; i++)
           numbers[i].addEventListener(MouseEvent.CLICK, pressNumber);
          for(i = 0; i < operators.length; i++)
           operators[i].addEventListener(MouseEvent.CLICK, pressOperator);
          clear_btn.addEventListener(MouseEvent.CLICK, clearAll);
          dot_btn.addEventListener(MouseEvent.CLICK, addDot);
         public function pressNumber(event:MouseEvent):void
          var instanceName:String = event.target.name;
          var numPushed:String = instanceName.charAt(3);
          if(txt.text == "0" || num1 == Number(txt.text))
           txt.text = "";
          txt.appendText(numPushed);
         public function pressOperator(event:MouseEvent):void
          var currentOp:String = instanceName.slice(0, instanceName.indexOf("_"));
          if(!num1)
           num1 = Number(txt.text);
           txt.text="";
           op = currentOp;
          else if(!num2)
           num2 = Number(txt.text);
           showCalculation();
           op = currentOp;
         public function clearAll(event:MouseEvent):void
          txt.text = "0";
          num1 = NaN;
          num2 = NaN;
         public function addDot(event:MouseEvent):void
          if(num1 == Number(txt.text))
           txt.text = "0";
          if(txt.text.indexOf(".")==-1)
           txt.appendText(".");
         public function showCalculation():void
          switch(op)
           case"multiply":
            num1 *= num2;
            break;
           case"divide":
            num1 /= num2;
            break;
           case"add":
            num1 += num2;
            break;
           case"subtract":
            num1 -= num2;
            break;
           default:
            break;
          txt.text = String(num1);
          num2 = NaN;
      </fx:Script>
      <s:TextArea id="window_txt" x="20" y="44" text="{txt.text}"/>
      <s:Button id="num1_btn" x="46" y="399" label="1" />
      <s:Button id="num2_btn" x="128" y="399" label="2" />
      <s:Button id="num3_btn" x="216" y="399" label="3" />
      <s:Button id="num0_btn" x="50" y="494" label="0" />
      <s:Button id="add_btn" x="294" y="308" label="+" />
      <s:Button id="equal_btn" x="294" y="493" label="=" />
      <s:Button id="dot_btn" x="128" y="493" label="."/>
      <s:Button id="clear_btn" x="216" y="493" label="C"/>
      <s:Button id="subtract_btn" x="294" y="399" label="-"/>
      <s:Button id="num4_btn" x="46" y="308" label="4"/>
      <s:Button id="num5_btn" x="128" y="308" label="5"/>
      <s:Button id="num6_btn" x="216" y="308" label="6"/>
      <s:Button id="divide_btn" x="294" y="131" label="÷"/>
      <s:Button id="num7_btn" x="46" y="219" label="7"/>
      <s:Button id="num8_btn" x="128" y="219" label="8"/>
      <s:Button id="num9_btn" x="216" y="219" label="9"/>
      <s:Button x="46" y="131" width="48" label="M+" fontSize="12"/>
      <s:Button x="128" y="131" label="M-" fontSize="12"/>
      <s:Button x="216" y="131" label="mr" fontSize="12"/>
      <s:Button id="multiply_btn" x="294" y="219" label="x"/>
      </s:View>
        • 1. Re: Calculator
          kraikit Level 2
          I haven't looked too closely, but at a quick glance it looks like you have an addListeners() function to attach the click listeners. Where does addListeners() get called?
          -- Tom Kraikit
          Flex SDK engineer
          • 2. Re: Calculator
            newbie-fl3x Level 1
            Hi Tom,
            Thanks for Reply
            I try to call my addListener() to my buttons, but got this error messages.
            TypeError: Error #1009: Cannot access a property or method of a null object reference.
            at Calculator/addListeners()[C:\Users\ut\Adobe Flash Builder 4.5\Calculator\src\Calculator.mxml:27]
            at Calculator/__num1_btn_click()[C:\Users\ut\Adobe Flash Builder 4.5\Calculator\src\Calculator.mxml:120]
            and then try to trace it with
            trace("mytrace:" + numbers[i]); -->  //mytrace: null
            trace("mytrace:" + numbers.length); --> //mytrace: 10
            trace("mytrace:" + i); --> //mytrace: 1
            <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                    xmlns:mx="library://ns.adobe.com/flex/mx">
            <fx:Script>
              <![CDATA[
               import flash.events.MouseEvent;
                if(window_txt.text == "0" || num1 == Number(window_txt.text))
                 window_txt.text = "";
                window_txt.appendText(numPushed);
                if(!num1)
                 num1 = Number(window_txt.text);
                 window_txt.text="";
                 op = currentOp;
                else if(!num2)
                 num2 = Number(window_txt.text);
                 showCalculation();
                 op = currentOp;
                window_txt.text = "0";
                num1 = NaN;
                num2 = NaN;
                if(num1 == Number(window_txt.text))
                if(window_txt.text.indexOf(".") == -1)
                 window_txt.appendText(".");
                switch(op)
                 case"multiply":
                  num1 *= num2;
                  break;
                 case"divide":
                  num1 /= num2;
                  break;
                 case"add":
                  num1 += num2;
                  break;
                 case"subtract":
                  num1 -= num2;
                  break;
                 default:
                  break;
                window_txt.text = String(num1);
                num2 = NaN;
            </fx:Script>
            <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
            </fx:Declarations>
            <s:TextArea id="window_txt" x="20" y="44" height="42" text="0"/>
            <s:Button id="num1_btn" x="23" y="182" label="1" click="addListeners()"/>
            <s:Button id="num2_btn" x="105" y="182" label="2" click="addListeners()"/>
            <s:Button id="num3_btn" x="193" y="182" label="3" click="addListeners()"/>
            <s:Button id="num0_btn" x="27" y="212" label="0" click="addListeners()"/>
            <s:Button id="add_btn" x="271" y="153" label="+" click="addListeners()"/>
            <s:Button id="equal_btn" x="271" y="211" label="=" click="addListeners()"/>
            <s:Button id="dot_btn" x="105" y="211" label="." click="addListeners()"/>
            <s:Button id="clear_btn" x="193" y="211" label="C" click="addListeners()"/>
            <s:Button id="subtract_btn" x="271" y="182" label="-" click="addListeners()"/>
            <s:Button id="num4_btn" x="23" y="153" label="4" click="addListeners()"/>
            <s:Button id="num5_btn" x="105" y="153" label="5" click="addListeners()"/>
            <s:Button id="num6_btn" x="193" y="153" label="6" click="addListeners()"/>
            <s:Button id="divide_btn" x="271" y="97" label="÷" click="addListeners()"/>
            <s:Button id="num7_btn" x="23" y="125" label="7" click="addListeners()"/>
            <s:Button id="num8_btn" x="105" y="125" label="8" click="addListeners()"/>
            <s:Button id="num9_btn" x="193" y="125" label="9" click="addListeners()"/>
            <s:Button x="23" y="97" width="48" label="M+" fontSize="12" click="addListeners()"/>
            <s:Button x="105" y="97" label="M-" fontSize="12" click="addListeners()"/>
            <s:Button x="193" y="97" label="mr" fontSize="12" click="addListeners()"/>
            <s:Button id="multiply_btn" x="271" y="125" label="x" click="addListeners()"/>
            </s:WindowedApplication>
            • 3. Re: Calculator
              pauland Level 4
              Your array initialisation for numbers is done before the buttons are created, so it's full of nulls.
              public var numbers:Array = [num0_btn,num1_btn,num2_btn,num3_btn,num4_btn,num5_btn,num6_btn,num7_ btn,num8_btn,num9_btn];
              Check out creation complete. You must wait for the interface to be built before referring to the buttons.
              You have supplied "addListeners()" as the handler for a click for all your UI elements. It should be called only once, preferably after creation complete, and certainly not as part of a click handler.
              You are clearly confused as to the differrence between creating a click event handler in MXML and actionscript.
              click="addListeners()" in MXML is saying that "my handler for the click event is what's between the quotes".
              When you write in AS3
              addEventListener(MouseEvent.CLICK, pressNumber);  you are saying "this is my click handler for the click event, for this UI element".
              So, use one or the other, either
              click="pressNumber(event)" in MXML, or addEventListener(MouseEvent.CLICK, pressNumber); in AS3, but not both.
              That should give you some movement towards the solution.
              I would also say, that before bad habits get entrenched, the old flash naming convention "subtract_btn" is not so good in Flex or indeed Flash these days. Use camel case to name your variables rather than underscores, so subtract_btn becomes subtractBtn. Better to start with that right now than later!
              Good luck.
              Paul
              • 4. Re: Calculator
                newbie-fl3x Level 1
                Hi Paul
                thanks for quick response
                I follow your advice and fix the code. creationComplete="addListeners()"
                Now i got displayed numbers on calc screen every time i push the button ,
                i forgot to include instanceName in Flex, got confused between "id" and "name" (instanceName in AS3)
                But the operators doesn't work well , any suggestion ???
                THis is the code
                        xmlns:mx="library://ns.adobe.com/flex/mx" creationComplete="addListeners()" >
                <fx:Script>
                  <![CDATA[
                    var numbers:Array = [num0Btn,num1Btn,num2Btn,num3Btn,num4Btn,num5Btn,num6Btn,num7Btn,num8Btn,num9Btn];
                    var operators:Array = [divideBtn,addBtn,subtractBtn,multiplyBtn,equalBtn];
                    clearBtn.addEventListener(MouseEvent.CLICK, clearAll);
                    dotBtn.addEventListener(MouseEvent.CLICK, addDot);
                    if(!num1)
                     window_txt.text="";
                     op = currentOp;
                    else if(!num2)
                     showCalculation();
                     op = currentOp;
                    num1 = NaN;
                    num2 = NaN;
                    switch(op)
                     case"multiply":
                      num1 *= num2;
                      break;
                     case"divide":
                      num1 /= num2;
                      break;
                     case"add":
                      num1 += num2;
                      break;
                     case"subtract":
                      num1 -= num2;
                      break;
                     default:
                      break;
                    num2 = NaN;
                </fx:Script>
                <fx:Declarations>
                </fx:Declarations>
                <s:Button id="num1Btn" x="23" y="182" label="1" name="num1Btn" />
                <s:Button id="num2Btn" x="105" y="182" label="2" name="num2Btn"/>
                <s:Button id="num3Btn" x="193" y="182" label="3" name="num3Btn"/>
                <s:Button id="num0Btn" x="27" y="212" label="0" name="num0Btn"/>
                <s:Button id="addBtn" x="271" y="153" label="+" name="addBtn"/>
                <s:Button id="equalBtn" x="271" y="211" label="=" name="equalBtn"/>
                <s:Button id="dotBtn" x="105" y="211" label="." name="dotBtn"/>
                <s:Button id="clearBtn" x="193" y="211" label="C" name="clearBtn"/>
                <s:Button id="subtractBtn" x="271" y="182" label="-" name="subtractBtn"/>
                <s:Button id="num4Btn" x="23" y="153" label="4" name="num4Btn"/>
                <s:Button id="num5Btn" x="105" y="153" label="5" name="num5Btn"/>
                <s:Button id="num6Btn" x="193" y="153" label="6" name="num6Btn"/>
                <s:Button id="divideBtn" x="271" y="97" label="÷" name="divideBtn"/>
                <s:Button id="num7Btn" x="23" y="125" label="7" name="num7Btn"/>
                <s:Button id="num8Btn" x="105" y="125" label="8" name="num8Btn"/>
                <s:Button id="num9Btn" x="193" y="125" label="9" name="num9Btn"/>
                <s:Button x="23" y="97" width="48" label="M+" fontSize="12" />
                <s:Button x="105" y="97" label="M-" fontSize="12" />
                <s:Button x="193" y="97" label="mr" fontSize="12" />
                <s:Button id="multiplyBtn" x="271" y="125" label="x" name="multplyBtn"/>
                • 5. Re: Calculator
                  pauland Level 4
                  "But the operators doesn't work well"
                  Well that could mean anything! Put in some trace statements and/or have a go with the debugger. Start debugging by trying to add 1 to 1 and then gradually move on from there.
                  Paul
                  • 6. Re: Calculator
                    newbie-fl3x Level 1
                    I solve the problem,
                    @Paul, i follow your advice ("the old flash naming convention "subtract_btn" is not so good in Flex or indeed Flash these days") .so i change subtract_btn -> subtractBtn.
                    But then i realize that i am using "_" for my operators naming.
                    This was the problem and then i change my button id again
                    subtractBtn -> subtract_btn and it works.
                    anyway thanks.
                    I also learn how to combining vertical and horizontal group, playing with color picker.
                    It was fun.
                    <fx:Script>
                      <![CDATA[
                        var operators:Array = [divide_btn,add_btn,subtract_btn,multiply_btn,equal_btn];
                         //trace("mytrace:" + i);
                        //trace("instanceName:" + instanceName);
                        trace("numPushed:" + numPushed);
                        if(!num1)
                         window_txt.text="";
                         op = currentOp;
                        else if(!num2)
                         showCalculation();
                         op = currentOp;
                        trace("currentOp:" + currentOp);
                        num1 = NaN;
                        num2 = NaN;
                        switch(op)
                         case"multiply":
                          num1 *= num2;
                          break;
                         case"divide":
                          num1 /= num2;
                          break;
                         case"add":
                          num1 += num2;
                          break;
                         case"subtract":
                          num1 -= num2;
                          break;
                         default:
                          break;
                        num2 = NaN;
                    </fx:Script>
                    <fx:Declarations>
                    </fx:Declarations>
                    <s:layout>
                      <s:HorizontalLayout gap="15" paddingLeft="10" paddingTop="10"/>
                    </s:layout>
                    <mx:VDividedBox backgroundColor="{colorPicker.selectedItem.toString()}">
                      <s:Panel width="100%" height="74">
                       <s:TextArea id="window_txt" x="0" y="0" width="308" height="42" fontSize="20" text="0"
                          textAlign="right"/>
                      </s:Panel>
                    <mx:HDividedBox height="136">
                      <s:VGroup horizontalAlign="left" verticalAlign="top">
                       <s:Button label="M+" fontSize="12" />
                       <s:Button id="num7Btn" label="7" name="num7Btn"/>
                       <s:Button id="num4Btn" label="4" name="num4Btn"/>
                       <s:Button id="num1Btn" label="1" name="num1Btn" />
                       <s:Button id="num0Btn" label="0" name="num0Btn"/>
                      </s:VGroup>
                       <s:Button label="M-" fontSize="12" />
                       <s:Button id="num8Btn" label="8" name="num8Btn"/>
                       <s:Button id="num5Btn" label="5" name="num5Btn"/>
                       <s:Button id="num2Btn" label="2" name="num2Btn"/>
                       <s:Button id="dotBtn" label="." name="dotBtn"/>
                      </s:VGroup>
                       <s:Button label="mr" fontSize="12" />
                       <s:Button id="num9Btn" label="9" name="num9Btn"/>
                       <s:Button id="num6Btn" label="6" name="num6Btn"/>
                       <s:Button id="num3Btn" label="3" name="num3Btn"/>
                       <s:Button id="clearBtn" label="C" name="clearBtn"/>
                      </s:VGroup>
                       <s:Button id="add_btn" label="+" name="add_btn"/>
                       <s:Button id="subtract_btn" label="-" name="subtract_btn"/>
                       <s:Button id="divide_btn" label="÷" name="divide_btn"/>
                       <s:Button id="multiply_btn" label="x" name="multiply_btn"/>
                       <s:Button id="equal_btn" label="=" name="equal_btn"/>
                      </s:VGroup>
                    </mx:HDividedBox>
                    </mx:VDividedBox>
                    <mx:ColorPicker id="colorPicker" />
                    • 7. Re: Calculator
                      pauland Level 4
                      Glad it worked out, and still the question is "not answered"!
